Hot Rods 29 RPU- "Street/Strip" B/SR Build - Marty Strode
Discussion in 'The Hokey Ass Message Board' started by Marty Strode, Dec 19, 2019.
  1. Marty, that front mount turned out mega nice (as has the rest of the project). You should stamp STRODE where Hurst would be if it were one.
  2. Marty Strode
    Marty Strode
    Mike that's a good idea, perhaps I can have it done with a ball mill, as I am terrible with stamps. Sorry I missed you, looks like you painted the Victoria, did you get it sold ? I will see you at an alley soon. Thanks.
    Tim likes this.
  3. Marty Strode
    Marty Strode
    I am using a Speedway column with a quick disconnect on the wheel, and have mocked it up with 2 different wheels. It can be shortened to suit, once the seat is in place. The good part is, only one u-joint is needed. IMG_8654.JPG IMG_8650.JPG IMG_8651.JPG IMG_8653.JPG IMG_8657.JPG IMG_8658.JPG
  4. No, my Vicky is still Green and Silver resting in the Shop. I was there to sell working out of my closed trailer parked in the same spot on the street by the gate. The B 4-cyl with the Drake head drew quite a collection of comments. I was hoping to make a sale so I never had a chance to walk around inside. Pete came inside and stood next to his little sweetheart for a while. Several asked me why I didn't just bolt it in the 29 Sedan I had on the ramp door for sale. We had some good Chuckles. Sorry I missed you also.
    alanp561, bchctybob, Tman and 3 others like this.
  5. Marty Strode
    Marty Strode
    With the steering temporarily in place, I decided to see what my options were for a seat. I pulled one of the Speedway seats out of the track roadster to get a baseline. As many of you know, the cabs on '29 roadster pickups are quite small, and sitting lower also cramps the issue. Since it will only be a race truck this year, and not on the street, I think I can use a Speedway seat. I had to remove a section of the cross channel, to make room for the shifter. I haven't shifted this 4 speed with a Hurst Super Shifter, since 1975. I had to molest the shift handle back then, to work in my Altered Roadster, with the Boss 302 and center steering. After sitting in the seat today, and reaching for the shifter, it couldn't have been a better fit, even the angle of the "T" handle was set perfect ! I was thinking about buying some plywood for the floor sections, and remembered I had kept the ones out of it. Since the truck was an amateur restoration from 1970, I couldn't believe the quality of the plywood. So, a little t******* around the trans and shifter, and most of the hole is closed. IMG_8665.JPG IMG_8668.JPG IMG_8672.JPG IMG_8674.JPG IMG_8676.JPG IMG_8679.JPG IMG_8680.JPG IMG_8683.JPG
    bchctybob, Tman, bymanr and 11 others like this.
  6. DDDenny
    That's one ugly shift handle Marty............I love it!
  7. Marty Strode
    Marty Strode
    It looks like me !
    lurker mick and Dean Lowe like this.
  8. Marty Strode
    Marty Strode
    In my haste, I didn't take time to wash the boards, so I went out in the dark and cleaned them up. Perfect patina, like the rest of the truck. IMG_8688.JPG
    bchctybob, Just Gary, brEad and 7 others like this.
  9. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    It would be hard to find new plywood like that today!
    Tman likes this.
  10. Marty Strode
    Marty Strode
    I had to pull off the RPU to help a friend with his project. It's an AJ Watson styled machine, for the street. He needed me to mount the nose. It required some tube bending and rolling along with some sheet metal punching, bending, and shrinking. Should be wild to drive ! IMG_8699.JPG IMG_8700.JPG IMG_8702.JPG IMG_8703.JPG IMG_8705.JPG IMG_8706.JPG IMG_8725.JPG IMG_8726.JPG
    bchctybob, Tman, Blues4U and 20 others like this.
  11. redo32
    redo32
    Totally cool.....unHAMB friendly. I love it.
    Stogy and AmishMike like this.
  12. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Oh, My!!!!!
    Stogy likes this.
  13. Marty, it's been a few years since I actually seen Doug Nicoli's project. Is that his? If not a close twin. Doug was building a 2-seater and I think it has individual roll bars at each seat. Can't see that part with the Exhaust there. Maybe 2 guys with similar thoughts in the same neighborhood?
    bchctybob and Stogy like this.
  14. Stan Back
    Stan Back
    Looks like you can get burned getting in either side . . . but sure might be worth it!
