Projects 31 Kustom Roadster (DIY duvall, tudor to roadster conversion)
Discussion in 'Traditional Hot Rods' started by Chevy28, Feb 13, 2020.
  1. ct1932ford
    ct1932ford
    Great work! I like that Chevy roadster. Needs a 265!
    Chevy28 and kidcampbell71 like this.
  2. HelminenHotrods
    HelminenHotrods
    from Finland
    Hot rod season have started again !
    This build was on pause for a good while (1,5 year), but atleast i did build shovelhead chopper ! IMG_20210619_170012.jpg
    I have started ford build with doors:
    -starting point.
    FB_IMG_1580764199968.jpg -rust off
    IMG_20211020_194737.jpg -made new door bottoms IMG_20211020_212126.jpg IMG_20211018_200212.jpg IMG_20211019_204301.jpg IMG_20211019_220826.jpg
    -Next up : correct bead IMG_20211104_222014.jpg IMG_20211113_191445.jpg IMG_20211212_181403.jpg IMG_20211114_203326.jpg IMG_20211123_210704.jpg IMG_20211218_220446.jpg IMG_20220104_222606.jpg
    - Cheers, Markus
    BigRRR, Deutscher, rod1 and 18 others like this.
  3. HelminenHotrods
    HelminenHotrods
    from Finland
    Moving on to doors inner structures.
    -Door supports/lock frame IMG_20220207_193644.jpg IMG_20220207_193524.jpg IMG_20220207_193502.jpg
    -Inner Door tops IMG_20220108_211157.jpg IMG_20220108_213443.jpg -both sides supports and tops welded
    -Room for dovetails
    Lower inner panels. Made them high to match channeling IMG_20220307_215315.jpg IMG_20220308_215431.jpg IMG_20220316_203306.jpg
    -Markus
  4. Squablow
    Squablow
    Fantastic metal work!
    Chevy28 likes this.
  5. Those doors are works of art!
    -Brent- and Chevy28 like this.
  6. HelminenHotrods
    HelminenHotrods
    from Finland
    32 dovetails and diy striker plate.
    -Base for dovetail IMG_20220302_201748.jpg and welded to quarter panel IMG_20220304_232301.jpg IMG_20220304_232328.jpg
    -Door latch striker plate, stainless steel
    -Markus
    BigRRR, Deutscher, dwollam and 12 others like this.
  7. 48fordnut
    48fordnut
    What an Imagination, and Craftsmanship.
    Thanks,
    jim
    oliver westlund, -Brent- and Chevy28 like this.
  8. GordonC
    GordonC
    Nice work!
    Chevy28 likes this.
  9. harpo1313
    harpo1313
    from wareham,ma
    Are you an engineer by any chance? I am impressed by your craftsmanship. I am also a shovel guy.
    Spooky and HelminenHotrods like this.
  10. HelminenHotrods
    HelminenHotrods
    from Finland
    Thank you all !
    Thank you !
    Just an hobbyist try and learn engineer.
    Sweet sound and power of an shovelhead, Try once and your hooked !
    harpo1313 and VANDENPLAS like this.
  11. HelminenHotrods
    HelminenHotrods
    from Finland
    This was big step for the build. After 5 months got working solid doors.
    -Markus
    Deutscher, rod1, dwollam and 11 others like this.
  12. HelminenHotrods
    HelminenHotrods
    from Finland
    Found this david brown door handles from local tractor parts store. They are kind of matching to my diy trunk handle IMG_20220319_212532.jpg IMG_20200320_232214__01.jpg
    Inside handle is from 1928 chevy.
    Smallparts are diy.
    -Markus
    Barn Hunter, BigRRR, dwollam and 12 others like this.
  13. Motorwrxs
    Motorwrxs
    Awesome work…my only complaint is the thread is too short! I could really read and look at quality work like this for hours at a time. Thanks for sharing.
  14. 101Scout
    101Scout
    Damn, Markus, you've got some top notch fab skills. Beautiful work! If I had just seen that body I wouldn't have guessed it was a converted sedan. Love the Shovel too. I've got a '29 roadster and a '76 Shovel (plus my '29 sedan) in the works when I get time to spend in the garage again. Very inspiring work, man, thanks for sharing!
    chryslerfan55 and Chevy28 like this.
  15. oldbanger71
    oldbanger71
    Cool stuff ,your building skill's are impessive . I like the little details...
    Have you thought of creating a hardtop for your roadster out of the remaining panels . Shouldn't be to hard for you....;) and intetesting for me. I'm planing to build a hardtop out of a 34 , 3 window roof panels onto my 32 roadster.....:) anyhow will follow.
    Chevy28 likes this.
  16. HelminenHotrods
    HelminenHotrods
    from Finland
    Thank you, and yes sir removable hardtop is on the bucket list !
    But i also thought of building more smoother 34 style roof, rather than using model-a panels .
    Just need to build windshield first to figure out right proportions for the roof !
    -Markus
  17. HelminenHotrods
    HelminenHotrods
    from Finland
    Thank you ! Not much left from tudor body, thats why i changed this build ***tle to kustom roadster, rather than just conversion.
    I almost have enough "spare parts" to build that tudor body back to rocking and rolling
    -Markus
    oliver westlund likes this.
  18. HelminenHotrods
    HelminenHotrods
    from Finland
    Thank you ! Kind comments gives me motivation and positive energy to keep on building !
    -Markus
    48fordnut likes this.
