Hot Rods Sbc oil filter relocation
Discussion in 'The Hokey Ass Message Board' started by pbr40, Apr 2, 2022.
  1. pbr40
    pbr40
    from NW Indiana
    I’m sure this has been neat to death here but I am running a early sbc with long tube headers. The Clearance from the filter to the headers is about 3/8-1/2 inch with the short filter and the spin on filter adapter. Looking to relocate the filter to a place where it’s not going to get beat up by heat and has better access. What have you fellas used to achieve this? Thanks
  2. Buy a filter relocation kit. Summit and I am sure jegs and any number of catalog speed shops sell them.
  3. pbr40
    pbr40
    from NW Indiana
    All I seen is for the later blocks. I didn’t really want to put an adapter on an adapter
  4. jetnow1
    jetnow1
    from CT
    Even the last small blocks use an adaptor, the block casting was the same.
  5. pbr40
    pbr40
    from NW Indiana
    Ok for some reason I was under the impression the early was different then later stuff.
    427 sleeper likes this.
  6. 427 sleeper
    427 sleeper
    You're correct, the early stuff is different. I don't know if an adapter for a remote mount is avaliable.
    egads, pbr40 and squirrel like this.
  7. squirrel
    the later blocks use a different adapter...the blocks are indeed different.
    427 sleeper and pbr40 like this.
  8. egads
    egads
    Why not get a short pf454 filter? 3.3 inches tall. What filter do you have now?
    tractorguy likes this.
  9. pbr40
    pbr40
    from NW Indiana
    Thank you
  10. pbr40
    pbr40
    from NW Indiana
    So I ordered the perma cool 10613 and that is for the early blocks. So hopefully this may help a hamber in the future. It’s also made in America! 87563392-064B-4D7D-8A4E-FB69D0CCDB27.png
  11. Russco
    Russco
    from Central IL
    On my ‘40 coupe I mounted in on the frame rail inside the drivers side fender. Easy to access and road tested for many 1000’s of miles B921E40F-8188-40C6-8CD1-FB36ED70CD40.jpeg
    pbr40 and CME1 like this.
