Hot Rods 57 FORD Build #2... Glutton for Punishment.
Discussion in 'The Hokey Ass Message Board' started by Jeff Norwell, Oct 20, 2021.
  1. 34fordjay
    34fordjay
    from Mass USA
    Baumi likes this.
  2. 34fordjay
    34fordjay
    from Mass USA
    Jeff
    Those brackets are just plain beautiful. You are going to have a lot of fun driving this car.
    Jay
    Baumi, loudbang and Jeff Norwell like this.
  3. what condition is your hood and fenders on your 57? any patching needed, and if so, how would you keep the "old" look like the rest of the car has?
    enloe and Jeff Norwell like this.
  4. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Apologies..I just had been too busy to make any updates, family and work are always first.... but pushing on areas that would seem too trivial to post about....
    The fenders, inner fenders, front valance are all in great shape.. and match the car.
    No work is needed on these fenders(which is totally amazing for anything 57 Ford!)
    I have yet to scrub and clean, then paint the inside of the fenders.... already did that to the inners and cleaned up the valance...
    In any spare time I have had... been mocking up the Alternator... needs some tweaks. but it will work.
  5. RmK57
    RmK57
    Amazing those fenders survived 65 years without rust or a fender bender. Good Stuff!
    Joe Travers, Thor1, Stogy and 2 others like this.
  6. Jeff Norwell
    Jeff Norwell
    MODERATOR
    On hoods and deck lids... I am good.. for some strange reason.. they kept finding me in the last 7 years....
    Piecing together my grill and such in spare time as well.
    Thanks all!
  7. Its funny how my bumper filler panel is in perfect condition, but the panel inbetween the headlight bezels is decently rusty
  8. RmK57
    RmK57
    I'm not sure if it's original or not but my bumper filler panel had a real thick coating of some kind of undercoat that looks like it applied with a broom. It seems like it was put on there to stiffen up or make the panel more rigid.
    Thor1, Stogy, enloe and 2 others like this.
  9. Fitnessguy
    Fitnessguy
  10. Jeff Norwell
    Jeff Norwell
    MODERATOR
    I guess I forgot to mention as well....
    Got my gauge layout done...So I had my talented friend Rob carve out one of the better 57 Gauge inserts.. to accept the awesome gauges I received from @Speed~On ..I am just waiting on the last 2 to arrive....(I used some gauges I had for mock up)
    So, made up the panels and I will engine turn them shortly.... experiments have taken place....
    I really dig this type of work....
    As I have mentioned.. much of this stuff could never be attained with the wonderful help of good friends.
    I had a 57 Meteor glove box door..... and I just love the key logo/art.... these I think are hard to find.. so the Lonesome Texan will have a little Canuck in her.(.... I can't believe I just said that!)
    brEad, pivir123, Marcia and 23 others like this.
  11. hrm2k
    hrm2k
    The dash and gauges are sweet !!!! Impressive
  12. bobss396
    bobss396
    I'm lucky my '59 has very minimal damage to the body. I found a crease in one rear quarter the panel behind the door that had been pulled and filled with bondo... I'm not touching it. Every drain hole in the lower fenders and rockers are clear and open.
    I fixed the front of the hood front inner structure with fibergl*** cloth after I acid dipped the rust out of it. All the ragged stuff I used a cutoff wheel to remove it. It came out nice.
    The back of my front bumper and filler panel were rusty. I wire wheeled them to bare clean metal, gave them a good lacquer thinner wash and a coat of POR15 on the back side of the filler.
    The money side of filler panel I painted with the correct Argent Sliver spray paint. Made by VHT for wheels. I did the same with the back of the bumper. Better than factory.
    Thor1, Spoggie and Jeff Norwell like this.
  13. enloe
    enloe
    from east , tn.
    None of it is too trivial. How we do stuff differs. No matter what the project is we may learn a easier/better way to do something by watching each other.
    The fab and execution of a lot of the details on this car are so cool.
    Keep on keeping on.
