need suggestions on a 303 olds build please
Discussion in 'The Hokey Ass Message Board' started by 303racer, Aug 24, 2006.
  1. 303racer
    303racer
    I would like to say hello to every one, I am new to this site, what I have seen so far,is amazing all you guys really come tgeather to help out each other, I hope I will be able to help anser some quetions, that may be helpful on this site, I was told that maybe some one here, could help me with my problem, so here it is I have a pile of parts I have been collecting over some time now, parts include 303 olds block weiand drag star 6x2 intake, 97 strombergs, Howard aluminum 303 rods, jahns pistons, and a -ronco magneto, hildebrandt valve covers,and thats about it im trying to stay with all the old scool stuff, I was wondering how I would go about using all this in a combo that would make great horsepower? Still have crank to buy, heads, and other internal/external parts. I was reading that you could take 324 heads, and put them on a 303 to get great power, but don’t know if my intake would still work? i am going to be putting this motor in a 29 roadster. How would you go about building a 303 motor from the ground up ? thanks -Josh
  2. Wasahawaiianrat
    Wasahawaiianrat
    josh welcome to the hamb, you need to make an intro in the right section, blah blah blah, ok now that i got that out the way so you don't get slammed. check out the tech section, look in the olds rocket motor tech and there is a perfect recipe for olds motors in there, cam selection, the best heads you can get etc. try and post some pics of what you have cuz i know us rocketeers would love to see that mag and those halibrand covers! oh and when you need some cash i'll buy both off you!!!!!!!!!! me first!!!!!!!:D welcome to the hamb and good luck with the rocket!. some names to search for that know there stuff on rockets would be yorg and DON WOW. Its all in that tech archive! what trans are you going to run behind it?!
  3. 55olds88
    55olds88
    sounds like a great collection, the manifold will work with 324 heads, check out the tech section..... I have seen some interesting alloy race rods on ebay latley too.
  4. Bobert
    Bobert
    Welcome over here. See you found the HAMB from the OCA board ok.
  5. touchdowntodd
    touchdowntodd
    DAMNIT i want your mag, if u ever wanna switch to dizzy let me know, i want into a mag BAD, dont care about the troubles, i WANT ONE!
  6. 303racer
    303racer
    Sorry about not putting my intro in the right section, i see where i do that now, and i will fill out a little bit about my self there, as for parting with some of my olds stuff im a packrat, so i most likely wont anytime soon,
    as for the trans i think im going to stick with a lasalle, i here they are one of the better trans to go with, but i dont understand ? will they only bolt up to such a year olds ? or would i just be better of to find a interdapt housing to mate the two ? i still have ton's and tons to learn about olds, but im loving every minute of it, I have to thank Bobert for telling me about this site thanks Bob,
  7. Welcome,
    I'll trade you a good crank for the valve covers :)
  8. Dago 88
    Dago 88
    Welcome to the hamb, always good to here from another Rocketeer. Thats an amazing collection of parts you have there, If you can find some 1956 324
    heads, there the ones to use , they have "10" cast on the center exhaust ports. Good luck.
    Cheers Dago :)
  9. yorgatron
    yorgatron
    i'll trade you a crank AND a pair of '56 #10 cylinder heads.
  10. thekid
    thekid
    from PDX
    hey 303 racer.
    i'll keep a look out for your progress, i'm in the same boat.
    i've got a 303 and a la salle too.
    i'm still in the collecting process on the truck it will go in.
    but i've squirreld away some nuts and going to try and find a good place to rebuild the olds soon.
    i just need to get my only car on the damn road first, so i can go chasing parts and the such.
    good luck and keep us posted.
    gary
  11. Chili Phil
    Chili Phil
    Google Gene Adams and follow the trail to his 303 dragster. gene and his brother are nice guys and if you ever get to find them they will answer allyour questions. Use the Rocketeer archives herein too. And welcome.
  12. Chili Phil
    Chili Phil
    And when Don_Wow chimes LISTEN to his advice. He is the MAN on these engines.
  13. VikingHotRods
    VikingHotRods
