Hot Rods Homogenized ‘28 roadster build
Discussion in 'The Hokey Ass Message Board' started by Anderson, Oct 24, 2021.
  1. Tim
    Tim
    from KCMO
    Saw this and thought it felt appropriate for this thread E89972D5-6FDC-44E9-99ED-AAC82DFE8A60.jpeg
  2. Anderson
    Anderson
    It’s been a minute and while I’d like to report that a lot has been done, the reality is that I haven’t done anything! Went to the roadster show, then came upon an o/t project at a local estate sale that I just had to have, both things which kept my finances and attention occupied.
    But now, again, it’s roadster time. As cool as the old batwings were, I didn’t like the fact that they were cast and I also didn’t like that they centered the hairpin on the axle. The hairpin looked like it was heading too downhill towards the front. So I got these from Speedway which are forged and raise the front. They are for a 2-1/4” axle so I dug around in my magic spacer bin and found a couple that were just right. I also didn’t like the kinda rat-rod plate that was welded in the middle of these hairpin, and they were too long overall. So out came the cut-off wheel. I had the right tap for the tubing ends but it is just too dull, so that is where I stopped today.
    I did get a Zoops water pump setup and a radiator. Of course now I’m not sure I need the water pump raised after all. Might order a cheap-o short SBC pump and see where it lands. The fan is early small block but that’s all I’m certain of. The radiator is a Champion 2-row core because they do not have any 3-rows currently. I’m not impressed with the quality and really would prefer a 3-row core, but as cheap as it was it’ll do for now.
    BBC67193-ABAE-4DE1-9B05-5FDF938DEE87.jpeg E279D527-7BB5-4F0D-A7DC-8A9F395688AE.jpeg
  3. 1-SHOT
    1-SHOT
    from Denton
    I like where you are going with this.
    Stogy, loudbang, TomT and 1 other person like this.
  4. Anderson
    Anderson
    I should have just bought my own tubing and made the hairpins from scratch as that’s really what happened in the end, but oh well. Some shortening of the top bar and a new bend on the lower one makes them much more like what I had in mind. I also got the new radiator fit and notched the sides of the grill shell 1”. I think it’s just about right. The M&H Racemasters keep being back ordered longer and longer, so that’s been cancelled and a pair of Towel City pie crusts have been ordered.
    C37CB6D6-9C05-40B4-A395-7C32AB24C309.jpeg 6A78A291-83B9-43E1-ACB1-0A2AFA86BA6C.jpeg 8AD9D974-19C6-4EF4-B995-2E47942166E6.jpeg ECCB981C-B901-44F4-84C5-0A5E48C5DDBD.jpeg
  5. Fogger
    Fogger
    I built two cars back in the '60s and both were with hairpins just like your design. Very cl***ic and fit your build. Really like what you're putting together.
    -Brent-, Gotgas, Stogy and 1 other person like this.
  6. CTaulbert
    CTaulbert
    from Detroit
    Hairpins look great!
    What size are Towel City's?
    Stogy likes this.
  7. Anderson
    Anderson
    Thanks Cory!
    All their 15” slicks are 28.5” tall, except for a 10” wide one that is available in 29.5”. But I want to run my 7” wheel so went with their narrowest, the 8.00-15.
    The M&H’s were 29.5”. I think it’ll look fine on an A.
    Stogy likes this.
  8. 1-SHOT
    1-SHOT
    from Denton
    I like your tubing bender, very creative. Frank
  9. Dan Hay
    Dan Hay
    That tubing bender is legit. The 1" drop of the grille shell is dramatic and spot on!
    Stogy likes this.
  10. Squablow
    Squablow
    Add me to the list of guys who like that caveman tubing bender setup. I am definitely going to remember that.
    Stogy, Anderson and Dan Hay like this.
  11. If I haven't said it, you car is the perfect simple solution to hit an era! No weird geegaws, bracket of the day etc
  12. Anderson
    Anderson
    it wasn’t perfect but the job got done! Those original Buick hubs were good for something after all.
    dana barlow and Stogy like this.
  13. Anderson
    Anderson
    Thanks T! Some builds need to have a lot of churched up brackets and some builds don’t. It’s important to know which is which!
    dana barlow and bondojunkie like this.
