Looking to Get Started...
Discussion in 'The Hokey Ass Message Board' started by Tribalmonkey, Dec 14, 2020.
  1. Tribalmonkey
    Tribalmonkey
    Here is my swap meet haul. Stuff I don’t need. Stop sign. Bunch of old hose clamps. Two old headlight switches. 31 gauge cluster. Stewart Warner Amp meter. HAMB topper. Two old 3 bearing banger cams I plan to use as cores. Probably $75 worth of stuff. B13A970D-FAA5-4B22-87AD-0029D8AB2F45.jpeg
  2. Tribalmonkey
    Tribalmonkey
    I should have looked for some old regulators yesterday.
    lothiandon1940 likes this.
  3. Tribalmonkey
    Tribalmonkey
  4. Tribalmonkey
    Tribalmonkey
  5. lothiandon1940
    lothiandon1940
  6. ^^^^ What he said^^^^^^^^^
  7. Tribalmonkey
    Tribalmonkey
    Doing small stuff today. Worked on moving the battery over about half an inch to give more clearance for the 39 ****** mount arms on the bearing retainer. Did a bit more pedal adjusting. Messed with the coolant pet**** valve trying to stop the persistent drip. No luck yet. Also started creating a new ****** cover for the floorboard. The old one doesn’t fit right with the new ****** and emergency brake relocation bracket. 42AC81DE-9EE3-4CB3-A2C2-92CDDA680259.jpeg E1DEB97B-8CD5-4EE9-80F0-438491180680.jpeg
  8. Tribalmonkey
    Tribalmonkey
  9. Tribalmonkey
    Tribalmonkey
    Here are a few pics of some of the shop tools I have made. Noting spectacular here. Just trying to get the job done. Anvil stand, vice stand, belt grinder, brake.
    CDAF1EA6-18CE-40EB-B598-A3EB7286276B.jpeg E8BEF6D6-24E7-4922-A799-36B34D5B6C75.jpeg 3462F8DC-093C-412B-BD86-EAD6261A5167.jpeg 8A041652-95B5-4F88-881B-DF0C6913E5E9.jpeg
  10. Tribalmonkey
    Tribalmonkey
  11. Tribalmonkey
    Tribalmonkey
    Dannerr, drdave and lothiandon1940 like this.
  12. Tribalmonkey
    Tribalmonkey
    Ratty the Rusty Roadster walk around. Running and shifting pretty good. Time to try out the Mallory Dual Point soon.
    Dannerr, vtwhead and lothiandon1940 like this.
  13. Tribalmonkey
    Tribalmonkey
  14. lothiandon1940
    lothiandon1940
    Excellent! Congrats on being accepted, Mark. Should be a fun time.:)
  15. lothiandon1940
    lothiandon1940
  16. Tribalmonkey
    Tribalmonkey
  17. Tribalmonkey
    Tribalmonkey
    First time running Ratty on the old Mallory Dual Point distributor. Runs awesome! I’ve been burning the ‘tire’ (a little bit). Thanks Skip!!!
  18. Tribalmonkey
    Tribalmonkey
  19. ROADSTER1927
    ROADSTER1927
    Looks Great and sounds the Same! Gary:)
    Tribalmonkey and lothiandon1940 like this.
  20. Dustyp489
    Dustyp489
    Glad you could use it, does make much better running and respons
  21. Tribalmonkey
    Tribalmonkey
  22. Tribalmonkey
    Tribalmonkey
  23. Tribalmonkey
    Tribalmonkey
  24. Tribalmonkey
    Tribalmonkey
    First time doing body patching. Poor roadster.
    ACC1CE45-A9A8-49EA-A1C6-D8161E1465D0.jpeg 59860E53-305D-4CB7-B8CC-E6A94DF2EE6E.jpeg CCE4636A-EF07-433E-90DE-42AA5BF50E5A.jpeg
    lothiandon1940 and Dustyp489 like this.
  25. Tribalmonkey
    Tribalmonkey
    Updates on my art project and wheel well patch. 90214FEF-C070-48AC-A7D9-51F6AE478C4A.jpeg 94BAF5BF-8DD0-4565-B0F3-98D8C02BD37A.jpeg
    Dannerr, Dustyp489 and lothiandon1940 like this.
  26. Tribalmonkey
    Tribalmonkey
  27. vtwhead
    vtwhead
    Doesn't look like you had much brake there. What is the plan?
  28. Tribalmonkey
    Tribalmonkey
    I think these are 1940 spindles, backing plates, hubs. I am still collecting parts for my AV8 build. My plan is to send the spindles and king pins to Okie Joe to build me another 4” drop axle with correct camber. I have a 40 rear end with hubs I will rebuild also.
  29. Tribalmonkey
    Tribalmonkey
    This is not what I expected. My wife thinks the 31 roadster is hers now. Makes me nervous.
  30. Tribalmonkey
    Tribalmonkey
    Found a homemade downdraft intake for the roadster. 906A6499-58BA-41EE-AE60-D777E95B490F.jpeg 6B6EFC44-67DD-416A-B4EA-14D35EE00229.jpeg
