Projects Mild custom '51 Pontiac Chieftain
Discussion in 'The Hokey Ass Message Board' started by PhilA, Nov 4, 2019.
  1. v8flat44
    v8flat44
    Phil, I can hear Willie singing "On The Road Again".... and the sweet soung of that GR8 straight 8; good for you.
    Stogy and PhilA like this.
  2. v8flat44
    v8flat44
    Ooops sounD . DDD, not g
  3. PhilA
    PhilA
    Another smile.
    Been humming that all day long today.
    Stogy and Bruce A Lyke like this.
  4. Or Gene Autry..."I'm back in the saddle again."
    Stogy, PhilA and v8flat44 like this.
  5. PhilA
    PhilA
    Yuck.
    I think the seal was a little too good along the bottom!
    Cut a slice of it away, cleaned up. Lens is in the dishwasher.
    Phil
  6. Bruce A Lyke
    Bruce A Lyke
    Or too bad on top?:rolleyes:
    Woogeroo, Stogy and PhilA like this.
  7. PhilA
    PhilA
    Gl*** half full, half empty.
    Either way, it can drain now. I cannot see where it was getting in.
    Stogy, Bruce A Lyke and bchctybob like this.
  8. v8flat44
    v8flat44
    Lenz needs a drain notch.at the bottom ..... I used to do moisture testing at Ford in the 80s/90s, amazing how leaks showed up in what seemed to be a "perfect" ***y. Drain notches & vents were common on some park & rear lamps.
  9. PhilA
    PhilA
    Working on the garage a bit today.
    Slowly getting somewhere.
    Sat down with lager & lime and some nonsense on the TV. Doesn't look like much but that was hard work.
    bchctybob, 51pontiac, Stogy and 5 others like this.
  10. Holy ****, man, you took a HIT! Hope you managed to save the mural.
  11. vtwhead
    vtwhead
    Did the Pontiac mural survive?
    Stogy likes this.
  12. PhilA
    PhilA
    Tornado. The mural survived, it's behind the door in the workshop, the only part of the building still standing.
    I need to pull it all down and start over, the remaining parts are all twisted.
  13. Bruce A Lyke
    Bruce A Lyke
    S
    Sorry that you are having to deal with this:(
  14. PhilA
    PhilA
    Hey. It is what it is. Pick yourself up, dust yourself off and start fixing up.
    bchctybob, Woogeroo, SS327 and 4 others like this.
  15. Stogy
    Stogy
    Phil it looks like you can build the new generation brick ****house of shop using a portion of the old...the pad is still intact too...that helps to some degree too...
    PhilA likes this.
  16. PhilA
    PhilA
    Some of the wood is good, but most of it has suc***bed to the ravages of Louisiana humidity. A good portion of it dates to the late fifties, and is well seasoned wood. I've had a large number of carpenter bees decided to move in and they need to be made very very gone- they're not particularly aggressive but they are almost as destructive as termites. I don't want the new building to be provided with a self destruct mechanism.
    The pad is good, as is most of the foundation so something can go back up- even if it's not as big (I don't need such a tall building, it was created to house a boat originally, then extended to take an RV) but shelter and workspace is a nice thing to have.
    Phil
    bchctybob, Bruce A Lyke and Stogy like this.
  17. PhilA
    PhilA
    Hm. I need to pull the radio out and put it on the bench. It's all crackly and clipping, particularly at low volume.
    Another thing on the list.
    Phil
    Edit: Also need to check the valves. What is the opinion of Berryman B12? I need to get some lubricant on the top end of the valve stems. One of the valves is a bit sticky until everything warms up.
    (I know the answer is to pull the head, pull the valves and clean the guides but that's a lot of work...)
    Cut down the tree that got blown over and mowed the gr***.
    Still more to tidy up and the bees are taking an interest in the woodpile.
    Still, the weather's nice, I got sunburned and it's beer o'clock. Cheers.
    Mtn Goat, pivir123, brEad and 10 others like this.
  18. PhilA
    PhilA
    Full engine rebuild:
    Rebuild in a can.
