Hot Rods Ageing a alumunium VIN Tag
Discussion in 'The Hokey Ass Message Board' started by panhead_pete, Apr 1, 2022.
  1. panhead_pete
    panhead_pete
    I'd like to 'age' or 'distress' this VIN tag which we have had to put on my car for registration purposes here in Japan. Any suggestions on how I can do that?
    Thanks
    Pete
    dana barlow likes this.
  2. error404
    error404
    from CA
    salt water probably would do fine would be easier to do before installing it though. Are you looking to keep the surrounding metal clean?
  3. Petejoe
    Petejoe
    from Zoar, Ohio
  4. oldiron 440
    oldiron 440
    Give it time....
    Stogy likes this.
  5. Mr48chev
    It will get ugly quick enough as it is, "aging" it artificially could eat the aluminum to where the stamped number isn't legible.
  6. Casey Riley
    Casey Riley
    from Minnesota
    Yellow Mustard forced patina
    ProtoTypeDesignFlauz likes this.
  7. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Spray it with Easy-Off oven cleaner.
    Let sit to taste.
  8. Moriarity
    Moriarity
    SUPER MODERATOR
    Instead, how about making the rest of the car look as good as the tag?
  9. squirrel
    Leave the car outside, under a tarp, for a couple decades. That should do it.
    (sorry...I couldn't resist)
    slayer, rc57, VANDENPLAS and 8 others like this.
  10. Mimilan
    Mimilan
    A diluted mix of Lye and table salt in water [5% each]
    Soak it into a sponge/rag and place it up against the alloy .[keep it wet]
    I have also had great success adding patina to alloy wheels with dry powder from a fire extinguisher
    panhead_pete likes this.
  11. 1952henry
    1952henry
    As above, test on s**** to get desired results.
  12. choptop40
    choptop40
    squirrel thats hillarious...the humor on the Hamb is priceless...
  13. Truckedup
    Truckedup
    Give. I to me because I can’t have any nice stuff. In a short time it’ll look all used up
  14. blowby
    blowby
    from Nicasio Ca
    Pee on it. That's how my dog ages my mags.
  15. lake_harley
    lake_harley
    Squirrel......I completed the above instructions for you in bold.
    Lynn
  16. panhead_pete
    panhead_pete
    Thanks for the laugh Squirrel. For those that missed it here she is the day the previous owner Jay, found it and the tarp came off it after 20+ years. If only the tag was on it then :)
    Yeah, nah. That's not in the cards for this one.
    Cheers!
    Dont think I'll get a dog to piss on it either @blowby :)
    Primered Forever and VANDENPLAS like this.
  17. Wanderlust
    Wanderlust
    BCF2D45F-3887-4C9A-B017-D67730E02381.jpeg 539307C3-5D46-42DF-8417-553E3B2B0655.jpeg Why? This is the tag on this truck , that’s 60 years old!
  18. MCjim
    MCjim
    from soCal
    bury it in your cat's litter box for a couple weeks
    Phillips likes this.
  19. HOTRODPRIMER
    HOTRODPRIMER
    A friend of mine refinishes antique furniture and uses regular bleach on aluminum and decretive tins to achieve the look of time, he sprays bleach directly on the piece he is working on and the sit's it out side in the sun, it will fade the piece, check it every now and then to ac==get the look you want. HRP
  20. redo32
    redo32
    Is that the number on your ***le? That's a fairly early '32 serial number. 1934 number should be 18-450,000+.
  21. blowby
    blowby
    from Nicasio Ca
    Man, that is sweet looking coupe!
  22. Budget36
    Budget36
    Can it be distressed with a scotch brite pad?
  23. blowby
    blowby
    from Nicasio Ca
    I think soda blasting.
  24. For US production the 1934 Ford did not have a VIN tag. They used the serial number stamped into the top of the frame near the steering box (it may be faint). The same number also appears on top of the frame rail under the body where you need to pull the body to see it. Here is a site with a lot more info on serial numbers (thank you Mac VanPelt). The tag you have looks like something from EBAY. If the inspector is knowledgeable showing him a VIN (or serial number) tag when there shouldn't be one will probably get you off on the wrong foot.
    Charlie Stephens
    R A Wrench likes this.
  25. twenty8
    twenty8
    Hey @Charlie Stephens , I think you missed a bit of important info.
    Budget36 likes this.
  26. Budget36
    Budget36
    What the Emperor says, you do;)
    Tman likes this.