  14. Will you be using a solid filler plate for the speaker grate? Or just reinstallig the grate as is?
    lothiandon1940 and Jeff Norwell like this.
  15. Jeff Norwell
    Jeff Norwell
    MODERATOR
    No.I will be using the speaker cover.. it's just off for easier access when wiring.
  16. Jeff Norwell
    Jeff Norwell
    MODERATOR
    A small trivial move forward.....
    got the Alt bracket all lined up and adjusted ...found a 42.5 belt and had to change the top pulley.
    A much larger one from the stash.
    the bracket is a neat piece from a guy named Larry who owns.....
    https://car****.net
    Larry makes stuff for Fords.. real nice guy..... and since my block is an older FE engine.... and was a generator engine, the mounting boss was at the side of the block.. not the front.
    all ended well and moving forward.
    Finished all the fuel lines and now running the brake lines.
    I made the last of my orders and awaiting the final parts to complete.... the Starter, Wildwood master and the PVC unit.
    Anxious to get into the wiring......
  17. John Kostick
    John Kostick
    As an FE guy, lt me say that's a beautiful mill!
  18. 34fordjay
    34fordjay
    from Mass USA
    Jeff
    That is one beautiful alternator bracket.
    However, the FE engine with the Y block color is not fooling me. It's still an FE.
  19. Jeff Norwell
    Jeff Norwell
    MODERATOR
    hahahah.... Oh Jay hahahah..My secret is lost! hahahah
  20. 34fordjay
    34fordjay
    from Mass USA
    Honestly now....... Jeff do you really really think that you could drive that 57 Ford with the nice patina to a car cruise and open the hood with that big disguised FE and p*** it off as a Y block?
    Thor1, Baumi and Jeff Norwell like this.
  21. guthriesmith
    guthriesmith
    Sadly, I would guess he could at most car cruises in today’s world. :rolleyes:
  22. 34fordjay
    34fordjay
    from Mass USA
    I think that I might have to agree with you.
    Baumi, Jeff Norwell and guthriesmith like this.
  23. Jeff Norwell
    Jeff Norwell
    MODERATOR
    What did P.T Barnum say?.....
    hahaha
  24. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Another nice surprise today
    I have mentioned @Speed~On several times and his amazing knowledge and help on getting the proper gauges for this application.... well.. the remainder of the Gauges came and I am more than overjoyed!
    TJ is one heck of a guy and I enjoy supporting Hambers.
    He was patient with me and is a gentleman.
    If your looking for proper SW gauges. he is your man
    I am very stoked.
  25. Texas57
    Texas57
    Very nicely done, Jeff.
  26. Speed~On
    Speed~On
    Thank you for the incredibly kind words, Jeff! You are such a gentleman. It has been a pleasure to work with on the gauges, thank you for the call. It was great to speak. with you. Your project is looking awesome and you're making incredible progress. It's really coming together nicely and I've always been a fan of 57 Fords, they look so tough.
    I've always been a huge fan of your incredible art work. I have numerous pieces in my house and garage. After we spoke on the phone I said to my son, "I was just talking to the guy that painted that piece of art on your bedroom wall". His jaw hit the floor...it was pretty funny.
    Keep rockin on the '57, you're sooo close!!! And the HAMB world wants to see it run!!
    brEad, Algoma56, Fabulous50's and 5 others like this.
  27. Sky Six
    Sky Six
    from Arizona
    Very nice work but I have to say that you are the first person I know that is "anxious to get into the wiring".:)
  28. Jeff Norwell
    Jeff Norwell
    MODERATOR
    hahahahaha… that is funny Dan… but there was a time I was terrified of wiring… but when I did my other 57… ( and asking a lot of questions)… I found it rather enjoyable!
    Ha!
  29. the only thing thats annoying about wiring is diagnosing 65 year old wiring!
    Spoggie, bobss396 and Jeff Norwell like this.
  30. 57 Fargo
    57 Fargo
    I love wiring!!! But I’m weird like that.:)
