Technical ENGINE STORAGE STAND
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Mar 21, 2022.
  1. HOTRODPRIMER
    HOTRODPRIMER
    Some time soon I will be transporting a sbf engine and don't want to use the old tire method of hauling it, last time I hauled a engine in that manor it rolled over.
    Are any of you guys aware of a simple stand that is readily available, possibly a universal or Ford only, I have a regular roll around engine stand but looking for something low without wheels. HRP
    dana barlow likes this.
  2. nochop
    nochop
    from norcal
    dana barlow and alanp561 like this.
  3. KevKo
    KevKo
    from Motown
    I have one like nochop showed. Strapped down in the bed it never moved.
  4. squirrel
    just kind of difficult to bolt the Ford engine to it.
    I've made them out of s**** lumber too....supports the oil pan rail. A few pieces of 2x8 or 2x10 lumber, one under each rail, and something across both ends, is all you need.
  5. Andy
    Andy
  6. 57 Fargo
    57 Fargo
    Another vote for the s**** lumber, my go to as well
    bchctybob, egads and VANDENPLAS like this.
  7. ekimneirbo
    ekimneirbo
    Pretty much anything you cobble up won't really be much better than a good deep old tire. Yes you can make a wooden stand that sits low and surrounds the oil pan, and many engines have been successfully transported that way. The key is to strap it to the four corners of the bed with some good ratchet straps. Then it doesn't matter if you use a tire or a neat little fabricated wooden stand.
    (Have you priced any wood lately?) Those $10 stands ain't $10 anymore. Probably $40 to build one right now.
    The problem with transporting is that the engines are all naturally "top heavy", and the straps are the only way to insure they don't flip over. Had a guy come buy an engine from me a long time ago. Told me he was an engineer:cool:........but he was still a nice guy:p
    Anyway I gave him an old tire since he had brought nothing to sit the engine in. Then he reached into his truck and came back with 4 bungee cords. He was going to hook a bungee cord to each corner of his truck bed to restrain the engine from moving.............:rolleyes:
    I gave him some old rope I had on hand.;)
  8. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Straps help a lot when using an old tire. Just saying
  9. patterg2003
    patterg2003
    Like Squirrel and others. We built one out of wood with some 6x6 blocking. If you are using wood for a longer term then stay away from pressure treated as it will corrode metal. The engine rested on the pan rails and needed a couple notches and a cheap set of casters for rolling it around. The engine travelled along with an old car about 1100 miles in a trailer with no issues. I built a plywood box, recycled the casters on it and lined the box with heavy poly. We used the engine lift and put the engine with the wood supports in the box. I got a gallon jar of silica gel used for drying flowers and put the silica gel tied up in old nylons in different places on the engine to grab any moisture then sealed the poly up and put a plywood lid on the box. We did the same storage method for an airplane engine and it stayed sealed for about 6 years. The silica gel turns a color when it is wet and can be dried in an oven endlessly. When we opened the airplane engine the silica jet had stayed dry and the engine was the same condition as the day we put it away. The engine curretly in the box now is a Chevy 350 and was put there in 7 years ago.
    ekimneirbo, tractorguy and egads like this.
  10. I have one of those. Wheels off I hauled my 348 around under my topper for months before I was ready to machine it. Great weight for winter driving
    nochop likes this.
  11. I have one made out of lumber for my 6. Pan rails rest on it. works well.
    egads likes this.
  12. nochop
    nochop
    from norcal
    Pure Dakota solution to traction issues….I’m originally from Hudson….
    tractorguy likes this.
  13. Thanks!
  14. BamaMav
    BamaMav
    from Berry, AL
    Buddy of mine bought a SBC that came on a cut down grocery cart. Was held down with two 1" ratchet straps.
    54EARL likes this.
  15. Nailhead Jason
    Nailhead Jason
    go to your local Chevy or ford dealer and look by their dumpsters, I have ******ed several crates from new motors being installed in the shop and the crates are then tossed out, as the old motors were put into the s**** pile. I usually have 3 or 4 laying around. the crates are made so that they just sit right on the pan rails and usually still have some strapping bolted to them to bolt the engine to the crate.
