Technical BUDGET COLUMN DROPS
Discussion in 'The Hokey Ass Message Board' started by topher5150, Mar 24, 2022.
  1. topher5150
    topher5150
    Honestly didn't think about that. Time to make a trip to the hardware store
  2. iwanaflattie
    iwanaflattie
    How bout some 1/8" thick rubber or leather?
    stanlow69 likes this.
  3. Johnny99
    Johnny99
    Budget yes. Timewise no. Made from a chunk of pipe and a shaft collar from a bearing supply house. Going in my Vicky.
  4. Almostdone
    Almostdone
    I modified a Model A drop just like @ClarkH said. Mine was easy to find too, since my car IS a ‘31 Model A.
    John
  5. 28rpu
    28rpu
    A hunk of aluminum and a little machining.
  6. David Gersic
    David Gersic
    from DeKalb, IL
    I’m thinking polish and engine turning.
    Bandit Billy and Just Gary like this.
  7. Marty Strode
    Marty Strode
  8. Johnny99
    Johnny99
    Thanks Marty. And what a cool hauler that COE is. I'm old enough to remember when the COE trucks and old school busses were affordable, now, holy smokes!
  9. Stllrng.
    Stllrng.
    91531DAF-5880-4DBF-BFAC-8A24FB53132E.jpeg This is one I made up myself. I was able to make it exactly to the dimensions I wanted
  10. the37thstreet
    the37thstreet
    Made this one from a block of aluminum then installed vintage temp gauge in it. 2 in drop to a 37 ford steering. Any body ever seen a 7 gauge Hollywood gauge panel ? Picture 096.jpg
    Johnny99, Just Gary and bchctybob like this.
  11. 2OLD2FAST
    2OLD2FAST
    from illinois
    How about stop buying **** & fab your own ?
    chevyfordman likes this.
  12. bchctybob
    bchctybob
    You could always just start welding together some left over 1/8" - 3/16" plate. I wanted this one to look sorta factory/utilitarian since it's a truck. Still needs a little finishing work, but it'll get painted black and blend in with the rest of the stuff.
    chevyfordman and mcsfabrication like this.
  13. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    Cut 1" off a lower radiator hose and put the column rubber mounted... Works like a charm.
    topher5150 likes this.
  14. here is what I have done on the last 3 builds, simple and something I built myself rather than turn a page in a catalog... steering clmn1.jpg steering clmn2.jpg steering clmn4.jpg steering clmn 5.jpg
    Bugguts, D-Russ, caseywheels and 3 others like this.
  15. nobby
    nobby
    mid 60's ford f100 ?
  16. chevyfordman
    chevyfordman
    Get into the mind set of making items instead of buying a catalog item that will need to be modified anyway. In the long run your skills will get better and you will save money and not have a bunch of catalog items to sell or store unused.
    Just Gary likes this.
