Projects Nate’s 32 roadster build
Discussion in 'Traditional Hot Rods' started by heyitsnate, Nov 17, 2020.
  1. heyitsnate
    heyitsnate
    I’ve been packing in the miles. About 80 so far , and Loving it. The rear shocks are not working at all , and as the body settles in it’s apparent there’s still some shimming to do. The shocks seem ok but the caps were bent and allowing the fluid to leak . Getting into that now. 2D2F4C30-6402-408B-B075-B1AD63838C91.jpeg B98DA0AD-5E81-4719-8043-4A819452CD44.jpeg BF5D219C-CEB2-4931-AB21-74DB29F9BBD2.jpeg 367118DF-ED0E-4A28-BAE0-8F7D3E04F866.jpeg 354BFEC1-3CE6-4DD7-B15E-D043BB277191.jpeg 65A1DC02-1961-4BA7-B8AE-2DD965A24988.jpeg 7C26F0FA-F6EE-4832-80E4-297EC3B30A3E.jpeg
  2. Outback
    Outback
    from NE Vic, Oz
    Lovely work! A beautiful hot rod!
    heyitsnate likes this.
  3. hotrodA
    hotrodA
  4. heyitsnate
    heyitsnate
    The motor developed a mechanical noise , so I pulled it. The rebuilder looks like he’s backed up all summer so I drove to Bakersfield and bought a 57 power pack engine from a hamber. Swapped it, Broke in the cam and had a main seal leak so I pulled it , did the rear main seal and took care of a bunch of other stuff along the way. Hopefully this works.
  5. gary kessler 1932
    gary kessler 1932
    Nate u did a grat job on your 32, but my 2 cents is compare the shot next to the beach, with the shot of the proper 32. notice the exhaust pipe, the one at the beach u cannot see the exaust pipe, this is the that look that u need. loose that pipe just my 2 cents Gary
  6. Atwater Mike
    Atwater Mike
    This is undoubtedly the most proper '32 I've seen...and I go back a long distance!
    Superb work, Nate
    Outback and heyitsnate like this.
  7. heyitsnate
    heyitsnate
    ACBDE9B5-422B-4F44-A81F-B9695E3D2E7C.jpeg I’ve been through a few of these early sbc motors now but still managed to make a few car shows this year, and get the interior finished. Currently I have this 265 in there.
  8. heyitsnate
    heyitsnate
    Rex upholstery did a fantastic job IMG_2675.jpeg IMG_2672.jpeg IMG_2676.jpeg IMG_2965.jpeg IMG_2836.jpeg IMG_2855.jpeg
  9. heyitsnate
    heyitsnate
    The way you see this car now is not how I pictured it in my mind at all. I’ve been working very hard on version 2 which I’m trying to finish by Santa Maria. Until then thanks for looking !
    rod1, brEad, teach'm and 3 others like this.
  10. Itchy
    Itchy
    Great hot rod, can’t wait to see the next version.
  11. heyitsnate
    heyitsnate
  12. heyitsnate
    heyitsnate
    Ok so I put some fenders on it. Then I bought a complete rootleib hood and cut it up to fit some 32 Chevy master deluxe hood sides . The Chevy handles are cool! so I made some brackets and made them work
  13. heyitsnate
    heyitsnate
    IMG_9876.jpeg IMG_9877.jpeg IMG_9876.jpeg IMG_9877.jpeg IMG_9887.jpeg IMG_9885.jpeg
    after I did what felt like an eternity of flat tig welding and bump chasing I had the hood blasted and primed and the hood doors chromed.
  14. NoSurf
    NoSurf
    Looks great! Nice job.
    Weedburner 40 and heyitsnate like this.
  15. hotrodA
    hotrodA
    Very NICE!
  16. Weedburner 40
    Weedburner 40
    Lovin the hood and fenders!
  17. hotcoupe
    hotcoupe
    Nate, really digging your car. A couple of questions - did you use a '32 or '34 rear cross member? And how did you get the '32 Chev. good to confirm to the curves of the '32 Ford cowl and grill shell? I'm planning to use the same hood side on my car and the flanges on the hood door openings want to stay flat.
    Tanks,
    Tom
    Outback likes this.
  18. 31Apickup
    31Apickup
    IMG_2874.jpeg Looks good! I also used 32 Chevy hood sides on my A coupe on 32 rails. A lot of sectioning and twisting to make it fit right.
  19. heyitsnate
    heyitsnate
    I used a 34 rear crossmember. My door openings are flat, to me it looks fine. There’s a small high spot on the cowl bead kind of in the middle of the sides but it’s not super noticeable and I don’t care. I could probably match the contour 100% but I’m not going to.
    hotcoupe, brEad and Outback like this.
  20. heyitsnate
    heyitsnate
    Yeah it’s a lot of work!!!
    Outback likes this.
  21. hotcoupe
    hotcoupe
    Thanx for the info.
    Tom
  22. dirt car
    dirt car
    from nebraska
    A totally refined traditional build & well done!
    heyitsnate, Outback and Kelly Burns like this.
  23. Malcolm
    Malcolm
    from Nebraska
    Looking good!!
  24. 57tailgater
    57tailgater
    from Georgia
    I love this thread!!
    heyitsnate, Kelly Burns and Outback like this.
  25. heyitsnate
    heyitsnate
    This next bit took one year . I love Carson tops on early cars. I thought I’d take a crack at making one. I’ve seen some on 32’s and I think some of the more modern ones are too round. I wanted to keep some angles and make it more coach built style than traditional padded tops on early customs. I ended up making the frame twice . I got the wood bow from an Amish carriage supplier and made the header bow . Here’s some pics.
    oliver westlund and loudbang like this.
  26. heyitsnate
    heyitsnate
  27. heyitsnate
    heyitsnate
    IMG_4185.jpeg IMG_9528.jpeg IMG_9538.jpeg IMG_9690.jpeg IMG_0574.jpeg IMG_0585.jpeg IMG_0584.jpeg IMG_0576.jpeg IMG_0586.jpeg The whole way through Rex from Rex upholstery and I met up so we could make sure the proportions came out right. We even went to lunch with the man Sid Chavers and he let me ask him all sorts of questions. Rex has had the top at his shop and totally crushed it , I’m so happy with how it came out !
  28. NoSurf
    NoSurf
    Sweet!
  29. glennpm
    glennpm
    Great look and job on the top!
    36 ROKIT, heyitsnate and Kelly Burns like this.
  30. wheeltramp brian
    wheeltramp brian
    That top is the ****ing best! Wow, it came out
    So nice.
