Technical Help required with GMC head gasket please
Discussion in 'Traditional Hot Rods' started by Little Terry, Mar 18, 2022.
  1. Little Terry
    Little Terry
    Hello everyone.
    I am in need of some help, please. I am trying to put a 46-54 270cid GMC motor (according to casting numbers) back together in my sprint car. This motor has been heavily hopped up in the past and so is now far from stock.
    I have a new gasket set, but the bores are larger than stock (approx 3.15/16"). The head gasket in the kit I have is too small and overhangs the bores. I am worried about hot spots and detonation with the gasket hanging into the top of the bores.
    There is a part number on the old gasket (Felpro 7607), but I cannot find any leads on where I can get one from, nor what I can cross reference it with.
    Please can any of you experienced guys give me some guidance on this - I am hoping to get to the beach races with the car in May.
    I am in the UK, which makes it even more complicated!
    Thank you
    LT
    Jet96, VANDENPLAS, vtx1800 and 3 others like this.
  2. 302GMC
    302GMC
    from Idaho
    Best gasket company makes 302 head gaskets, but won't sell to individuals, only businesses. Find a shop that will order one for you.
    gimpyshotrods and tractorguy like this.
  3. Little Terry
    Little Terry
    Thank you I will check them out. Is the 302 head gasket the same as the 270, apart from bore diamter?
  4. Bob Lowry
    Bob Lowry
    tractorguy, TA DAD and Little Terry like this.
  5. BJR
    BJR
    I have nothing to add, but that sure looks like a gas to drive. :p
  6. jimmy six
    jimmy six
    Look on the Best site. Their 302 head set will have all you need and their intake manifold gasket is better than anyone else’s. A 3-15/16 bore is close to the limit on the later blocks but good on the early ones. If your H head has not been cut too much the compression is pretty good. I’ve used Venolia pistons that look like those on a head with .100” cut off. The H head accepts 1.94-1.60 Chevrolet valves with ease. I’ve also gone to head studs from ARP. They don’t list them but you can buy them by length.
    Looks like a lot of fun.
  7. Gofannon
    Gofannon
  8. Moriarity
    Moriarity
    SUPER MODERATOR
    Little Terry likes this.
  9. Beanscoot
    Beanscoot
    The Rockauto Felpro gasket is on Wholesaler Closeout, so might be gone soon.
    They are cheap enough, at £10.02 each, but an additional £30 for shipping & fees. However it's the same shipping cost for three of them, you could order a lifetime supply!
    Bob Lowry, Little Terry and Moriarity like this.
  10. Little Terry
    Little Terry
    Thanks guys. Roy at Best Gaskets and Bob at Marx Parts have been really helpful and I think I am now sorted.
    Here is a short video from when we got the car started a couple of weeks ago.
    Jet96, Garpo, 302GMC and 7 others like this.
  11. Gofannon
    Gofannon
    Is this the same car?
    Jet96 and Little Terry like this.
  12. Beanscoot
    Beanscoot
    Since this thread has been revived, I checked Rockauto again.
    They have the gasket back in stock, but now it's £25.65! Two and a half times as expensive.
    It's .058 to .068 ins. thick, so nominally 1/16.
  13. jimmy six
    jimmy six
    Everything is up. Bests are still the best especially if you’ve added compression.
  14. Little Terry
    Little Terry
    It's not - the frame and axles are different a**** other things. Thanks for sharing it though.
    LT
    Gofannon likes this.
  15. Mr48chev
    Good news, I figured out years ago that If you ask the manufacture who to buy a part from when they won't sell direct to a retail customer (I have no issue with that) that you normally get the sales outlet that they are comfortable in dealing with. Sometimes it takes a couple of steps because there may be a distributor in the middle.
    The car sounds great, glad you got it all sorted out.
  16. Little Terry
    Little Terry