    Bring the thunder!
    Some hydrocarbons occur. Rebuilt!
    Idle is better, which is good. The intake valve that was clicking up front has shut up. Exhaust 8 is still noisy. Poured a bit of MM oil down it while cranking it over. That can sit now.
    My neighbors love me.
  19. Next time you do that, back it up to the wood pile and give the wood bees a treat! Two birds with one stone!
    brEad, bchctybob, Ford52PU and 4 others like this.
  20. PhilA
    PhilA
    Went drive the car and this afternoon it got a bit stuttery and was running a bit warm. Fuel starvation leading to a weak mixture. Thinking it was vapor lock, I pulled on the boost pump. Stink of raw gasoline enters the cabin. Not good. Switch that off and slow down some.
    Got home, popped the hood and took a look see.
    Looks a little damp but that's mostly oil.
    Boost pump on, fuel comes ******* out in a stream from between the bowl and pump. Ugh. Looks like the seal has failed, hopefully it's not cracked.
    Waiting on it to cool down to pull apart.
    Phil
    bchctybob, Woogeroo and Stogy like this.
  21. PhilA
    PhilA
    Nothing majorly amiss but the sediment bowl wasn't particularly tight.
    I might pull it off and re-torque it all. However, as I was working it got so windy and sideways rain suddenly that I was caught by surprise as the hood was lifted up off the prop. Glad I caught it!
    That's for a drier day...
    Phil
    bchctybob and Woogeroo like this.
  22. PhilA
    PhilA
    Nothing wrong, just needed tightening up a scosh.
    Back in, running, with the boost pump on. Totally dry.
    While I was at it, I set the idle mix and spark timing. It's easiest setting it in Drive with the brakes on, against the load of the fluid coupling. Set up for highest vacuum at lowest idle. Then reset to 375 RPM in Drive.
    Will give that a test run after dinner if time permits.
    Phil
    Stogy, bchctybob, Woogeroo and 4 others like this.
  23. PhilA
    PhilA
    Test drive successful. It's got a slight warble at light throttle cruise (~2000 rpm) suggesting a valve not closing fully- it goes away under heavier load. Compression test will show that if I can find my gauge in the rubble. Might also be a valve spring gone soft, thinking of it.
    Need to tweak the timing slightly, it is pulling very well a little low down the rev range. Just a degree or so will sort that.
    Need to clean and gap the points, then redo the timing. Apart from that, it is running better than it did when I started, so that's a bonus.
    Phil
    Stogy, brEad, bchctybob and 4 others like this.
  24. PhilA
    PhilA
    A few up and downs the highway, and I think I got it dialed in.
    45 mph I am holding 16-17"Hg and the warble has settled to a thrum- what I thought was a misfire is actually the harmonic of the exhaust. It's never really had that before. Picks up well and no longer coughs when it's hot, runs just about 175° just as the thermostat starts to open (180 stat).
    Now, I think I need some slightly better quality transmission fluid that holds viscosity when it's hot, and I'll be about set.
    Phil
  25. Pontmerc
    Pontmerc
    from Finland
  26. PhilA
    PhilA
    Yes. Hydra-Matic. It's running a DEXRON-III oil right now, which is fine when it's cool but gives trouble when it gets hot in the valve block.
    Phil
    Stogy and bchctybob like this.
  27. Pontmerc
    Pontmerc
    from Finland
  28. PhilA
    PhilA
    Stogy likes this.
  29. v8flat44
    v8flat44
    At Phil's Garage, "progress is our most important product". Keep on keep'n on Phil !!!
  30. PhilA
    PhilA
    This perpetual rain is a hindrance. Dry for a day, wet for a day .. repeat.
    Other things around the house have been taking precedence. I need to cut the old fence up and put it to the street for trash. Yesterday was taken up with a little side project that I needed to get on with, going to the store to buy groceries and trying to sort my old lawn tractor which is at my mother in law's property.. need to mow that.
    It never ends.
    Stogy, bchctybob, brEad and 2 others like this.
