Projects Hotrod ford and a 2$ bill 3window
Discussion in 'Traditional Hot Rods' started by angelbaby65, Mar 7, 2022.
  1. sloppy jalopies
    sloppy jalopies
    are going to paint it yellow ?
    WC145 likes this.
  2. v8flat44
    v8flat44
    How about this one that I have
  3. v8flat44
    v8flat44
    Couldn"t post it ???? #02 Wix Filter Ertl 1/24 th scale.
  4. Budget36
    Budget36
    If you head my way, lemme know. Gotta hide the women and children.
    That’s gonna be one radical looking machine!
    angelbaby65 likes this.
  5. angelbaby65
    angelbaby65
    Onto the next piece. DEEP BREATHES!!!! This is going to be a challenging one for me. 0D6CA8CF-3B88-4E7F-BC1B-96A3D8D330B9.jpeg
  6. angelbaby65
    angelbaby65
    I was hoping to get this, in 1 shot but no cigar. I’ll have to make the drip rail section separate. Which I’m ok with, it’s a learning process, trying to take my time, listen, watch and learn the metal. I was a little over whelmed after I cut this section out due to the radius in every direction but I’m happy with how it came out.
  7. vtwhead
    vtwhead
    Nice work and I bet that was a bit of a challenge.
    Stogy, lucky ink and angelbaby65 like this.
  8. angelbaby65
    angelbaby65
    Messing around with a little push bar. I didn’t spend much time on it because I had mixed feelings.. if I decide to keep it the connecting tube needs coped and the push bar needs capped, just a light tack to see what it looks like. I used some 1.5 od tubing to match the back connecting brace on the frame. It was just some s**** I had it actually has a slight radius to it too, which I kinda like.. still unsure tho, I think the 1.5” might be too big. What do u guys think? 7E55B789-F808-4773-B232-85E2C3AA8F83.jpeg B145D92A-D3F4-4777-9C2E-2CBB3BF7DBBE.jpeg
    brEad, oliver westlund, Stogy and 4 others like this.
  9. Outback
    Outback
    from NE Vic, Oz
    Even if it is never used it needs to be functional to look right. Great project! Sub'd
    angelbaby65 and Stogy like this.
  10. vtwhead
    vtwhead
    I like it, weld it up!:)
  11. That is a lot of progress in just a month. Love me a chopped 33/34 will be following along.
  12. angelbaby65
    angelbaby65
    DDDC5FE7-E261-4C36-AFB7-53BCC9B0AF0C.jpeg I’ve been busting my ***, Got most of the metal work finished up on the p***enger side so I had to roll it out side for a shot! Still not sure if I like the push bar or not… also scored a ton of good parts! I’m gonna make garnish moldings out of the sedans molding I got. Also got a 34 dash that’s been cut with this cool insert. Anybody ever seen a insert like this with the hearts as blinker indicators?
  13. Budget36
    Budget36
    I’m not feeling the look of the push bar. Great work on the car!
  14. junkman8888
    junkman8888
    Dump the rear push bar, use individual "nerf" bars.
  15. Stogy
    Stogy
    It's a Hotrod that looks like it does Lakes duty...You'll use it when there's higher gears...I'm working on an inspiration...the keep it simple principle hugely plays into this... but at a minimum it needs to be functional and the beef is workable...it's got a tough job...your nailing it @angelbaby65
    :rolleyes:...if you click on the thumbnail you can clic the image and cycle it to visualize the pushbar changes I made...basically put an arc in the crosspipe and cap the pusher and fit and gusset it... the aft arc would strengthen the crossbar I'm thinking and work with the curve of the pan area...again I like it...just me...;)
  16. I can’t help you with the insert, but the overall look sure is sweetheart. With the dramatic overall look, your rear spreader can be simple/clean. In my world maybe a tapered oval, but as I always say , I wasn’t alive back then, so I didn’t live it. Keep on keepin on.
    angelbaby65, Stogy and Budget36 like this.
  17. angelbaby65
    angelbaby65
    That’s a great idea, u like the idea of the radius on the spreader! I mocked up a piece of 1.25 stainless and I think that it’s much better in proportion for size than the 1.5…
  18. angelbaby65
    angelbaby65
    Any pics for reference?
    Stogy likes this.
  19. angelbaby65
    angelbaby65
    Started cleaning up the 34 door latches, soaked them in on overnight and the work beautifully. The bear claw latches that were in it looked like they were welded with s**** metal installed in the car so they were … a Bear To get out after a little persuasion they came out and I started to get the new ones in. Also started cutting the driver side for repair..
  20. Outback
    Outback
    from NE Vic, Oz
    This is looking great! Nice work!
    Stogy likes this.
  21. Stogy
    Stogy
    I think a curved spreader bar the Push bar attaches to looks good...straight across as well was probably more popular due to that kiss. principal, but pipe bending and rolling was closely ***ociated with racing...I was thinking a bowed back crossbar would have more bend resistance...Stainless is good and your eye knows what talks and heck there was probably guidelines depending on year...;)
    Atwater Mike, WalkerMD and Outback like this.
  22. angelbaby65
    angelbaby65
    Got the p***enger door opening and closing hood, gotta love the original paint still on the screws and door latche awesome set a few gauges in to get the feel of the dash!
    Nailhead A-V8, Shadow Creek and Stogy like this.
  23. ESGEE
    ESGEE
    from Sweden
    Really looking good, sitts just right
  24. 1-SHOT
    1-SHOT
    from Denton
    If you use that push bar you need to run it to the rear crossmember or it will fold up like a wet noodle.
    Stogy and angelbaby65 like this.
  25. winr
    winr
    from Texas
    Lookin great already !! ... and, that is around the age my Daddy got me interested in hot rods
    Can ya tell me about the 6 chrome stacks on the carburetors ??
    Have 3 WW Strombergs an have been thinkin about something like your carbs
    Ricky.
    Stogy and tr_rodder like this.
  26. angelbaby65
    angelbaby65
    They are Scott tops on 97 stronbergs
    Stogy and winr like this.
  27. angelbaby65
    angelbaby65
    What’s your guys thoughts on these bat wings? I know it’s hard to run split bones with a 5” drop axle but these bat wings do not look strong to me, am I being too worried? What’s your guys experience ? I’ve only had split bones on previous cars and I know they hold up.. I do drive my cars hard, I plan for the 33 to see dirt and gravel roads along with the street.
    Jeff34, Stogy and Outback like this.
  28. angelbaby65
    angelbaby65
    Started another thread on the wishbones and got my answers… think I’ll keep ‘em… little progress tonight I started fixing the roof on the driver side and once almost done I just wasn’t happy with the section right behind the driver door as it was mangled, and didn’t have the correct flow so i cut it out and made a patch, I’ll get it welded in tomorrow. Also got interior and exterior door handles properly working.
    Nailhead A-V8, fauj, winr and 5 others like this.
  29. Outback
    Outback
    from NE Vic, Oz
    Nice work!
    Stogy likes this.
  30. Motorwrxs
    Motorwrxs
    You are killing it…looking forward to your progress.
    Stogy likes this.
