Technical What did you do with your car today? * NEW*
Discussion in 'The Hokey Ass Message Board' started by j hansen, May 3, 2020.
  1. guthriesmith
    guthriesmith
    More driving and a little fundraiser show a guy I used to work with organized. I remembered why I don’t really do shows anymore. The driving was nice though.
    19C16281-085A-4CB2-9B57-CEB7A7C2D977.jpeg 88C1C471-5C1F-4D53-9054-C68FAEE7418E.jpeg
  2. Dave Mc
    Dave Mc
    [QUrestOTE="vtwhead, post: 14438107, member: 65875"]Wow that is a nice 53! How many miles on that beauty?[/QUOTE]
    136,212 total miles, very few since restored.
    Lil32 and guthriesmith like this.
  3. cheap-n-dirty
    cheap-n-dirty
    drove to the town next door for a burger.
    MO_JUNK, Blues4U, Marcia and 4 others like this.
  4. mad mikey
    mad mikey
    Got the engine back together, everything checked, improvements done, resealed with cometic gaskets, polished and polished again. Changed the diff oil in the 59 pontiac Fab craft trophy track rear. Fresh plugs, and made a brace for the wheelie bars. Fired her up yesterday. She is snappy and ready for action. WIN_20220403_14_35_50_Pro.jpg WIN_20220403_14_36_27_Pro.jpg WIN_20220403_14_38_37_Pro.jpg
  5. mad mikey
    mad mikey
  6. nobby
    nobby
  7. guthriesmith
    guthriesmith
  8. mad mikey
    mad mikey
    This will be the first full season with the Rossler racing trans and other upgrades, I am looking for high 8 seconds- 1/4 mile. Ran low 9s last season.
    Almostdone, rod1, j hansen and 4 others like this.
  9. 1971BB427
    1971BB427
    from Oregon
    Swapped out the funky aftermarket steering wheel in my '39 Chev coupe, and installed a '53 Chev steering wheel I found at the swap meet on Friday.
  10. Rehpotsirhcj
    Rehpotsirhcj
    Pulled this old girl out today. In mothballs for the last two years. A quick battery swap and a prime of the fuel system, started right up!
  11. I began ***embling the 351W after getting it back from the machine shop this winter. I was rolling along just fine until installing number five piston and rod. I was making sure I had the bearing insert oriented correctly so that the hole lined up with the oiling hole in the rod. Well, there wasn't an oiling hole in this rod, unlike the other seven. It was a new rod, a replacement that the machinist had to get as the old number five rod was too corroded to stay. I believe the oiling hole, which feeds the wrist pin with oil, needs to be drilled in this rod. Do they come from the factory without the hole? Also, another hitch: I had gotten the wrong timing set, which needed a longer chain. So the 48-year-old project has to wait another week or two before the new timing set arrives. Anyone need a brand new timing set for a Ford small block no later than 1972?
  12. Wanderlust
    Wanderlust
  13. topher5150
    topher5150
    Got it cleaned up, painted and in it's new home
  14. TA DAD
    TA DAD
    from NC
    I finished the side boards and they are bolted in place. I never liked the chrome reverse wheels I had on the front so a buddy gave me these wheels and I flipped the white walls around and with the old Keystone spyder caps it looks much better ! IMG_0286.JPG IMG_0289.JPG
    MO_JUNK, osage orange, Marcia and 6 others like this.
  15. Crkrjac
    Crkrjac
    from Waxhaw NC
    Finished up seat mounts for my A coupe. 7007F7D5-0C80-4B3C-8742-9CEFD1BAFB35.jpeg 105F8DBE-4CFE-43E6-84EE-70D6368F221F.jpeg
  16. jeepster
    jeepster
    from wisconsin
    Oil Change
    Marcia, Lil32, TA DAD and 2 others like this.
  17. Marcia
    Marcia
    What year is this? Chevy or GMC?
  18. TA DAD
    TA DAD
    from NC
    It is a 47 Studebaker M15
    milwscruffy and Marcia like this.
  19. Modded 105E
    Modded 105E
    Looks excellent, a huge improvement.
  20. Modded 105E
    Modded 105E
    Squeezed around it to get to a drill I needed at the far end of the garage!
  21. RICH B
    RICH B
    Frustrated hanging around with my right arm in a sling from shoulder surgery. Wife went to work, so I snuck out in the garage and used the belt sander on my hopefully soon to be dash knobs. I'm right handed so left hand sanding took a bit of learning.
    rod1, Hamtown Al, MRW1994 and 14 others like this.
  22. TA DAD
    TA DAD
    from NC
    So to let the front tilt with the bumper in place the bumper must pivot also to clear the grill section. I fabbed up some brackets and hinges to make that happen I just need to come up with a couple quick release pins of some kind to hold it in place when up. IMG_0300.JPG IMG_0299.JPG IMG_0298.JPG IMG_0303.JPG IMG_0297.JPG
  23. Almostdone
    Almostdone
  24. TA DAD
    TA DAD
    from NC
    Do you mean the front sheet metal ?
  25. Marcia
    Marcia
  26. TigerFan
    TigerFan
    from Athens, GA
    I got my Auburn radials mounted on my 16x4.5 wheels, and just for giggles set them up next to the ‘31 to get a sense for how they will look. ADC95C2B-6677-43BE-ABF9-5B3003E175D7.jpeg B5846903-366E-41BA-B807-F6FE499689AA.jpeg View attachment 5370082
  27. blowby
    blowby
    from Nicasio Ca
    Cut, welded and rattle canned an old dished steering wheel. No flat ones at the swap meet.
    MO_JUNK, rod1, bchctybob and 12 others like this.
  28. tylerbrasher
    tylerbrasher
    “Finished” up a disc brake conversion on my 54 ford
    quotes because there are still leaks of course
    TA DAD and j hansen like this.
  29. Marcia
    Marcia
  30. Jkmar73
    Jkmar73
    from Tulare, CA
    Didn’t do much to it today. Pushed the model a out to do a quick garage cleaning and reorganizing to get some more room to work on it. 696413F9-414D-4623-9F31-6B8F53618798.jpeg
    Dave Mc, bchctybob, blowby and 7 others like this.
