Projects 1956 Pontiac Chieftain Brake Questions
Discussion in 'The Hokey Ass Message Board' started by Clint Lovell, Apr 12, 2022.
  1. Clint Lovell
    Clint Lovell
    After 8 years of sitting in the garage undriven, I'm getting my Chieftain in shape to get back on the road. When I parked it in September of 2014, it was to replace the floor pans. Got the engine going again with a new coil and a little attention to the points. But now, my brake pedal goes to the floor and doesn't return on its own. I haven't had time to crawl underneath and look at the master cylinder an d brake lines, but I suspect the problem is in the master cylinder which is the stock single reservoir model. Back in 2014, I acquired Scarebird's front disc brake conversion and purchased everything except the Wilwood dual reservoir master cylinder, though I did get Scarebird's bracket. What I would ike to do is to go ahead and change out to the Wilwood 260-7563 master cylinder, locate and replace any leaking components (if there are any) on the stock system, and get it driveable, then do the front disc conversion.
    My question is about what I need in the way of a proportioning valve and residual valves for the stock drums, and same for the front disc/rear drum setup. I would like to hear from others who have used this conversion and what they did and their results.. Thanks.
    Clint Lovell
    Greenwood, LA
  2. bob b.
    bob b.
    from peoria az.
    always buy a complete kit I bought mine from speedway 10 years ago never had a problem
  3. petersyl
    petersyl
    Sorry, can't answer your actual question but I would be interested in seeing how you mount the MC and booster; I need to do something similar on my 57... tx.
  4. BJR
    BJR
    If the car has been sitting since 2014, you will probably need to replace all the wheel cylinders, and the master cylinder. Brakes don't like to sit unused.
    egads and bobss396 like this.
  5. bobss396
    bobss396
    And the hoses. Don't spend a lot of $$ if you have most of the disc parts on hand. Go for it.
  6. Clint Lovell
    Clint Lovell
    What brake fluid do you recommend in this 56 Pontiac?
  7. Clint Lovell
    Clint Lovell
    Yes. I have the installation sheet in my hands.
