Projects New Owner of the 1954 Ford “Mint Julep”
Discussion in 'Traditional Customs' started by HelmuthBrothers, Mar 4, 2022.
  1. chiro
    chiro
    FYI, backfiring through that Holley that's on there is said to blow the power valve out. I'm running dual Holleys on my flatmotor so it was something I was aware of doing research while doing the build. Never had it happen to me but it's a point of information for you. I like my Holleys. They perform well and the only "special" tools you need to work on them is a screwdriver and a Crescent wrench for the power valve. You're changing it out for the Rochester so that's not important but the timing issue must be addressed regardless to get rid of backfiring through the carby. Great looking car. Good luck with it.
    Andy
  2. HelmuthBrothers
    HelmuthBrothers
    from New Jersey
    More progress today. Finished installing the 3” blocks out back, finished the fuel pump hard line, raised the front end 1”, got the steering linkage fully greased and tightened up. Tomorrow we will do an alignment, tweak a few small things and take it for a spin to see how everything is before we park it back in the garage to dig into the motor work.
    F70920E0-776A-4EC8-982C-99613C1E896C.jpeg DA767BFC-581E-460B-8D57-CEC5CB45DA08.jpeg E07FED28-9980-4D01-A447-971FD9650012.jpeg 5032A928-6ADE-42F2-B4D6-9158A2F59084.jpeg DE02E1A3-2D75-405B-BC8C-02105354C113.jpeg BF38B8A1-DAAF-493B-93FE-21EAC02062DA.jpeg CDF91873-EA32-4266-8980-D765CBF16799.jpeg
    OLLIN, Copper Top, 40FORDPU and 17 others like this.
  3. Lone Star Mopar
    Lone Star Mopar
  4. jimmy six
    jimmy six
    Looks good. Remember to lower the headlights before you drive at night.
  5. greaser 35
    greaser 35
    from FRANCE
  6. HelmuthBrothers
    HelmuthBrothers
    from New Jersey
    Wrapped up everything outstanding today and took it down the highway. Steering is back to normal, shift linkage is dialed in, fuel gauge is good to go. Speedometer isn’t working. It makes awful noises when it’s connected so I unhooked it all. Have to figure that out at some point. Car is almost done. Ready or start on the motor next weekend. Recorded a video for instagram that I’ll share a link to which I just posted on YouTube. 9EDDE11A-C678-43EF-9D26-AAFC8B0460E9.jpeg D500EC07-F09D-4344-8EFA-EB2E203AD48E.jpeg 839BBB43-4791-4002-AE3A-CD5BDD8654FD.jpeg 2985D396-DBA9-4D45-838D-8E2FC8A5AD83.jpeg C3DC59DA-B1F7-4FBD-832F-CC82C7F57FBA.jpeg
    https://youtube.com/shorts/oSMF931r0i0?feature=share
    Tim, lurker mick, -Brent- and 12 others like this.
  7. Rand Man
    Rand Man
  8. pprather
    pprather
    UPDATE: Knowledgeable poster below says use white lithium grease.
    Disregard the rest of my post, please.
    The speedo sounds like lubrication problem. Remove inner cable and use a cable lubricant. I think it is graphite based. Should quiet it down.
  9. e1956v
    e1956v
    Alliance Vendor
    Do not use graphite, graphite is a speedometer repairman's best friend. It works its way into the speedometer and causes all kinds of havoc. It is fine for locks and such but not speedometer cables.
    My dad always said " that sh*ts to sell not to use", pull the cable and use white lithium grease. If it still make noise and jumps the speedometer will have to come out and be repaired.
