Technical 350 crate pushrods
Discussion in 'The Hokey Ass Message Board' started by Dino 64, Mar 18, 2022.
  1. oj
    oj
    Thats a lot of abuse, since the intake is off how about pulling the lifter for a looksee at it and the cam lobe. Odd that the pushrod broke and in more than 1 place. All this from a screw holding a breather, is it a stamped steel cover that would flex or a cast aluminum thats more rigid?
  2. Dino 64
    Dino 64
    from Virginia
    Thanks Oj, it’s aluminum cast. Changing all the pushrods with ones I got from you. Don’t trust them now. I’ll take a look at the cam too ;)
    oj and lothiandon1940 like this.
  3. ThisOneGoesTo11
    ThisOneGoesTo11
    from Oxford, PA
    That push rod looks like it has been through a garbage disposal. Stuck valve?
    sunbeam and Dino 64 like this.
  4. jbon64
    jbon64
    dang it .....havent been on the HAMB for a few days and i see this . i feel bad , i could'a fed ex'd a box of pushrods for you to sort thru.
    mad mikey, lothiandon1940 and Dino 64 like this.
  5. Dino 64
    Dino 64
    from Virginia
    Read the first post
  6. Dino 64
    Dino 64
    from Virginia
    Thanks Jeff, I’m good :);)
    mad mikey and lothiandon1940 like this.
  7. Dino 64
    Dino 64
    from Virginia
    Update, pulled the lifter, looks fine. Looked with a flashlight at the cam, it looked fine as well. Dressed the end of the valve as well. Intake is reinstalled, torqued. Thanks everyone for your advice, pretty straightforward from here :)
  8. B.A.KING
    B.A.KING
    Sorry to hijack your thread, but you were lucky! but how long you had that 290 hp crate motor? I cant find one anywhere. anyway keep us posted!
    Dino 64 likes this.
  9. Dino 64
    Dino 64
    from Virginia
    I’ve had for about 5 years but just got the coupe running last summer. Has about 500 miles on it. Don’t think Chevy is selling these anymore
    lothiandon1940 likes this.
  10. B.A.KING
    B.A.KING
    I think you are right. Thanks for the reply . good luck with motor!!
    Dino 64 likes this.
  11. 2OLD2FAST
    2OLD2FAST
    from illinois
  12. Don't feel bad, I have a 330hp 350 still attached to the skid, been there for quite a long time(+10 years?)
    I turn it over every month so that the rings don't get stuck.
  13. Dino 64
    Dino 64
    from Virginia
    So I reinstalled all new pushrods and adjusted the lash. Distributor is in, just the carb and fluids
  14. Harv
    Harv
    from Sydney
    I was thinking the same thing. Have seen plenty of bent pushrods, but have not seen one snap like that in two places. Looks like a brittle failure. I guess those pushrods are hardened and perhaps not tempered as much as the ones I use.
    Cheers,
    Harv
  15. Dino 64
    Dino 64
    from Virginia
    Yeah Harv ! That’s why I replaced all of them.
  16. Dino 64
    Dino 64
    from Virginia
    Don’t think I mentioned a bracket, but it was the head of the machine screw holding the breather. C4126A9E-08C3-4D08-BAC6-E27F5C37B0EA.jpeg 6E055154-5B89-4A64-A1C3-6A372EE4B7F9.jpeg
  17. alanp561
    alanp561
    Why, I believe a Good Welder could fix that pushrod for you in a couple of minutes and probably wouldn't charge you much either. ;)
  18. jimmy six
    jimmy six
    Bad luck, or thought there was enough clearance. A flat head machine screw with and sunken Allen head would have made it I guess.
  19. Dino 64
    Dino 64
    from Virginia
    I was fixing something that wasn’t broken, there was really no need for the lock washer I added over the winter that pushed the head into harms way. It wasn’t even loose !! :rolleyes:
  20. ClayMart
    ClayMart
    Sure. But then you'd have to re-balance the rest of the pushrods.
    :eek:
    So . . . there's that.
    :rolleyes:
    Budget36, Dino 64 and alanp561 like this.
  21. alanp561
    alanp561
    o_O After I got done with the grinder, you wouldn't be able to tell the one I welded up from any of the rest.;)
    lothiandon1940, Budget36 and ClayMart like this.
  22. B.A.KING
    B.A.KING
  23. B.A.KING
    B.A.KING
  24. sunbeam
    sunbeam
    Are the valve covers like stockers that have a right side up?
  25. Dino 64
    Dino 64
    from Virginia
    They have the Edelbrock name on them, so they are mounted with that right side up
    mad mikey likes this.
  26. Dino 64
    Dino 64
    from Virginia
    Update, replaced all the pushrods and adjusted all the valves. Put everything back together and it fired right up :):).
    Thanks everyone for your help
    Just wanted to tie this up and not leave loose ends !
  27. lothiandon1940
    lothiandon1940
    Excellent!
    Dino 64 likes this.
  28. Dino 64
    Dino 64
    from Virginia
    Thanks Don ! Jalopyrama or bust !!