  16. Atwater Mike
    Atwater Mike
    Ha...Yeah, the old Grocery Cart trick! (Santa Clara, 1959: The Safeway carts were best...Flash chrome lasted for decades.
    SBCs were like flatheads to haul: Never less than three, keeps 'em from rollin' around!:eek::D
    Hemis were profoundly top heavy, (AND heavy! 760 lbs.) I cut some 4X4 posts into 22" (iirc) lengths, and strapped them upright under the heads, alongside the pan. Like 'stilts'. Moved 5 or 6 like that, same blocks.
    Pan rail 2" X 12"s are excellent, long as you 'box' them or ratchet strap them.
    I also have some I made from hospital bed angle iron and rectang tube, plug-in casters for rolling, unplug for pickup bed.
    Lots of options and opinions.
  17. oldiron 440
    oldiron 440
    I will not strap down 500 lbs of iron with out using 2” straps. **** happens at least in my life so I want that clump not moving no matter what happens! I want it to be in the bed of the truck even if the rig is up side down after a wreck. A tire works just fine as padding or a skid resister but straps hold it in place.
  18. squirrel
    there's nothing in the bed of my truck that's stronger than a 1" ratchet strap, to attach the heavy straps to....
    :rolleyes:
  19. Moriarity
    Moriarity
    SUPER MODERATOR
    is it empty of fluids? lay it on its side and 4 corner strap it
  20. HOTRODPRIMER
    HOTRODPRIMER
    It has been painted and ready to be installed. HRP
  21. Moriarity
    Moriarity
    SUPER MODERATOR
    attach some blocks to a pallet so they hug the pan rail. strap the engine to the pallet and set the pallet in the back of the truck....
    egads and Tman like this.
  22. oldiron 440
    oldiron 440
    I realized that after I posted that most truck beds are not made for heavy work. I have been using my car trailer for over thirty years for hailing motors. One thing nice about using a trailer is you can hall the stand and cheery picker at the same time:)
  23. Bandit Billy
    Bandit Billy
    I have one of those steel motor stands with the adjustable uprights. I removed the wheels and I set in the bed and drop the engine in it.
    Desoto291Hemi and silent rick like this.
  24. KevKo
    KevKo
    from Motown
    I also like to keep weight at the front of the bed rather than the rear, just in case something happens to the straps. You can decide how hard you take off/accelerate. You can't always decide how hard to brake. Seen a lot of pickups with crunched front bed panels when heavy stuff crashed into it.
    LWEL9226 and Dick Stevens like this.
  25. alchemy
    alchemy
    Put it on the tire in the middle of the bed, then a strap from one corner, a few times around the carb, and attach to the opposite corner. Foolproof.
  26. Budget36
    Budget36
    Are you picking an engine up, or taking one from your place and delivering it?
    If picking one up I see why you’d want some universal that you could ***emble on site.
    The last V8 I transported was on tires, I took my carb plates I use to pull/install engines with. Once bolted to the intake I had the engine on tires as far forward as we could get it, then used 4 straps from the “pull ring” on the plate to the corner ties in the bed. Made it pretty dang secure.
  27. squirrel
    The other stuff fits in my truck...easier than hooking up the trailer. I drive careful with a load in the back of the truck, but you never know what the other guy is gonna do.
    oldiron 440 and Budget36 like this.
  28. SuperWildcat
    SuperWildcat
    Got this one for my 455 and made a similar one for my nailhead.
  29. 40Standard
    40Standard
    from Indy
    I bought an engine stand from Summitt, works great
  30. 38Chevy454
    38Chevy454
    The support under the pan rails is pretty universal. Straps for sure to keep the engine upright and from moving. As mentioned, you can control how fast you accelerate, but not always how fast you need to stop. Ensure that 500-600 lbs of engine does not come sliding forward.
    egads, Just Gary and Dick Stevens like this.