  10. HOTRODPRIMER
    HOTRODPRIMER
    Have owed a couple of '54 Fords I have used Lithium grease for a dry speedometer cable when they are making noise, works great. HRP
  11. HelmuthBrothers
    HelmuthBrothers
    from New Jersey
    C107363A-67FA-4EC5-A10D-7E46E96D3A71.jpeg 4D5BA1C4-F138-43E6-9582-711AA1A699D5.jpeg 8C3D39EE-06AB-4B8A-9B6F-7EA229D7DE6F.jpeg D9B5D700-388C-42DD-A17A-A9E93E63A7EE.jpeg 0623D5DE-16DC-4E52-BEDE-5D2BB7805584.jpeg 0617E40F-2808-4A6A-9476-C35FFAC4C366.jpeg 04BBC893-83E9-4249-9C17-A6637CFBCF3A.jpeg Brought the car back home today from my uncles shop. All 4 of us were able to tackle a big list in a short amount of time. We installed the 57+ distributor into the car with a new set of plugs. The motor runs night and day better now. Didn’t have to mess with the carb at all. The car is nearly 100% ready to cruise now safely. Did an oil change today and was really glad I did. I was able to inspect the PCV / road draft tube / oil catch can situation. The PCV valve was good, the canister had no filter in it and someone hose clamped a plastic catch can to the bottom of the road draft tube. It was disgusting. Cracked and leaking. I put a filter in the canister, cleaned the entire system out and repainted a few things. Now that the car is home I can address a handful of small things. Gotta install a phone charger, fix the p***enger door jam light switch, fix a few interior panels, and start detailing the **** out of the car. Eventually this year I’m going to repaint the motor and detail it up but for now I just wanna put some miles on it. Hopefully bring it to Jalopyrama on May 7th with the family.
    Tim, Sum54ford, lurker mick and 12 others like this.
  12. jimmy six
    jimmy six
    [QUOTEand someone hose clamped a plastic catch can to the bottom of the road draft tube. It was disgusting. Cracked and leaking. I put a filter in the canister, cleaned the entire system out and repainted a few things. [/QUOTE]
    Did you plug the draft tube?
  13. HelmuthBrothers
    HelmuthBrothers
    from New Jersey
    302CC429-0B2F-46C9-8AE4-74BA53AB67AF.jpeg D9BB1064-24CF-4682-84AF-94B98BF8EE9E.jpeg 88C82B90-5F81-4F8A-B9BF-02D0CE7B0FF1.jpeg 1A9C04F6-59D9-4528-A063-B3F4D372C382.jpeg 78C3B94F-745A-42F3-BEBB-F03DA062FD17.jpeg The road draft tube is still open. I’m now realizing that by having an oil filler breather cap and an open road draft tube that one should be closed right? My current setup.
    -Oil filler cap is a breather
    -Carb baseplate has hose going down to the road draft canister filter with an inline PCV valve
    -Road draft tube is still open
  14. jimmy six
    jimmy six
    Sent a message from your inquiry.
    HelmuthBrothers likes this.
  15. Stogy
    Stogy
  16. lothiandon1940
    lothiandon1940
    ......Looking forward to seeing it in person there.:).....Don.
    Stogy and HelmuthBrothers like this.
  17. sunbeam
    sunbeam
    With the pc valve plug the road draft tube . You want the pcv pulling air through the engine. With out filter the pcv could pull air and dirt into the engine
  18. jaracer
    jaracer
    In order for the PCV system to be effective, you need to close off the road draft tube.
  19. HelmuthBrothers
    HelmuthBrothers
    from New Jersey
    I’ve been enjoying the 54 a lot lately. Hit up a few local cruise nights, took some long Sunday drives with it. It’s been running and driving great. Removed the pinstripes on the hood and the “low life” script from the trunk with some oven cleaner. Worked as advertised with no effect to the mint green paint. I dig some of the striping on the car, but I wanted to remove what I wouldn’t have added myself if I had the chance. You’ll see some photos with the script on the trunk and some without.