  19. oldbanger71
    oldbanger71
    My plan for the windshield is to use the original panels chop them at lest 2 -3 inch, but lean a-pillar backwards, build a lower frame which follow the original torpedo but covers the lower seal and use the Original montingpoints to screw down the front, the rear should also follow the stock contours with s seal, use the original fixing points. As for the doors, i will keep the stock 32 short doors but use the top portion and windows of the 34 as sort of removable window, (much like manny british roadsters ) If viewed from the side, so when the door is closed it looks 34 window with layedback a-pillar, but when open the 34 window sticks out from the short door. I start first with the sidewindows, as they will show how much lean back is needed in the windscreen to get the right look once this is right, the roof will follow. Most people start to chop the roof first and the sidwindows follow. i believ my approach is easyer , jusr my two cents . I 'm quite large and discovered that with my softtop visability is very restricted... but with the 34 window all is good . Windows will have sliding tracks to open..... loads of ideas and gathering parts, but building has not yet started. Cool that your hardtop is on your list....
  20. HelminenHotrods
    HelminenHotrods
    from Finland
    Looking forward to see what you come up with !
    I'm planning on building V-style/ hallock style winshield, so going to be a challenge to get right proportions for roof !
    -Markus
    Spooky, oliver westlund and hfh like this.
  21. sloppy jalopies
    sloppy jalopies
    spiff... very spiff !
    Chevy28 likes this.
  22. oldbanger71
    oldbanger71
    Hey Marcus, Hallock windshield is cool, what do you know about your Hallock ?
    Is it bronze or alluminium cast ? Is it a '39 cast , 70's cast or 90's cast ?
    How about using the hallock windscreen without the hardtop but build a '34, 3 or 5 window hardtop, so you get both styles. i'm somewhat concerned that if you use the hallock 'screen, it might not be ridgid enough and seen might spoil the unic style ? Although i have seen a V-screen with homemade hardtop....
  23. hfh
    hfh
    from Western MA
    Thank you for sharing all the pictures of your roadster project. You have some very impressive metalworking and design skills. Looking forward to details on your Hallock style windshield and top. HFH.
    101Scout and Chevy28 like this.
  24. HelminenHotrods
    HelminenHotrods
    from Finland
    I dont have windshield yet. Mine is still just an cardboard mockup. I'm going build one from stainless steel.
    Your idea of roof with A-pilars is great idea ! but i think im up for the challenge to get right looking V-Window and roof. If it looks goofy, i can go back and build the A-pilar style roof.
    -Markus
  25. HelminenHotrods
    HelminenHotrods
    from Finland
    I've been working on cowl. P***enger sides panels are done and welded up.
    Because the body is channeled and sits very close to frame (0,1 inch / 3mm gap at front)
    I made an "unit" with inside and outside panels. Pretty complex panel with all the curves and beads and bends.
    -starting point: rusty and no curve IMG_20220402_000726.jpg
    -After figuring out right upwards curve i made an wood buck IMG_20211023_232259.jpg
    -Bead rolled and hammering flanges against the woodbuck IMG_20211225_181910.jpg
    -Two pieces ready to weld up IMG_20220327_184357.jpg IMG_20220327_180922.jpg IMG_20220327_204632.jpg IMG_20220327_204640.jpg IMG_20220327_204615.jpg IMG_20220327_204424.jpg
    - At first try it was kind of sticking out at that point where the upwards sweep starts. After cutting and welding again i got the shape all good and smooth
    -Welded up. TIG welding is the King ! So smooth and fun, just have to be extra carefull to clean everything up before welding! IMG_20220330_202024.jpg IMG_20220401_232423.jpg
    -little tech tip. I use flashlight to spot any holes in welds. You can easily spot smallest pinholes what wouldnt be seen with bare eyes IMG_20220401_230549.jpg IMG_20220401_233922.jpg IMG_20220401_231058.jpg
    -Markus
  26. HelminenHotrods
    HelminenHotrods
    from Finland
    Finished p***anger side. Next up is drivers side. IMG_20220401_234143.jpg IMG_20220401_234040.jpg IMG_20220401_234454.jpg IMG_20220401_234431.jpg IMG_20220401_233913.jpg IMG_20220401_235342.jpg IMG_20220402_005046.jpg IMG_20220402_005118.jpg IMG_20220402_005300.jpg
    And some off-topic for shovelhead guys ! I had an honor to be on the cover of Finnish chopper magazine Kopteri IMG_20220328_194620.jpg IMG_20220328_195050.jpg
    -Cheers, Markus !
  27. 101Scout
    101Scout
    Wow, extremely nice detail work on the cowl. And your shovel is just bad***, congrats on the magazine cover shot! That's just cool.
    Atwater Mike and Chevy28 like this.
  28. HelminenHotrods
    HelminenHotrods
    from Finland
    Thank you !I appreciate !
  29. 2Blue2
    2Blue2
    Cool cover, buy extra copies.
    Roadster is coming along very nice.
    Carry on!
    Chevy28 likes this.
  30. HelminenHotrods
    HelminenHotrods
    from Finland
    Getting on with the build.
    I didn't spent much time in garage during summer holidays, but now been enjoying building, full of motivation !
    Drivers side cowl :
    IMG_20220412_144336.jpg IMG_20220411_210655.jpg IMG_20220411_210723.jpg IMG_20220409_175943.jpg IMG_20220409_192423.jpg IMG_20220412_164345.jpg
    Welded and finished :
    -Markus
