Features Coolvairs Lets See Them
Discussion in 'The Hokey Ass Message Board' started by dons t, Jun 19, 2007.
  1. moparboy440
    moparboy440
    from Finland
  2. moparboy440
    moparboy440
    from Finland
  3. blowby
    blowby
    from Nicasio Ca
    *****in'. Plus you'll always know where to park when you pull in. :)
    El Mirage Garage, hrm2k and Moriarity like this.
  4. Sky Six
    Sky Six
    from Arizona
    who gets to sweep the floor?:)
  5. atch
    atch
  6. SAM3 Customs
    SAM3 Customs
    from Michigan
    Now THAT'S a bubbletop!
  7. NASTY 1
    NASTY 1
  8. killbilly
    killbilly
    Cas,you gotta post some pictures on here!
    hrm2k likes this.
  9. NASTY 1
    NASTY 1
    1960 Corvair with 409 Chevrolet in back ,:)
  10. El Mirage Garage
    El Mirage Garage
    Wow. Is that bolted to the original trans-axle?
    hrm2k likes this.
  11. NASTY 1
    NASTY 1
    Yes ,but it is beefed up , no troubles for over 10 years.
  12. Moriarity
    Moriarity
    SUPER MODERATOR
    bchctybob likes this.
  13. El Mirage Garage
    El Mirage Garage
    Amazing!.. I would think that all that cast iron hanging off the back would induce some pretty wicked handling characteristics, making driving fast on twisty roads a real “white knuckle flight “ lol. I love this thing! , even if it’s just for the Shock factor alone. Very cool…
  14. NASTY 1
    NASTY 1
    Rear end is supported by stock 64 Corvair springs, 409 has alloy heads and intake manifold, yes it is a bit scary to drive . :(
    Jet96, bchctybob and El Mirage Garage like this.
  15. El Mirage Garage
    El Mirage Garage
    The ultimate sleeper!! Sure hope you get to go to a Corvair meet, open the hood and piss-off some purists…:)
  16. hrm2k
    hrm2k
    I can not tell you the numbers of hours I have looking at your Corvair. A true grandma car with a healthy teenager kick. So clever !!
  17. moparboy440
    moparboy440
    from Finland
    Happy Easter to all Corvair enthusiasts!
    Jalopy Joker and hrm2k like this.
  18. quick85
    quick85
    It appears that way but I ***ume it's a standard body '65-67.
  19. HOTRODPRIMER
    HOTRODPRIMER
    I had a crazy experience with a 66 Corvair, I was on my way home and it was raining, like most guys I was driving too fast and as I rounded the curve going down hill I tapped the brakes and the rear came around on me and I went off the road into a deep ditch in front of my parent's house, the cars rear end was in the ditch and the headlights were shining straight up in the air, I no more had dropped out of the car into the ditch when my dad rounded the corner.
    He wasn't too pleased with me, he had bought the car just a couple of weeks earlier, fortunately there was very little damage, cost me about 300 bucks. HRP
    Jet96, hrm2k and bchctybob like this.
  20. Mike VV
    Mike VV
    from SoCal
    How...does one "beef up" a Corvair trans-axle ?
    I started a mid-engine Corvair years ago. I wasn't too concerned with the OEM four speed, but one day with the Corvair ring gear in my hand...I thought...no fking way is THIS little thing gonna work !
    I stopped all work and sold the package.
    And this was with an expensive adapter to bolt the engine to the trans-axle, a full roll cage, and a few other tid-bits.
    Mike
  21. pnevells
    pnevells
    This one runs an injected small block in local nostalgia races
    quick85, Jalopy Joker, hrm2k and 3 others like this.
  22. bchctybob
    bchctybob
    If anyone has a Corvair 110 hp 164 engine or cylinder head lying around and can measure the exhaust stub ID, OD and length from the gasket backing ring I would sure appreciate the info. I’ve been wanting to build a slick set of custom headers for my wife’s Corvair for a long time but I was holding off until I found a set of 140 hp heads and built a big bore motor. Well, I don’t think that’s going to happen. I don’t want to tear it apart to measure the exhaust ports, you know how that can lead to it being disabled for an unexpectedly long time. If I have the dimensions I can make the flanges and get everything ready before hand. Thanks in advance.
  23. hrm2k
    hrm2k
    You could give California Corvair Parts a call (909) 287-0741 . I'm sure they could give you that information with no trouble .
    There are several big bore threads on Corvair Forum and Corvair Central.
    Good luck with your project
  24. Jalopy Joker
    Jalopy Joker
  25. Blue One
    Blue One
    from Alberta
    I’m on the search! Does anyone know what became of this awesome car after the p***ing of the owner /creator Jay?
    This needs to be posted again.
    This is one of the neatest Corvairs that you will ever see.
    Jay Eitel's V 12 ' Jaguar' Corvair .
    Read about his background and look at the engineering that went into this.
    I have always thought it was incredible.
    He has p***ed now but what an interesting story.
    http://www.corvaircorsa.com/V-12-01.html
    http://www.curbsidecl***ic.com/blog...rsons-who-made-their-wildest-ideas-come-true/
    http://www.legacy.com/obituaries/sfgate/obituary.aspx?pid=158037672
    All you other Corvair owners can only dream of doing something this neat with your cars.
    This one sets the bar and I can't help but wonder where it is now.
    hrm2k likes this.
  26. bchctybob
    bchctybob
    Another Corvair on par with Eitel’s V12 version is Ray Goulart’s ‘65 Corvair. Yep, that Ray Goulart, of custom Oldsmobile fame. He built a front engined version using the unmentionable L ess drivetrain and I defy anyone to look it over and not think it came from Chevrolet that way. It’s amazing and he did it all himself in his shop in NorCal. It’s dark gray metallic, black interior and all of the finishes and details are GM correct. I may still have some pictures but they were taken in the cramped quarters of the shop where he parks his hot rods. I helped him out with an old Ford steering column and he gave me the drivetrain that came out of the Corvair. He’s in his eighties now but he’s been building amazing, unusual hot rods all these years.
  27. Just on your side issue here with the '53 Buick.. a fella I know recently lost the brakes on his clean original FIFTY-FIVE '88 Olds. Hmm..
    hrm2k likes this.
  28. bchctybob
    bchctybob
    I have to agree with leaving a Corvair a Corvair. The front engine V8 conversions kinda make them more like a conventional car. If I was younger, I would be building a big bore flat six with a belt driven supercharger for the wife’s ‘62 and converting to the later 4 spd and IRS. That would be a fun combination and still keep it all Corvair.
    Weedburner 40 and quick85 like this.
  29. quick85
    quick85
    The same thing happened to a friend in high school. Mind you, it was 1967
    so whichever pre-65 it was it was still a relatively new car. He rolled up the
    bump into the school parking lot and the engine made its escape. I had a '63
    at the time and, fortunately, never had that experience.
    mitch 36, SpeedyAtkins and bchctybob like this.