    749FBDCC-6A8F-40F4-9151-65CFFBC34677.jpeg 0EB0D875-4659-4EBF-9CB7-63E4009FD717.jpeg 4F65F68A-E9DE-420D-A56B-E76175027C9B.jpeg EF0CB978-466E-4CBF-8794-5EC1D8E51521.jpeg F46A233D-7888-44C8-90D1-223F0CD1E829.jpeg 2CCD4383-8390-473E-BE7A-C693E1285346.jpeg 3A31C77F-3ACF-42EC-A29B-047865A4133F.jpeg 2EA81FDE-CC82-44B0-80B2-3B44AFD57085.jpeg 20F3574F-4019-4331-A2D9-2E98028ACC8E.jpeg 494358C6-FBBD-4B7A-BAA2-4CBB064F64FF.jpeg
  20. loveoftiki
    loveoftiki
    from Livonia,Mi
    Looks great without the stripes and the name..the striped dash looks killer
  21. Positively one of my favorite cars on here!
  22. HelmuthBrothers
    HelmuthBrothers
    from New Jersey
    No major updates with the Vicky. Just driving it and enjoying it! Swapped out the Summit Racing gauges under the dash for SW. Num Nub made me a set of acrylic glow in the dark shift and blinker knobs. Glow in the dark photo posted down below haha. Hope to drive it out to Good Guys Columbus in early July if we get enough people to go. Lately I've been considering getting a set of 53 Caddy flying saucer caps to have an additional hub cap option. Love the sombreros and wouldn't sell them, but I think a set of 53 caps would still look good on the car. I looked up more info on getting the 53 caps to fit a 15" ford rim, but I'm trying to find better photos of the process. Does anyone have any posts or photos on modifying them? I'd like to see how they're changed up to fit a 15" Ford rim. Or does anyone have a set for sale?
    Screen Shot 2022-06-20 at 9.04.00 AM.png IMG_1245.jpeg 289629038_735736860904609_4710822052423577570_n.jpeg 289172744_1197795964340447_7072707255473180321_n.jpeg 288639261_419940536797263_8016754988678598125_n.jpeg 288399725_5154401871311436_167016365603292252_n.jpeg 289160071_1642832232758520_3240556115447642659_n.jpeg 288954517_602075257732523_3180008779063489020_n.jpeg 288461823_1795443777465282_566390657574700498_n.jpeg 288237639_750279049719980_6171839142848942533_n.jpeg 288917155_356400579950210_574118261200685766_n.jpeg 288809054_368796991907177_3801266250552616565_n.jpeg 288537489_1897185257336262_6430080820710951972_n.jpeg
  23. deucetruck
    deucetruck
    from Missouri
    Awesome car! Thanks for sharing the pictures.
  24. alchemy
    alchemy
    How does the glow in the dark knob work? Small bulb inside? Uranium? Magic?
  25. HelmuthBrothers
    HelmuthBrothers
    from New Jersey
    Apparently Num Nub had it blessed by a local wizard. Pretty nuts.
    lothiandon1940 likes this.
  26. 57JoeFoMoPar
    57JoeFoMoPar
    Glad to see this awesome car out and about. I saw some of the pics from the Asbury Circuit that Rob posted, love seeing cool customs out on the prowl. Hope to see it in person soon
  27. axle
    axle
    from Drag City
    MY OLD CAR !!!! It's lookin a lot better. That stance is back to the way I had it. Dang, I wish the previous guys didn't pinstripe all over it. Still, its a nice car ;-)
  28. HelmuthBrothers
    HelmuthBrothers
    from New Jersey
    Thanks! I removed most of the striping that I wasn't a fan of. I think I'll eventually remove more but for now I'm cool with what it has. Didn't want to push my luck with that oven cleaner lol.
  29. patterg2003
    patterg2003
    Your car is pure cl***. Congrats on having such a beauty.
  30. junkman8888
    junkman8888
    Please, please, please, throw away that plastic fuel filter and replace it with a steel one. The gas available today is formulated with chemicals that make the plastic used in those filters to turn brittle and crack, great way to burn a car to the ground.
