Hot Rods 29 RPU- "Street/Strip" B/SR Build - Marty Strode
Discussion in 'The Hokey Ass Message Board' started by Marty Strode, Dec 19, 2019.
  1. Johnny99
    Johnny99
    My louver press no problem. Like Marty said "it's having the die set". Cant imagine to many of that particular die set was made commercially, pretty specialized. Guys that do a lot of aero/race car panel stuff or the guys that supply the guys that do a lot of aero/race car panel stuff would most likely have this set up.
    Stogy likes this.
  2. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    True. There are also two common sizes of spring retention clips - one with 1 3/8" spacing and a smaller one with 1" spacing. Dies are needed for each.
    bchctybob and Stogy like this.
  3. Marty Strode
    Marty Strode
    Since I will be hauling the RPU in my COE, I am going to work back and forth on both projects. I have been needing to build some mirror brackets, that utilize the slot in the door, on Ford trucks from 53 to 66. I didn't want commercial "Ape Hanger" mirrors, so this is what I built, after sourcing the mirror heads. The tube is 7/8" .065 4130, and the rest is just some machining and welding. I even had a buddy, a professional Truck Driver, sit in the seat, and give me instructions on placement and angles. I am going to mount some 3" convex, blind spots as well. I had hoped to get away without adding another strut, to stop the vibration, but I will add a 1/2" tube for that reason. IMG_8750.JPG IMG_8754.JPG IMG_8758.JPG IMG_8761.JPG IMG_8770.JPG IMG_8775.JPG
    bchctybob, OFT, rod1 and 16 others like this.
  4. Johnny99
    Johnny99
    Nice. Guessing you did the flanged step pads and fender anti scuff pad too? The stamp made me chuckle, as I've gotten older, I tend do that a lot more myself.
  5. Marty Strode
    Marty Strode
    If I had been able to buy original rubber for the steps, I certainly would have, but I made the aluminum guards. I am going to have those pieces, along with some inside scuff moldings clear anodized, to preserve the aluminum. As far as the stamping of parts, I do it out of habit, and in most cases, to help the guy down the road to figure out what pieces go where.
    OFT, brEad, Stogy and 1 other person like this.
  6. oldiron 440
    oldiron 440
    You done really nice work but I have driven truck and I can’t imagine those single posts holding a mirror stable enough to be useable. Road vibration combined with wind are tough elements to deal with.
    OFT likes this.
  7. Marty Strode
    Marty Strode
    In my post, I stated that an additional strut would be required to deal with the vibration, it will be done when the blind spots are added. I just didn't want West Coast style mirrors. West Coast Mirrors.jpg
    Stogy and Just Gary like this.
  8. Nice job on those mirrors Marty. This is my buddy's COE, when he wrestled with the mrror issue, he found his solution on a cast away wheelchair. They were part of the leg supports I believe. I don't have the best photo of them, but you get the idea. Solutions can be anywhere with a bit of imagineering.
    bchctybob, brEad, Stogy and 1 other person like this.
  9. Marty Strode
    Marty Strode
    Thanks, I see your buddie kept the Signal Stat lights on top of the fenders on his 54. We were able to find NOS amber lenses for mine, they are original to the truck. IMG_2964.JPG
    Toms Dogs, bchctybob, brEad and 2 others like this.
  10. dwollam
    dwollam
    Marty, how long is the steering arm on your 525 steering box? I am looking for a longer one for my 525 in my '33 Plymouth w/Hemi as currently the steering is way too slow, albeit very easy steering. Mine is a stock arm.
    Dave
    Stogy likes this.
  11. Marty Strode
    Marty Strode
    Dave, the one on the RP is 7".
    Stogy and dwollam like this.
  12. dwollam
    dwollam
    @Marty Strode , Thanks! I ***ume that is center to center?
    Dave
    Stogy likes this.
  13. Marty Strode
    Marty Strode
    Yes.
  14. Marty Strode
    Marty Strode
    The aluminum seats I ordered from Speedway are supposed to be here tomorrow, so I spent part of 2 days this weekend building the frame to carry them. I used 3/4" -.065 wall tube and 10 ga plate for the bases. The next thing is to make some mounting tabs to weld to the frame. The base mountings bolt directly to the frame rails. I used one of seats out of my Track Roadster project for setup, same seat. IMG_8779.JPG IMG_8781.JPG IMG_8783.JPG IMG_8784.JPG IMG_8787.JPG IMG_8789.JPG IMG_8790.JPG IMG_8792.JPG IMG_8793.JPG IMG_8794.JPG IMG_8795.JPG
    bchctybob, OFT, Graham08 and 14 others like this.
