Looking to Get Started...
Discussion in 'The Hokey Ass Message Board' started by Tribalmonkey, Dec 14, 2020.
  1. Tribalmonkey
    Tribalmonkey
    Couldn’t wait. I used my Lucas ***embly lube. Slicked it up and stuck it in :) New aluminum cam gear. New adjustable lifters. Installed and adjusted the original valves and guides with new springs in their original locations.
    BECC5DA1-1B61-4166-989B-25FA4F04A8B2.jpeg F8669A56-B1C6-4050-BA2B-1A08A488C840.jpeg 6C15736E-BA0C-46A3-A9C1-E27011FBB5B0.jpeg
    Dannerr, Stogy, loudbang and 2 others like this.
  2. Tribalmonkey
    Tribalmonkey
    You may notice I made a bit of an attempt to port the intake and exhaust. That’s what happens when you get too much time on your hands.
    Stogy, loudbang and lothiandon1940 like this.
  3. Tribalmonkey
    Tribalmonkey
    Still not roadster weather in MD.
    Dannerr, Stogy, Tman and 3 others like this.
  4. Tribalmonkey
    Tribalmonkey
    Making some progress on the banger. Valves adjusted, oil pump installed, oil pan installed. Working on getting flywheel housing true and then will mount the flywheel, clutch, and pressure plate. BA38B099-6CE3-424B-8144-C8DF03843436.jpeg 6537222F-F014-49E3-8CA6-6A45055A6EE2.jpeg
  5. Tribalmonkey
    Tribalmonkey
    Getting there…
    F67C5C03-5E06-47CB-ADA9-02CE0EE305DF.jpeg F558E6C5-7B06-401B-BA75-53D5C47D8078.jpeg A5C4C51C-3F49-485F-9844-46801285816F.jpeg E03DD6AC-5CA8-4FED-8F10-CE98FD19C7A8.jpeg
    Dannerr, Dustyp489, Stogy and 4 others like this.
  6. Tribalmonkey
    Tribalmonkey
  7. vtwhead
    vtwhead
  8. Tribalmonkey
    Tribalmonkey
    List is getting pretty short. Goal is to drive it this weekend. 3F86FC1B-F50B-4FE1-822B-F8D0880F2C56.jpeg 0E24171C-E39F-406A-9BBF-21204A322953.jpeg 563E3F38-CF16-4658-A4EF-62CF4FD864AF.jpeg
    Dannerr, Stogy, Tman and 4 others like this.
  9. vtwhead
    vtwhead
    Closer....waiting to hear this thing run.
  10. Tribalmonkey
    Tribalmonkey
    Ratty The Rusty Roadster lives again!! So much fun!
    Dannerr, Stogy, loudbang and 3 others like this.
  11. Tribalmonkey
    Tribalmonkey
  12. lothiandon1940
    lothiandon1940
  13. vtwhead
    vtwhead
    Sweet! That smile on your face says it all, well done.
  14. Tribalmonkey
    Tribalmonkey
    I finally got sync’d up on a roadster weather day and a running/driving roadster. Ratty has significantly more power now. Had a great 10 mile initial shake-down run. All good! 7BFB8180-8ABD-4DF9-AA3C-8536A7E2E54B.jpeg 6E469277-D2CF-46FF-B3B2-3F081AF48E73.jpeg
    Dannerr, drdave, Dustyp489 and 7 others like this.
  15. lothiandon1940
    lothiandon1940
  16. Tribalmonkey
    Tribalmonkey
    Yeah. I hate to get too many variables going at once. I was concerned that either my first try at a 39 trans rebuild or my first try at a cam replacement would go sideways. Once I’m sure this is dialed in I plan to try the Mallory distributor and the upgraded 12v generator.
    Stogy and lothiandon1940 like this.
  17. Rand Man
    Rand Man
  18. vtwhead
    vtwhead
    So glad you were able to drive it this week. Bet you felt great!
  19. Tribalmonkey
    Tribalmonkey
    Got the generator working pretty good after my 12v field upgrade. I have to admit it was a bit of a pain. Getting the new fields in tight enough for the armature to fit was a challenge. Not understanding that I had to polarize the fields to make them work was a hurdle. I learned a lot by reading the Ford Barn posts from the guys that rebuild these things.
    Dannerr, drdave, Stogy and 1 other person like this.
  20. Tribalmonkey
    Tribalmonkey
    You may also notice that I am hitting the new head with a strip disk to remove the coating so I can begin the rust process.
  21. vtwhead
    vtwhead
    You wouldn't be the first or last to not know about the polarization. I think I saw a foot note in my Olds manual referencing that which undoubtably saved me considerable head scratching.
  22. Tribalmonkey
    Tribalmonkey
    Hanging with my peeps at the Westminister Swap meet today.
    33D2164F-48FE-4354-8FA1-97E9888AFE9D.jpeg A5093B61-03E1-475C-B0D7-3A1BB4C58AAA.jpeg
    Dustyp489, Stogy and lothiandon1940 like this.
  23. Tribalmonkey
    Tribalmonkey
    I stopped by my buddy Skip’s house on the way back from the swap meet. He gave me his collection of F.A.S.T magazines. So generous. I have never been so excited about a box of magazines!!! 4340D599-8E59-47EA-9DF9-8517FB3D977B.jpeg
    Dannerr, Stogy and lothiandon1940 like this.
  24. lothiandon1940
    lothiandon1940
    Did you find anything at the swap meet that you didn't know you needed?:D;)
    Stogy and Tribalmonkey like this.
  25. Tribalmonkey
    Tribalmonkey
    Absolutely. I’ll post my small haul soon.
  26. Tribalmonkey
    Tribalmonkey
    Also received this in the mail today. I have more reading material than I have time for now. :)
    Dannerr, tr_rodder, Dustyp489 and 2 others like this.
  27. wheeldog57
    wheeldog57
    That ^^^^ is a fantastic book, you will find yourself referring to it often.
    The roadster is killer kid!
  28. Tribalmonkey
    Tribalmonkey
    Let’s talk voltage regulators. Should I use one with the 12v generator? Here is why I am asking. If I adjust the middle brush to give me 12v at idle then I get upwards of 17v at high RPMs. Seems like that is not good and could do some damage. If I adjust the middle brush lower then I only get 3-6v at my retarded timing cool model a loping idle. That means I am running off of battery power to keep the engine running. Any thoughts or recommendations?
    Stogy likes this.
  29. Dick Stevens
    Dick Stevens
    Voltage regulator use................YES!
