Hot Rods SBC Edelbrock manifold comparison
Discussion in 'The Hokey Ass Message Board' started by Desoto291Hemi, Mar 13, 2022.
  1. Edelbrock C3BX
    30 vote(s)
    61.2%
  2. Edelbrock Performer RPM
    19 vote(s)
    38.8%
  1. Okay guys,,,,,I’m looking for an idea of which manifold I should proceed with .
    I could buy a brand new “anything “,,,,but at this time these are what I have,,,,and they are free and clear .
    So,,,here goes .
    This engine is gonna be a pretty healthy street engine,,,,not a race engine .
    I’m getting old,,,,,and would like to do a nice replica of what I had many years ago .
    The block,,,,an 010 casting 350,,,,,bored .060,,,,4 relief flat tops .
    Warm Hydraulic cam,,,,,.473- .497 lift .
    2.02 - 1.60 heads .
    Here are the intakes :
    Edelbrock C3BX
    Edelbrock Performer RPM 6A4B8CFC-BC38-41BA-9BDE-21919B6A4132.jpeg 14559C95-679B-423C-B300-B0A4D8CC8B34.jpeg 3880B904-0623-4715-9B85-7FC8335E41FB.jpeg
    1Nimrod likes this.
  2. lippy
    lippy
    from Ks
    Old Torker. Lippy
    Nugget37 and rbrewer like this.
  3. squirrel
    yeah, the old one, of course.
  4. blue 49
    blue 49
    from Iowa
    I've ran both on the 327 in my Henry J and they both work well. Both with the same 670 CFM Holley Street Avenger carb. I got the Perf RPM cheap and have it on now. I removed the performer RPM lettering and drilled for a fill tube so it wouldn't look so modern. The C3BX is on the 305 in my '36 Ford "bobber" truck With a 570 Street Avenger. I tried a Holley single plane on the 327 and it didn't like it much, or maybe I just didn't know what I was doing tuning it.
    Gary
    1Nimrod and loudbang like this.
  5. Old
    Because you said you wanted to replicate a past engine.
    A couple of HP or pounds of torque between the two isn’t very important
  6. lostone
    lostone
    from kansas
    I prefer the taller performer. Anything to help the torque.
    Deuces, Hollywood-East and loudbang like this.
  7. fastcar1953
    fastcar1953
    I'm with lostone. perf rpm
    Deuces and loudbang like this.
  8. Moriarity
    Moriarity
    SUPER MODERATOR
    certainly the 3BX
  9. oldiron 440
    oldiron 440
    RPM, I hate giving up performance....
    Deuces, loudbang and SS327 like this.
  10. sunbeam
    sunbeam
    I like sleepers grind off the logo and paint them orange
  11. squirrel
  12. jimmy six
    jimmy six
    I’d use the CBX3 after lightly blasting it to get remove the shine. For the oil tube I’d use an early Z28 with a seal top cap.
    1Nimrod, High test 63 and Fordors like this.
  13. 57JoeFoMoPar
    57JoeFoMoPar
    I voted for the C3BX but only because of the front oil fill tube. The Performer RPM is almost definitely a better intake that will make a bit more power. Such is the way of progress. But the old intake is still a solid option, and looks like someone already tried to make an "air gap" in the plenum. Aside from reliability, looking cool is always my top priority. If I'm going to get gapped by any bone stock new Challenger, Mustang GT or Camaro, I might as well look cool.
  14. moparboy440
    moparboy440
    from Finland
    Performer RPM for sure. It's not only about power but driveability also.
    Notice the “waffle” pattern at the bottom of the plenum on the Performer. This is an intentional feature that helps keep the fuel and air consistently mixed on their way to the cylinders.
    Deuces, loudbang and Desoto291Hemi like this.
  15. Jokester
    Jokester
    C3BX...but be aware that it may not work with an HEI if that's your ignition choice.
    .bjb
    1Nimrod likes this.
  16. Well I like a stock later truck intake with the plenum cut for a mild street motor. That is pretty much what the Performer is.
    if I was building a hot rod I would go with the C3BX. It is more of a hot rod manifold.
  17. blue 49
    blue 49
    from Iowa
    006.JPG With C3BX
    RPM1.JPG With Performer RPM with oil fill tube added.
    Gary
  18. Blues4U
    Blues4U
    from So Cal
    I would guess that any performance gain with the RPM would be marginal at best. It would be interesting to see some dyno numbers with them both on the same engine.
    1Nimrod, Stock Racer, ottoman and 2 others like this.
  19. lippy
    lippy
    from Ks
    I meant neither of those. Get a single plane old Torker and feel the high rpm kick. ;)
    Baumi likes this.
  20. Mario p herrera
    Mario p herrera
    I've had both over the years there isn't that much of a difference power wise at least on the streets I say go with the c3bx purely for the old school look
    1Nimrod, ottoman, Fordors and 3 others like this.
  21. swade41
    swade41
    from Buffalo,NY
    Another vote for the rpm after you removed the "performer rpm" letters and drilled it for the oil fill tube.
    Deuces, 427 sleeper and loudbang like this.
  22. Jones St.
    Jones St.
    The modern E-brock (not trad fellas) air gap. Same w/modern cam ground to your exact build.
  23. Fordors
    Fordors
    I’m into details on a hot rod. I’m not talking about having screw heads properly clocked or the lettering on a tire lined up with the valve stem and the logo on the center cap on a mag wheel too. My concern is if the suspension fits the theme of the car, does the engine look right too, and stuff like that.
    If I was building to a ‘60’s theme the Performer would stick out like a sore thumb, no matter how it was doctored.
  24. saltflats
    saltflats
    from Missouri
    What heads are you running, how do the ports line up?
  25. Hollywood-East
    Hollywood-East
    The taller one...
    Closest to the LT-1 intake which was an amazing factory intake across the rpm range..
  26. swade41
    swade41
    from Buffalo,NY
    I'm a performance kinda guy and would take that intake out of those two because it's more efficient at making hp.
    It's not like it's a modern Victor Jr. or something, John Q. Public wouldn't know the difference, only the **** guys that walk around and pick apart other people's car would notice.
  27. squirrel
    That's it, right there. I don't give a flip what JQP thinks. The guys who know, are who I'm building my car for.
    Gotta be the early one.
  28. Moriarity
    Moriarity
    SUPER MODERATOR
    yup, this right here.... make up the difference with driver ability, or if it is a street car does 5 or 10 hp at 6000 rpms really matter?? If you care anything about period correctness (if you don't then why are you here?) then it has to be the early one and it should not matter that one of those god awful ugly HEI distributors won't fit....
    1Nimrod, ottoman, kadillackid and 8 others like this.
  29. From it sounds like you are trying to do, go with the C3BX.
    1Nimrod and Fordors like this.
  30. jimmy six
    jimmy six
    How does each one perform from 650 to 3000 rpm is way more important to me than 5000-up. Fuel milage at cruising speed is nearer the top than once was.
    Mario p herrera, Blues4U and Fordors like this.
