Technical 283 sbc identification
Discussion in 'The Hokey Ass Message Board' started by Binford 6100, Apr 7, 2022.
  1. Binford 6100
    Binford 6100
    Hey guys, I am looking for a little help with a mysterious small block I have. It's a 283, casting number 3756519
    Which is a 58 to 62 block. Ok great. Now the stamping number. I can't find anything on it. I know someone here will have it no question. But I can't find it.
    It is F09I4D.
    I have added a few pictures.
    Thanks.
  2. silent rick
    silent rick
    @squirrel has always helped me on chevy numbers
  3. 427 sleeper
    427 sleeper
    What's the casting Date?
    Moriarity likes this.
  4. 31Apickup
    31Apickup
    Flint plant built on sept 14. I found two D codes, one for 1958 and the other for 1960, both list for cars and trucks, two barrel power glide. 170 or 185 hp.
    Binford 6100 likes this.
  5. Binford 6100
    Binford 6100
    So that's all the further I can break it down?
  6. 427 sleeper
    427 sleeper
    The casting date would help to narrow it down a bit, but most 283's weren't anything special.
  7. Moriarity
    Moriarity
    SUPER MODERATOR
    yup, what is the casting date??? is all you have a bare block? if it has heads are the valve cover bolts straight across or angled??
    427 sleeper likes this.
  8. fastcar1953
    fastcar1953
    1960 283 170 hp
  9. Binford 6100
    Binford 6100
    Where do I find the casting date?
  10. Moriarity
    Moriarity
    SUPER MODERATOR
  11. Binford 6100
    Binford 6100
    Its complete. But it had a smog Era 4 barrel intake on it. And its painted 70s sbc blue. I'll check the bolts.
  12. Moriarity
    Moriarity
    SUPER MODERATOR
  13. Binford 6100
    Binford 6100
  14. squirrel
    "D" is probably the most common early 283 stamping, it was used on all the boring 2bbl Powerglide 283 engines from 58 to 64.
    427 sleeper and Moriarity like this.
  15. Mr48chev
    Unless it is going in a 100% restored 58 or 62 Chevy there is absolutely no reason to break it down any further it is just a 58/62 Two Barrel Powerglide 283 and not at all exciting. It has side mount pads so you can hook it to side mounts in a hot rod if so inclined.
    There is no difference in parts for it than any other 2 barrel 283.
    lippy, Budget36 and squirrel like this.
  16. Binford 6100
    Binford 6100
    I was asking because I was wondering if it was a vette engine. If it was I'd try to sell it. But since it's not, no I don't care. It's getting a crossram and going in my 50 gmc.
    squirrel likes this.
  17. Mr48chev
    They are all Corvette engines when you put the right heads and a pair of correct for the year Corvette valve covers on them. The local Chevy dealer sold 50 sets of finned Corvette valve covers for every Corvette they sold in the finned cover days. 35 bucks a pair an another 35 bucks bought you an 098 cam off the other shelf. The parts dude kept at least three pair of valve covers and a half dozen 098 Cams on the shelf at all times in the 60's. I got in on installing some of each when I was in my teens.
  18. 327Eric
    327Eric
    58 to 62 283 is the thicker wall casting and the best one to bore to 4 inch, or so I read in the days before google
    427 sleeper and Binford 6100 like this.
  19. partsdawg
    partsdawg
    from Minnesota
    There are more ‘Corvette’ engines out there than Corvettes produced between 1958 and 1964
  20. 327Eric
    327Eric
    I bought a 56 GMC years ago, with a frozen 283 2 barrel. I pulled the crank and Rods for a guy who was restoring a 57 Vette 270 horse engine and stuck the block outside. A year later I ran the suffix code out of boredom. My parts engine was a 58 Vette 240 horse horse engine. Go figure
    SS327 and 427 sleeper like this.
  21. SR100
    SR100
    Do the heads match the block or the intake?
  22. Binford 6100
    Binford 6100
    There is not a casting date on the block in the place that it was pointed out to me.
    No, I just ran the heads, they come back as 75-79 262/267/305 heads. 1.72/ 1.30 60cc heads.
    I'm not sure that they are an upgrade or not, but I'm going to use them.
    It kinds makes sense to my thoughts. Someone had some for a smogger car that needed an engine.
    They used the ****py 70s intake and cast iron exhaust manifolds. The heads confirm my su****ion, in my mind at least.
  23. Moriarity
    Moriarity
    SUPER MODERATOR
    look here.....
  24. squirrel
    this should be the beginning of the date code
    Deuces, 427 sleeper and Moriarity like this.
  25. Binford 6100
    Binford 6100
    That's it. Only the "1" you can see.
    Guessing that means it a 61 block.
  26. Moriarity
    Moriarity
    SUPER MODERATOR
    how about posting a picture of that part of the block?
  27. Binford 6100
    Binford 6100
    Sure, I'll grab a picture in the morning. Enjoying the fireplace and a gl*** of wine right now.
    squirrel and Moriarity like this.
  28. 427 sleeper
    427 sleeper
    1 in the first position doesn't make sense. "L" does. December. Something ain't right, here. What give's?
  29. squirrel
    don't put too much stock in the shape of the characters on the old date codes...but seeing all of what's there between the screws, would help.
    Desoto291Hemi and 427 sleeper like this.
  30. Binford 6100
    Binford 6100
