Hot Rods Crower Small Block magnesium fuel injection manifold
Discussion in 'The Hokey Ass Message Board' started by Greg Hogue, Jan 16, 2022.
  1. Greg Hogue
    Greg Hogue
    I Found this in an attic over a race shop, probably been there for 50 + years. Tring to figure out the history. Its magnesium.
    1934coupe, Bob Lowry, Deuces and 7 others like this.
  2. Doublepumper
    Doublepumper
    from WA-OR, USA
    Man, I wish I'd find something cool:rolleyes:
    Deuces likes this.
  3. sdluck
    sdluck
    Tubes look big.
    Deuces likes this.
  4. Mike VV
    Mike VV
    from SoCal
    Have you...say...called Crower ? Seems like the thing to do. Have the casting and part number in hand...
    Mike
    Just Gary, mad mikey, X38 and 2 others like this.
  5. sdluck
    sdluck
    Are you sure it is for a sbc?
  6. 402BOSSMAN
    402BOSSMAN
    Nice piece, yes clearly for a SBC.
    Deuces and mad mikey like this.
  7. Greg Hogue
    Greg Hogue
    Crower has not made this one since the 70s. The ports are stock SBC and not port matched. The throttle blades are still smooth. This one looks big as far as tubes. I'll look for some numbers on it in the morning
    Deuces likes this.
  8. X38
    X38
    This is a little vague. What kind of history are you after?
    Crower Fuel Injection
    The Crower Fuel Injection Division was sold to Ron's Racing in Tucson, AZ in 1990.
    For information, please contact Ron's Racing at 800-513-FUEL (3835) or Ron's Email
    Deuces, mad mikey and 19Eddy30 like this.
  9. Greg Hogue
    Greg Hogue
    Basically what it was. Drag, Land Speed. It's fairly big for that era
    Deuces likes this.
  10. Mimilan
    Mimilan
    And most of all..................Formula 5000 [Formula A]
    The Mackay and Crower Manifolds with Lucas Metering was the Injection of Choice
  11. pnevells
    pnevells
    looks very similar to our 1969 Crower unit
    fauj, Desoto291Hemi, Deuces and 3 others like this.
  12. mad mikey
    mad mikey
    Nice unit, I would clean it up and run it.:)
    Deuces, Just Gary and loudbang like this.
  13. pnevells
    pnevells
    Ours has 2.5 inch ****erflies ,but unported manifold that looks fairly stock sized, i have seen them with nozzles above and below the ****erflies , i had a Crower pump with mine when i got it from Alkydigger, ran fine for years until pump seals went, no parts available for Crower pumps so i switched to Kinsler pump
  14. Fordors
    Fordors
    It might not mean anything but I always wondered about Crower moving the nozzles down from their initial position. The first manifolds (Bruce intro’ed them for the BBC) had the high position and if my memory is right they moved them lower over the years.
    Hilborn nozzles were low, as were Pete Jackson’s and that seems like it would give a more direct shot at the intake valve. When I look at the change to the base of the unit I wonder if the casting was made to adapt something other than simple nozzles, it looks like there were bosses on the rectangular area where maybe 10-24 or 1/4-20 screws could hold something.
    mad mikey, fauj and loudbang like this.
  15. Anytime
    Anytime
    High for gas, low for ally.
  16. 12packo94s
    12packo94s
    I've got one of those too
