Hot Rods Hurst Mounts and the sincere Imitators
Discussion in 'The Hokey Ass Message Board' started by SilverJimmy, Mar 4, 2022.
  1. Can we PLEASE see some photos on this?!
  2. Hi Retson, I haven’t made my mount yet, hence the interest,the only picture I could put up was of an A timing cover showing the mounting castings, is that what you are after?
  3. Roothawg
    Roothawg
    The general consensus is to run a mid plate at the bell housing. You could fab something simple just to take some of the load off and help distribute the weight.
    Okie Pete and 46international like this.
    Retson, this is on a B motor I have that made me think about making a Hurst style mount,
    This is what got me thinking (maybe over thinking) about the hurst mounts just using the timing cover bolts and possibly crushing the gaskets causing them to loosen up. Obviously they are fine but hopefully my thought pattern is obvious when you compare the way these are mounted.
    I’m not sure if these are oem style or just something made to fit the sprung style A and B motor mount tabs.
    tractorguy, Okie Pete and neilswheels like this.
  5. 38Chevy454
    38Chevy454
    Mid mount also helps with torque reaction. Useful if the engine mount bokts are closer to center.
  6. nochop
    nochop
    from norcal
  7. bchctybob
    bchctybob
    On the early Olds, the front mount angle bracket attaches to dedicated threaded bosses along the bottom of the timing cover, the 4 bolts only hold the mount to the cast iron timing cover. There is a rectangular bonded rubber mount that bolts to the bottom of the angle bracket. The four bolts do not hold the timing cover to the block. There are nine or ten bolts that hold the timing cover to the block. Some Pontiacs and Ford Y-blocks also used a mount on the timing cover.
    In the rear, Olds used a bellhousing side mount. One on each side, bolted to the sub-bellhousing and attaching to a removable stamped steel crossmember. They make up a three point mounting system. I would not run an aluminum case transmission with only the Hurst front mount and the rear tail shaft housing mounts. The cast iron hydro would probably be ok with a Hurst on the front and a fabricated mount on the tail housing. I did it that way on my Olds powered ‘47 Ford coupe.
    I thought I had a picture of the Olds timing cover, I guess not. Here’s the side mount, very similar to a ‘55-‘57 Chevy. (Bottom transmission)
    Okie Pete and Barrelnose pickup like this.
  8. Boneyard51
    Boneyard51
    I’ve got a Hurst front mount to put a Y-block in a shoebox….somewhere in the barn!
    Bones
    alanp561 likes this.
  9. nochop
    nochop
    from norcal
    I’m thinking about adding mid mounts.
    bchctybob likes this.
  10. Marty Strode
    Marty Strode
  11. I know this post is about Hurst mounts, but C-T Automotive also made engine mounts, but not as many types as Hurst. In my 1961 Cragar catalogue, the C-T mounts are shown.
    Tman and bchctybob like this.
  12. atch
    atch
    nick, Since this thread includes "sincere imitators", which includes C-T, would you scan those Cragar pages and post here?
    Tman, SilverJimmy and bchctybob like this.
  13. neilswheels
    neilswheels
    from England
    enginemnt.jpg DSC04794.JPG My Hurst appreciation mount. 348 in a 40. It turns out I could probably have used a genuine one, but hey ho. It does move the engine forward an inch or so, giving me a little more fire wall clearance.
  14. Detonator
    Detonator
    from santa cruz
    Founds some NOS mounts for the Nailhead in my old RPU. I'd hate to have to hunt for this stuff today.
  15. tim troutman
    tim troutman
  16. -Brent-
    -Brent-
    I have had a small collection of Hurst mounts over the years. I'm down to two SBC mounts.
    Here's the one in my car.
    tractorguy, Okie Pete and SilverJimmy like this.
  17. atch
    atch
    Nick sent me the catalog and I scanned the page with motor mounts. Here the part of the page that shows motor mounts:
  18. bowie
    bowie
    CR-202 pair for 392” Hemi : 9FB65547-451F-4B31-8FAA-EC123D397A63.jpeg EAEE1DBA-2524-485E-AA47-E12EF4B9D82E.jpeg
    -Brent-, Okie Pete and SilverJimmy like this.
  19. bowie
    bowie
    87F47D02-360B-45D9-9A0C-308060183F78.jpeg I used a CV-2-202 to stuff the 427 in my ‘57 htop: CD0D99B9-B35B-4285-A1E8-FB10BE6ACD2E.jpeg
    bchctybob, Okie Pete and SilverJimmy like this.
  20. Speedy Canuck
    Speedy Canuck
  21. bowie
    bowie
    B842E03C-C2D3-4EBF-8D46-805A830F1803.jpeg I am using CV-202’s in my ‘32, ‘36 pickup and my “A” coupe : 6FD365B9-FD3B-44C0-9549-880DBB4DAAFF.jpeg CAB293BD-9A37-4CC3-8B32-946D48E7A1F9.jpeg 5DF1110F-730A-4D8F-B6D4-18013F6F8827.jpeg 1B7CDE33-B6A0-4817-A050-A797975E0784.jpeg 693F57B5-7CA0-42DE-BEBB-9C725318E3F4.jpeg
  22. Since myself and many others always ask about stock pumps, here is a good shot of the spacers needed taken from my new 283 20220522_125123.jpg
    bchctybob, SilverJimmy and Okie Pete like this.
  23. CGkidd
    CGkidd
    I have never seen a set up like that. Pretty crazy. I will post some of mine when I get home later. I have some original Hurst and repop
    SilverJimmy likes this.
  24. Speedy Canuck
    Speedy Canuck
    It's a modified Pontiac mount with the stock Olds mount added on.
    bchctybob and SilverJimmy like this.
  25. Jacksmith
    Jacksmith
    from Aridzona
    This one has a clearance on the p***. side and a small drilled hole on the driver side for some un-known reason... IMG_0545.JPG IMG_0547.JPG IMG_0549.JPG
    bchctybob, -Brent- and SilverJimmy like this.
  26. lodaddyo
    lodaddyo
    I bought a set of the ct mounts for an olds. Anyone got a picture of them mounted up? Thanks