  15. Marty Strode
    Marty Strode
    The seats came yesterday, I got the mounting tabs tacked on, and the seats bolted in place. I am going to retain the wood molding around the back of the cab, but it will require bandsaw work. Also, I am using a Sweet MFG stainless u-joint, great looking piece.
    Toms Dogs, bchctybob, OFT and 10 others like this.
  16. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Boy Marty, that shifter does look like it was made for that combination. I've never had one that fit in that well.
    Couldn't find one in my old Hurst catalog that was for a, "Model A pickup with SBC and Ford top loader".
    Those Sweet u-joints are sweet aren't they. Randy was quite the character.
    Speedwrench likes this.
  17. Marty Strode
    Marty Strode
    I got the wood coved out, to match the curve in the back of the seats. Nice Black Walnut. IMG_8804.JPG IMG_8805.JPG IMG_8806.JPG
    bchctybob, OFT, brEad and 4 others like this.
  18. Marty Strode
    Marty Strode
    Today, I started on one of the only jobs I have promised to do, for @fgnailhead34 , a roll cage for his 554 Coupe inspired 34. We looked at different ways of doing it and making it certify, and I convinced him that an Altered/Funny Car cage would be the safest, and the easiest to do the interior sheet metal. I did one in the Bizio Truck in the 90's, that still p***es tech today. So, we started by laying out and bending the front hoop, and getting it tacked in place. More to come tomorrow. IMG_8808.JPG IMG_8809.JPG IMG_8812.JPG IMG_8814.JPG IMG_8815.JPG IMG_8817.JPG IMG_8820.JPG
    Toms Dogs, bchctybob, OFT and 18 others like this.
  19. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I like how tight your tube miters fit.
  20. Stan Back
    Stan Back
    Make sure to leave room for the blower.
  21. Marty Strode
    Marty Strode
    We got the shoulder hoop and rear uprights in today. Tomorrow we will work on the front cage loop, and the bent L's over the top of the driver's head. I am waiting for a call from the local inspector, to make sure all of the uprights and diagonal bracing we have planed, meet his approval. IMG_8822.JPG IMG_8826.JPG IMG_8831.JPG IMG_8839.JPG
    Jet96, jaracer, bchctybob and 17 others like this.
  22. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    I see a Quickchange back there :D Oh Boy, Oh Boy!
  23. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Oh, and the roll cage looks good too!
    Is your coping jig something you made or is it commercially available?
  24. Marty Strode
    Marty Strode
    Bruce, it's a Pro Tools, works great. I have an old Speedway unit, that is used in the drill press, but this is far handier !
  25. Marty Strode
    Marty Strode
  26. Marty Strode
    Marty Strode
    My long awaited right front fender got back from the paint shop today, and it got installed, along with tweaking the braces on both sides. Next on this one is making an aluminum front valance to work with the mounting of the Moon Tank. IMG_8842.JPG IMG_8843.JPG IMG_8844.JPG
  27. Marty Strode
    Marty Strode
    We did also get the front hoop on the cage in Derrick's 34. With the width of the shoulder hoop, I was concerned the about how clunky a front hoop with 2 bends and a small flat area would look. So, we experimented with a single bend with a 6-5/8" radius, and a pointy center, giving it a 60's look. Coping a hoop with the angles, and holding center widths can be tough, but 8 years ago, I devised a method that works well for me. I bend a hoop, using exhaust tubing, and cut and cope to the rough angle on a couple 6" stubs of exhaust tubing as well. The thin pipe is pliable and easy to spread, or pull together for a test fit, and with the stubs, you can rotate the ends to make the copes fit the shoulder bar. With it held in place, I use radiator clamps to hold the stubs in the correct rotation, until I can tack weld them on. Once you have a sample hoop that fits, you can bend the real one to the proper angle, and trim the ends to the length to match the sample. Once that is done, you install the sample in the fixture, do a fine adjustment, making the cope hug tightly around the hole saw, and record the angle of the pipe with a digital level. Install the real hoop in the fixture, setting it at the same angle, and run the hole saw. Repeat on the other side of the hoop, and presto, you have a hoop the fits very well. IMG_8845.JPG IMG_8847.JPG IMG_8848.JPG IMG_8849.JPG IMG_8850.JPG IMG_8851.JPG IMG_8854.JPG
    alanp561, Toms Dogs, Jet96 and 16 others like this.
  28. dwollam
    dwollam
    @Marty Strode , play day at Madras Speedway is April 16th 12-4pm. Gonna bring something over?
    Dave
  29. Marty Strode
    Marty Strode
    Dave, I don't have anything to race, except my old buddy Ernie Martin's Roadster, and the vintage races for this type of car have petered out. IMG_7868.JPG
    Toms Dogs, ottoman, OFT and 1 other person like this.
  30. dwollam
    dwollam
    Marty it is test and tune/play day so I would ***ume you could probably run it, at least solo.
    Dave
