Hot Rods Dual M/C for 64 F100
Discussion in 'The Hokey Ass Message Board' started by MeanGene427, Mar 31, 2022.
  1. MeanGene427
    MeanGene427
    from Napa
    Anyone done this swap and can provide what M/C works well? 64 F100 shortbed with the original drums- brakes work fine, just looking for a dual pot for safety. It has a fresh single pot on it, but you know... I'm thinking maybe 67-70 Mustang drum/drum, or ?
  2. The mustang and the F100 both have a 1 inch bore so it should work OK. Check and make sure you can get full stroke on the master cylinder though. If you do loose pressure on the front or back at some point, without full stroke you may not have braking power on the other end.
    Big mike 1968 likes this.
  3. MeanGene427
    MeanGene427
    from Napa
    Yeah, the brakes are similar size, and somewhere around here I have the distribution plumbing for the M/C from a 69 I parted out, would make it a lot easier
  4. 100% Matt
    100% Matt
    ECI Brakes can get you set up with a dual mc set up
  5. I used a 67 f100.
    Super easy
    deathrowdave and bobss396 like this.
  6. Used a 67 on my 64 as well , easy peasy
    anthony myrick likes this.
  7. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    When I looked for a M/C I discovered the last year that the Ford F-100 had non-power disc / drum setup was 1977. So any prior year M/C for a disc / drum non-power application might work.
  8. HOTRODPRIMER
    HOTRODPRIMER
    That's what I used on my '65 Ford pickup more than 30 years ago. HRP
    Center of the Galaxie likes this.
  9. MeanGene427
    MeanGene427
    from Napa
    Might have gotten lucky today, helping my friend I got the pickup from, found a new dual M/C and power booster that they didn't use on their '66. Also found a boxful of dual M/C brake lines and new lines of different lengths- nice little stash
    MO_JUNK likes this.
  10. deathrowdave
    deathrowdave
    from NKy
    Did my Buds’66 many years ago , power steering , power brake booster and MC all from 75 4x2 f150 . They fit as if Henry planned it to work .
