Technical Tire Help
Discussion in 'The Hokey Ass Message Board' started by John Fournier, Mar 24, 2022.
  1. John Fournier
    John Fournier
    I have 32 that currently has a set of 235/75R15 Cooker Wide Whites on it.
    I'm going to keep them, but want a set of Black Walls to run.
    After researching it looks like AVON TURBO STEEL is the closest to the old look I'm looking for in a Radial even thought its a 235-70. Problem is: I cannot find them anywhere.
    Does anyone have an idea where I could get them, or a suggestion of another tire?
    I really want a Radial in that size or something very close, but want to keep a traditional look.
    Thanks in advance...
    dana barlow likes this.
  2. deansrr
    deansrr
    Starfire, Cooper tire import, Hankook, Toyo, Nexen, Kenda, just to name a few
  3. SS327
    SS327
    I thought Hoosier made all of Mickey Thompson’s tires?
    Elcohaulic likes this.
  4. deansrr
    deansrr
    Cooper
  5. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Please,,, do not do that. When radials became prevalent here in America, tire service industry newsletters warned against mixing bias + radial.
    "Only use radial on rear if mixing. Never run radials in front of bias. When radials are used to steer, they will create a path that the bias plies out back cannot follow. The result is compromised traction grip in the rear."
    Two and half decades later, looking to save dough, I committed this sin. The result, one rainy Friday afternoon, cost me, Two Three ****loads of money and a healthy spine and back.
    BTW the pain still lingers.
    Don't
  6. Mr48chev
    ^^^^^^^^^^^^^^^^^^^ this!!!!!!!!!!
    Been there, done that and it ******** doesn't work. I had mix and match tires on my truck in the early 80's and fought it from Top*****h to Waco and ended up taking the bias tires off the rear and putting a pair of radials on the back for the drive back. I thought the power steering was bad and it was mix and match tires.
  7. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Hey, those Diamondbacks always look impressive. Best wishes.
  8. 03GMCSonoma
    03GMCSonoma
    Why don't you remount your tires and put the white walls on the inside?
