Technical Almost 100 Years Later, and No Reproduction Model A Dash/Gas Tank...
Discussion in 'The Hokey Ass Message Board' started by Scotch Buzzard King, Mar 20, 2022.
  1. Why? The market is flooded with cheap Chinese reproductions for everything (including gas tanks for everything), but no one is reproducing the dash/gas tank for all Model A's. I figured we would have had one by now. It would make life much easier. I don't want to restore an original where I face destroying my engine if the fuel filter (cheap Chinese junk) gives way.
    I don't know. Maybe I'm in the minority. Does anybody else wonder why we don't have a reproduction tank yet?
    46international and Chucky like this.
  2. Beanscoot
    Beanscoot
    Yep, it's time for a cheap Chinese piece of junk to come on the market!:p
    49ratfink and Desoto291Hemi like this.
  3. Wouldn't fit anyway . Leaks , metric threads etc
    49ratfink and stillrunners like this.
  4. Still better than rust...
  5. woodiewagon46
    woodiewagon46
    from New York
    If you take a good look at Model A gas tank's, they are fairly complex to build, especially the '28-'29. It was OK for Ford to tool up because he built over 5 million of them. A small production run wouldn't be very cost effective. I once read that the gas tank was the most expensive part to fabricate on the entire Model A.
  6. hotrodjack33
    hotrodjack33
    I think I would have trouble trusting some ****py Chinese container full of fuel sitting over my lap:eek:
  7. I was thinking about that earlier. Edsel Ford designed the Model A, and he designed it in such a way that a Model A will only work with a Model A (unless its heavily modified). They sold millions of Model As, but Henry killed them after only 4 years of production.
    The V8 Fords from 1932-48 became more interchange-friendly. You can take a 59A and install it into a stock 32 Ford ch***is with the right parts. Bolts right in.
    It's kind of funny if you think about it. The Model T was produced from 1908-1927. Henry "gives the keys" to Edsel and cuts production quicker than any other time in the history of Ford up to that point. Complicated family...
    49ratfink likes this.
  8. 5window
    5window
    It's pretty clear that Henry didn't trust and didn't like Edsel-or pretty much anyone else for that matter. Henry only killed the T when he was lsing ground to Chevrolet and others, same with the Model A. The reason there's no repro gas tank for the A is a simple one: the cost of manufacture is too great for the expected Return on Investment. There is not enough demand to warrant the cost of reproduction and you'd likely also need to get a license from ford, adding to the expense.
  9. Truck64
    Truck64
    from Ioway
    Plastics. Think I heard that in a movie once
    Tow Truck Tom and kevinrevin like this.
  10. 327Eric
    327Eric
    The market for restored model As is dying with the men who remember them as used Stickers. I would be surprised to see any new products engineered, as there is not enough volume to make it worthwhile . The pandemic changed a lot of things
    Just Gary and hotrodjack33 like this.
  11. Beanscoot
    Beanscoot
    Yeah, maybe there's more concern about liability with making and selling this sort of a tank.
    Was the tank / cowl ever sold by Ford as a service part?
  12. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Truck64
    "The Graduate"
  13. BamaMav
    BamaMav
    from Berry, AL
    And here I thought the Moon style and the 32 Ford style were considered proper replacement for a A model tank. No other designs needed....
  14. KevKo
    KevKo
    from Motown
    You could try putting your skin in the game.
  15. I like the 32 Ford gas tank. I just don't like what I would have to do to an original Model A frame in order to make it work. I've got a near perfect original frame that my buddy, kidcampbell71, brought me a few years back. I don't want to cut it up.
    There are no really good solutions as to a replacement tank for the Model A. I mean they all work, but I'm looking at twenty years down the line.
    The only real solution is a 32 Ford tank because replacements (more than likely) will still be made. I'm probably going to have to go with a different frame if I go with a 32 Ford gas tank.
    I'll end up going with the Boling Brothers frame since it will be easier to mount the 32 Ford rear frame rails to this frame:
    Instead of to this frame (not my frame):
  16. HOTRODPRIMER
    HOTRODPRIMER
    Ford built almost 5 million Model A's verse's 275,ooo Deuces, with as many Model A's still out there there has to be thousands of good tanks left, they were well built.
    I have been able to locate a lot of good 32 tanks and a lot of tanks that need work, as luck would have it we have a great old school radiator shop here in town that knows what he is doing and has repaired a lot of gas tanks for local restorers and hot rodders.
    I would think that the demand for a original Model A gas tank has not been enough for any manufacture to start reproducing it. HRP
  17. 5window
    5window
    Thank goodness for "Luke". :)
  18. IIRC, there were 1930-31 reproduction gas tanks advertised in Hemmings back in the early 1960's.
  19. HOTRODPRIMER
    HOTRODPRIMER
    Faux pas on my part, it should have said luck not luke. :rolleyes: HRP
    5window likes this.
  20. That's awesome! Imagine how much one of those would sell for if you could prove it was one of theirs. I dig it.
  21. 5window
    5window
    Luck is fickle, but you can always count on Luke. :)
  22. 49ratfink
    49ratfink
    if there was an A gas tank made it would be like every other repop body panel and not fit for ****. why would anyone want that?
  23. 31Apickup
    31Apickup
    Just as Hotrod primer mention, about 5 million model A’s built, and a lot around along with parts. A lot of hot rods cut the tank out. The demand isn’t there to reproduce, in fact I have a really nice 30-31 one sitting here. Brookville makes just the upper part. To repro a full tank with dash, I’m guessing they’d retail for at least $1,200 due to the complexity.
    KevKo likes this.
  24. KevKo
    KevKo
    from Motown
    Yeah but then we could ***** about the price of repro parts!
  25. I'm dumb enough to pay it too...
    Beanscoot likes this.
  26. low down A
    low down A
    i would be interested in knowing how you destroy a engine with a pluged fuel filter and then crud would plug a carb and the worst i've ever seen is motor starves for fuel and won't start, nothin a good carb rebuild and fresh filter wouldn't fix but no destroyed engine
  27. I can do it. Don't ask me how, but I can do it...
    low down A likes this.
