Projects 1948 Anglia Southeast Gassers build
Discussion in 'The Hokey Ass Message Board' started by Zak Hall, Nov 14, 2021.
  1. Zak Hall
    Zak Hall
    36E8A5D7-32EE-41E2-985B-45CD6B64D7A3.jpeg B1032B03-37C6-49AA-BC18-9D078BEEBD5A.jpeg AD97EBDB-BB95-4597-9E37-E41A1CA3E7EB.jpeg 67D6D1DE-19FC-402C-AA65-B34AA4B8F90C.jpeg Scaled the Anglia to see where I was currently at weight wise.
    Has a bare iron bbc block, intake, and has heads on it. No internals. All the fibergl*** is laid on it, so the body is complete of sorts. Steering is 100% complete, suspension is 100% complete. Transmission and clutch/pressureplate/flywheel are in it. Rear end is all there except ring and pinion. Brakes are 100% complete except fluid and lines. It doesn’t have tinwork, lexan, battery, wiring, plumbing, engine internals and a gas tank. And no fluids of course
    Guess the current weight?
    EVL401, mad mikey, AHotRod and 3 others like this.
  2. 427 sleeper
    427 sleeper
    1850# give or take 100#
  3. brianf31
    brianf31
  4. lippy
    lippy
    from Ks
  5. Dick Stevens
    Dick Stevens
  6. catdad49
    catdad49
    1560, Glad to see that you're keeping busy!
  7. 1934coupe
    1934coupe
    1432# My MG weighs 1850# race ready.
    Pat
  8. DDDenny
    It's bigger than a breadbox, barely!
    Keep after it Zak.
    mad mikey likes this.
  9. bobss396
    bobss396
  10. Zak Hall
    Zak Hall
    Weight was 1372lb as it sat. Hoping finished turn key it’ll be 1850-1900lb fingers crossed.
  11. Zak Hall
    Zak Hall
    50988BE0-0612-4B82-BD1D-E870F69D3F66.jpeg AA971035-2EB3-4059-B014-5AF77DBAC7AE.jpeg 78A112A1-BC8F-4E29-BB25-EABA290BE3E0.jpeg 71082F80-ADC6-4EFD-91B8-F4A41F9F737F.jpeg 159AFDAB-DDB3-4A8F-B021-F9B925735504.jpeg D42A170E-7237-4038-8ECA-86FE76361308.jpeg 05D9F1EC-A65F-4679-A266-BF59F18D47AD.jpeg 8204D9A3-AD0F-4ECD-AB22-69462E2A4110.jpeg Made some patterns and got the body plates cut and body centered and welded in place, and rear fenders are mounted. Next up is swing the doors and tilt the nose. Then it’s time for body work, and paint. Then tinwork and final ***embly.
    mad mikey, AHotRod, brEad and 13 others like this.
  12. Zak Hall
    Zak Hall
    A0EECB30-203A-4C16-98D2-84FBB2EA8A3E.jpeg B16AEF69-4A81-495F-A25F-BC3B21FBE36B.jpeg Waiting on some tabs so I can tilt the nose on the Anglia, and mount the radiator. Also waiting on hinges and latches from speedway and the body will be pertnear ready for body work and paint.
  13. catdad49
    catdad49
    Comin' along, Zak!
  14. sidevalve8ba
    sidevalve8ba
    Looking good, Zak! I'm glad to see you back at it.
  15. brianf31
    brianf31
    That ought to 60 foot pretty good! Isn't there a 2400 lb minimum?
    Thor1 likes this.
  16. Zak Hall
    Zak Hall
    2200lb in A gas, but with mechanical fuel injection weight break, you can go under that. With the 408” big block and weight breaks, I’ll be 2145lb race weight minimum.
  17. Zak Hall
    Zak Hall
    A4231E65-197A-4DB8-895F-671E4D899C89.jpeg 7B54E2BA-F193-480C-B443-26539550C5FF.jpeg 3E2AEBD0-F1E9-450F-9AE8-F865EE6E7E5B.jpeg 0902F57E-1475-4477-8D1A-9F622FC13B8D.jpeg Did some work to the Anglia today. Worked on the front end and get it mounted and tilting. All that’s left is make some stops for it, notch it for the headers. Then mount and latch the doors and mount the trunk lid and it’s ready to go to paint and body.
    EVL401, mad mikey, verno30 and 15 others like this.
  18. lippy
    lippy
    from Ks
    Your Dad is proud of you Zak. I bet that will be a good ride!!! Lippy
  19. Zak Hall
    Zak Hall
    28D13F70-05F8-4C83-8D73-CF6B84C8B3D3.jpeg 476FF9CB-B166-4598-9EA3-9FBDF7D85922.jpeg 883AC104-E0F2-482D-9141-BD087EEA0209.jpeg Got the doors hinged tonight and they open and close. Gotta get the latches installed and pin the trunk on, and m***age a few things and it’ll be ready to get to paint and body.
    Chucky, Just Gary, AHotRod and 10 others like this.
  20. Zak Hall
    Zak Hall
    8A6FC959-DD26-44E0-B508-D6C590548263.jpeg 68BDA529-6431-4AE1-BDCC-D029751F33A5.jpeg
    Picked up my Gforce and got my mag wheel back from being drilled while at the track this weekend, more Anglia parts!
    Chucky, -Brent-, AHotRod and 10 others like this.
  21. Mike VV
    Mike VV
    from SoCal
    Mine weighed #1865 as I recall, with a small Chevy and T-400 trans., and me in it. Similar body layout. Steel body with fibergl*** bolt on parts.
    Have fun with it, great fun little cars !
    Mike
    EVL401, cooke, Just Gary and 11 others like this.
  22. brianf31
    brianf31
    That scoop goes real well with the shape of the hood.
  23. Mike VV
    Mike VV
    from SoCal
    Yeah, when I built the car, I though...what scoop ? Like everyone else using the more Pro Stock looking scoop, that was/is well rounded, short and fat..!
    I couldn't figure out why I'd put a short, fat scoop on a tall skinny car ?
    So, when I saw this one...I looked no further ! A tall skinny scoop (early F1 style) for a tall skinny car.
    Funny thing... After selling the car, Palmdale Raceway, (SoCal), where this picture was taken, would not let him run the car without (he did get to run it that day though) "shortening" the scoop. They never gave me any h***le at all, in a few years of running the car there. !
    As I recall, he had to section it, five or six inches to make them happy. It still looked..."ok" .
    Mike
  24. cooke
    cooke
    Mike VV- on your Anglia weighing 1865 lbs; was that with a mild steel or CM cage? Also; on your SBC, was that iron or aluminum heads.
    Thanks
  25. Mike VV
    Mike VV
    from SoCal
    Mild steel cage. The cage was VERY minimalistic ! JUST legal, nothing extra ! 2"x3" frame. Again, nothing like todays cars. Just enough to hold things together. It was built by Britting Engineering, back in the late 60's, best I could find out.
    Iron block and heads.
    Olds / Pontiac rear end.
    As weighed, WAY back...at the original Irwindale Raceway.
    Mike
  26. cooke
    cooke
    Sounds alot like the one I'm working one. Thanks for the reply- appreciate your time.