  14. 1-SHOT
    1-SHOT
    from Denton
    that's the way we built them in the 50's before 1-800-HOT-RODS
  15. And you got this!
    Anderson likes this.
  16. 1-SHOT
    1-SHOT
    from Denton
    Screen Shot 2022-03-20 at 7.27.39 PM.png we should have bought filler last week
  17. Anderson
    Anderson
    Man…I’m tired. I know a lot of y’all have more years on me but I can’t turn these things out like I used to. And while it used to be fun to get a car done on a deadline for a show, it’s become stressful now. After a week at work, I don’t usually have the energy to put in even a full day on the weekend in the garage. I managed to really hurt my back for the first time doing something last weekend. This stuff just keeps getting more expensive too. I don’t have kids or anything as a reason, but I do have a house that needs work and other expenses that call my attention. Plus a bad habit of collecting stuff. So yeah, this one isn’t going to make the Gathering this year but I hope they’ll let me bring the ‘57.
    Anyway, messed around some today. Fit the radiator support rods so I could get rid of the welding wire holding it up. Moved the engine around a little and the fuel pump fits…just have to notch the frame mount a bit to get a hose on it. It’s a Carter M4503. I’ll probably make some thicker spacers for between the Hurst mount the the block to better center it on the frame mounts too. Messed with some shock mount stuff and have an idea of where they’ll go. Going to bend some F1 mounts around to work. Set all the junk back on the engine cause I like looking at it.
    74ED0C46-23BD-406F-A404-1AAED8D5E324.jpeg AFE2929A-CB0B-4285-8E7A-0155CF73D195.jpeg 30AF4FC4-4BE2-410C-8ECB-45CFD045E679.jpeg 483BA56B-A0BE-4F43-837B-0D4047BEE3C7.jpeg
  18. Dan Hay
    Dan Hay
    I feel like as soon as I put a deadline on myself it's no longer fun and I start making mistakes. I build my cars one hour at a time and occasionally put in a full day. Slow is pro... I just made that up but I'm sticking to it!
  19. alchemy
    alchemy
    I am currently building some Heddman style hedders for my Dad’s car. I like your originals. Dad doesn’t really like the square flanges, but he’s letting me do it anyway. Hope they’ll be as nice as yours.
    Tim, Jim Bouchard and Anderson like this.
  20. Anderson
    Anderson
    I’d like to see those!
    I am actually intending to build another set of headers…they will still be Hedman inspired but I have big plans. I’m waiting on the new flanges to be cut now.
    Jim Bouchard likes this.
  21. Anderson
    Anderson
  22. 1-SHOT
    1-SHOT
    from Denton
    My original Hurst mount came with two spacers, still have them after 60 years
  23. 101Scout
    101Scout
    Beautiful car man! The fab work and style going into this are fantastic. I hope mine comes out half as well. Keep up the good work, love it!
  24. Anderson
    Anderson
    We have rear tires! And finally a roller. Keep in mind that the back half of the car is just mocked up junk, but it’s so good to get to stand back and check out what’s happening here. Sorry about the late models.
    635BC2C9-AA32-47CD-A4E3-DE5BC941DB86.jpeg 65B1F7C0-7B44-4236-AF54-4AB39D3E105C.jpeg 8A64A3F6-996D-4D4C-AAA5-E1BCCA7DC2EE.jpeg 9B8ED7AA-468A-49E3-889A-90796D8B27A3.jpeg
  25. Anderson
    Anderson
    Don’t mind the crooked…everything.
  26. 1-SHOT
    1-SHOT
    from Denton
    How are your doors ?
  27. Anderson
    Anderson
    Doors are in pretty good shape.
    Tim likes this.
  28. Tim
    Tim
    from KCMO
    Looks fantastic!
    if they don’t let the 57’ in drive it anyways and park with the rest of us at “the gathering in the lot” haha
    Dan Hay, Anderson and Tman like this.
  29. Looks ****ing killer man...
    -Brent-, Jim Bouchard and Anderson like this.
  30. Anderson
    Anderson
    Absolutely nothing to update except here’s another picture…
