I've seen a lot of engines but can't say I've seen this strange byp*** before. It's a 66 or 68 327 220hp, 4 barrel, manual trans, according to the suffix code. What's the deal with it, what application would've it been used in ?
That's an odd duck alright. Strange looking "327" label on those smooth v/covers too. You thinking light duty truck or something more like a 40, 50 or 60 series medium duty?
yeah that had to be out of a larger truck. You could look at the intake casting number to kind of figure out more I would think. Is that riser part of the intake or like a bolt on spacer then the thermostat housing bolts to it? Where the byp*** would usually go is where the alternator bracket is bolted. Is that a special plug there or is it sealed off the water p***age? It is an odd one for sure.
My 66 C10 had that,identical 4 barrel engine, except it had script valve covers, the "High Torque 327" sticker, and was Detroit diesel green from the factory.
Chevy put an external byp*** hose on the six and small block V8s, when used in trucks, to help prevent hot spots in the engine. If you're using the engine in something besides a truck, then you can do away with it.
Chevy truck brochure says the byp*** is to provide quick warmup for maximum efficiency….I was taught it’s to prevent hot spots during warm when drivers apply a heavy engine loading before it’s fully warmed up..
I used to work with a guy that said his 327 block did not have the drilled byp*** behind the p*** side of the water pump. Would it be one of these? His must have been a large journal because he said the 327 crank was bad so he put a 350 crank in it, with 350 pistons. Gary
Back in the day, replacement water pumps used to come with a small plug to block off the byp*** between the block and the pump when using that byp*** on large trucks. Don't remember too many of them being installed.
I have the 1969 Chevy truck parts book for light and medium duty trucks, YS is listed as a 327 in a C10-20-30 for several years. Not in the 1-1/2 ton or larger trucks at all, though.
Engines built for torque produce maximum torque at low rpm, where it's needed; for that reason, you don't see 4-barrel carburetors on high-torque, low-rpm engines. Vehicles equipped with such engines also are geared for hauling and use the low rpm torque to their advantage. A good example is the GMC V6 engine, which was not equipped with a 4-barrel carburetor.
My 2 pesos........ Truck cams engineered for a fat torque curve (aka: flat torque curve) are appreciated in boat engines, turbocharged engines, and by people who enjoy snappy, peppy, responsive rides on "cruise night". They have their niche in the hot rod community.
Funny... I seem to remember Holley 4bbl carb's on 366 & 427 truck engine's - factory equipped. Didn't rev real high and pretty torquey.
High Perf. Small block's with aluminum intake's had the byp*** like that. Cast iron intake's didn't, they had the thermostat housing byp***... on some truck's, p***enger car's didn't.
Ford used/uses a byp*** in everything that I know of, water neck and heater lines. I figure that large by p*** was used when the radiator wasn't really needed like in a school bus that needed engine heat for the heaters in the p***enger area, maybe even had a two stage thermostat.