    Tman, Stogy and Just Gary like this.
  15. Marty Strode
    Marty Strode
    Mike, it is Doug's project, that he sold to Lonnie, who has been getting it ready for a body. Tom Phillips built the headers, and John Keller did the pipes, with mufflers inside. I think Bill Jwayde and Doug built the ch***is.
    bchctybob, Pist-n-Broke and Stogy like this.
  16. Stogy
    Stogy
    Apart from the modern white letter tires it has an early to mid sixties Indy feel to it.
    Tman and alanp561 like this.
  17. Johnny99
    Johnny99
    So does the blue contraption punch and dimple holes for the DZUS fastener and spring all in one shot?
    Stogy likes this.
  18. Marty Strode
    Marty Strode
    Yes it does, very handy.
    Stogy likes this.
  19. I see Doug often but hadn't heard he sold it off. Your right about Bill being elbow deep in the ch***is. Good to see it moving forward and in very good hands all the way around.
    Stogy likes this.
  20. Johnny99
    Johnny99
    Thanks, now I am jealous! You build it?
    Stogy likes this.
  21. Stogy
    Stogy
    You could do that on a louver press...all you'd need is dies and clearance to install them...
    @Marty Strode, does that actually punch the holes and dimple as well...or do you pre-drill 3 holes then use the dimple die?
  22. Marty Strode
    Marty Strode
    It belonged to my old friend Jerry Hill, who ran a race car shop in Newberg,Or. He specialized in sheet metal, but built many completes with ch***is, like Dragsters and Funny Cars. When he p***ed back in 07, I bought his Louver press and this Whitney-Jenson kick punch, with the Dzus die. It does it in one strike, and is very handy lapping panels, it got a real workout when I built this Lakester ..... IMG_8728.JPG IMG_8729.JPG IMG_8730.JPG IMG_3295.JPG
    bchctybob, stanlow69, brEad and 8 others like this.
  23. Stogy
    Stogy
    Hmmm, maybe not, that machine has some serious strength built into it...I was ***uming...Louver presses punch through similar gage metal though...I'm still curious...
  24. Marty Strode
    Marty Strode
    Stogy, any louver press would do the job with ease, it's having the die set, and having to set it up between both operations. My louver press is 3" solid steel, with hydraulic cylinder from a Republic Aircraft, would do it just fine. IMG_8731.JPG
    bchctybob, Tman, ottoman and 7 others like this.
  25. Marty Strode
    Marty Strode
    Some other good news, when I did the job above, for my friend Lonnie, he gave me this Hilborn -0 fuel pump to serve as a primary or spare for the Roadster Pickup. It's newer than my existing one, so I will ship it to Spud Miller at FIE, to have it checked, and or rebuilt. Nothing like having spare parts. IMG_8732.JPG
    bchctybob, Tman, stanlow69 and 6 others like this.
  26. Stogy
    Stogy
    Thanks Marty, for anyone punching Louvers that might be something they could invest in to diversify there offerings to those looking for such details...
    Pretty cool that that punches 3 holes and dimples all in one...
    My experience in dimpling involved drilling the center hole full size and using a pinned two hole jig to drill the anchor nut rivet holes...then dimpling those rivet holes...it was generally an operation require in thin gauge materials that if countersunk would knife edge and enlarge the rivet bore.
  27. alanp561
    alanp561
    I don't see any voids in that plywood, Marty. Is that marine grade?
    Stogy likes this.
  28. Marty Strode
    Marty Strode
    Alan, I am not up on grades of plywood, but it is better than anything I have seen. IMG_8735.JPG
  29. Stogy
    Stogy
    Marty you had your hand in some really cool projects...that's one I mean two bad boys...but knowing the times helping out at the farm or shop in the dirty thirties, forties and even the 50s being a kid many times was cut short...
  30. Marty Strode
    Marty Strode
    Today I got a house call from a machinist friend, who did the machine work on a 283 for my '40 pickup. He got started on ***embly, got the rotating ***y installed along with the Erson camshaft, now I need a tighter timing chain. It's a simple 65-283, bored .060, with power pack heads, and will get the Edelbrock Tri Power, that is on the engine in the ch***is. That should make a great little package, with the Saginaw 3 speed and column shift. IMG_8736.JPG IMG_8738.JPG IMG_8743.JPG IMG_8747.JPG
    alanp561, bchctybob, rod1 and 12 others like this.
