Technical Removing melted plastic from my headers
Discussion in 'The Hokey Ass Message Board' started by Dino 64, Apr 4, 2022.
  1. I own a powder coat shop and have done lots of ceramic coating on exhausts. If your exhaust is truly ceramic coated and not just high temp painted, you should be able to "pluck" it off with a knife or s****er when the exhaust is cooled off. Ceramic coat is tough ****, not much effects it or sticks to it!
    Dino 64 likes this.
  2. bobss396
    bobss396
    I did contract work for him for years. If I did work in his shop, I made sure anything hazardous was put away. He closed up shop a few years back and is semi-retired up state NY.
    I was always careful around chemicals even when I fixed cars. I'd see guys washing their hands at the Safety Kleen sink, or use carb cleaner. One parts place I bought from had a hot-tank close to the parts counter. Go home and I'd still have the stink on me. I can't imagine working there 8 hours a day was good for your health.
  3. mickeyc
    mickeyc
    I would try cranking the motor, let it get hot. When the plastic gets as hot as it did when it initially melted try to
    s****e it off. It seems if it got hot enough to melt once it may well s****e off when that hot again. Just a thought.
    Dino 64 likes this.
  4. Dino 64
    Dino 64
    from Virginia
    Ok, thanks for all the suggestions. I called Sanderson today. The tech said guys try all kinds of things but if worse case, he can recover it. I mentioned propane low heat and a wipe off. He said never heard of that one, give it a shot !:rolleyes:.
    So I did. Waited till it got a little gooey, then a very gentle s****e with a knife. Once it started to loosen, I used an extra fine scotch bright pad with acetone. Slowly came off. Yay !!:):)
  5. mad mikey
    mad mikey
    Glad you got it off Dino, good job!
    lothiandon1940, Just Gary and Dino 64 like this.
  6. Dino 64
    Dino 64
    from Virginia
  7. choptop40
    choptop40
    It’s the little details….
    Dino 64 likes this.
  8. Dino 64
    Dino 64
    from Virginia
    Full disclosure, afterwards I used a buffing wheel with some hard metal polish and was able to match the shine that was partially dulled by the Scotch B***e pad.
    One last detail ;):cool:
  9. Dino 64
    Dino 64
    from Virginia
    Here’s a pic I just took, any eagle eyes out there that can tell where it was ? Still, better than a black blob.
    :eek::rolleyes::) 57AD2479-5131-442D-B0A3-489050D282AB.jpeg
    reagen, lothiandon1940 and Tman like this.
  10. theHIGHLANDER
    theHIGHLANDER
    DO NOT USE AN N-95 MASK!! IT WILL CONCENTRATE THE ****IN FUMES AND TOXINS IN THE MASK!! Only a regular paint respirator, N-95 is particle only. ****...:eek:
  11. AccurateMike
    AccurateMike
    I think there may be some confusion regarding our deadly chemicals. Methyl Ethyl Ketone Peroxide is a catalyst for setting off polyester resin. Without the peroxide it is a solvent. I think the Methyl Eats The **** Out Of Most Things that you might be thinking of is Methylene Chloride. Used in strippers (the "good old" ones anyhow).
    I'm glad he wiped it off, looks good. I was told a story about a girl that covered a hot motorcycle once. The bike shop used oven cleaner to get most of it off. Mike
    lothiandon1940 and Dino 64 like this.
  12. nrgwizard
    nrgwizard
    from Minn. uSA
    Thanks Highlander. Was only a guess, as I haven't used them for that. & if I did use it, it would only be for that short time needed, then tossed, *never* reused. I do have paint respirators.
    Marcus...
    theHIGHLANDER likes this.
  13. tiredford
    tiredford
    from Mo.
    I had the same thing happen. After trying a few things, I gave up and just drove it. The next time I drove it the spot was gone....completely gone
    Dino 64 likes this.
  14. Dino 64
    Dino 64
    from Virginia
    That’s definitely easier ;)
    lothiandon1940 likes this.
  15. Motorwrxs
    Motorwrxs
    Header looks great…cannot tell the area you cleaned.
  16. error404
    error404
    from CA
    looks great to me!
  17. Dino 64
    Dino 64
    from Virginia
    Thanks ;) :):) ^^^^^^
  18. Dino 64
    Dino 64
    from Virginia
  19. Knew it! Good job!
  20. Dino 64
    Dino 64
    from Virginia
    Thanks, so you knew where it was ? A guess it looks a little shinier than the other.
    But you said I was screwed !!:eek::eek::rolleyes::D:D
  21. It depends on the condition of your ceramic, yours looks pretty good to start. I have seen more fails than successes! You done well, and yes, that location was my guess. Not that it stands out
  22. seb fontana
    seb fontana
    from ct
    I picked there too but a few degrees towards the outside.. Just a guess.
    lothiandon1940, Tman and Dino 64 like this.
  23. Dino 64
    Dino 64
    from Virginia
    Still better than a black blob ! I appreciate your honesty .;)
  24. choptop40
    choptop40
    Those are amazing looking headers…
    Dino 64 likes this.
  25. Dino 64
    Dino 64
    from Virginia
  26. lothiandon1940
    lothiandon1940
    Glad this all worked out, Dean. I surely didn't have an answer, so I just listened to all of the responses. I personally wouldn't ever use MEK for anything. Just too dangerous.
    Dino 64 likes this.
  27. Dino 64
    Dino 64
    from Virginia
    Thanks Don, gotta make it all pretty for Jalopyrama !
    Just Gary and lothiandon1940 like this.
  28. reagen
    reagen
  29. Dino 64
    Dino 64
    from Virginia
    Thanks :) ^^^^^^
  30. theHIGHLANDER
    theHIGHLANDER
    I hope it didn't come across too hostile, but any of those face masks like N-95s will not stop the fumes. It will concentrate them into the nose and mouth because there's no charcoal filtering required for vapor. Dust and particulate only. And that was for everybody talking about it, not trying to be a safety freak just don't want anyone hurt. Or killed!
    X-cpe, Dino 64 and lothiandon1940 like this.
