Technical Where did I mess up with priming?!?!
Discussion in 'The Hokey Ass Message Board' started by 41Helen, Apr 12, 2022.
  1. NoelC
    NoelC
    Looks like dry spray to me. What speed of reducer did you use? Fast, medium or slow? I bet it was fast, hot out, and a light breeze blowing.
  2. 41Helen
    41Helen
    I didn’t use any. The tech sheet said 3:1 primer to catalyst.
  3. 41Helen
    41Helen
    Thank you both for that!
    Rickybop and chryslerfan55 like this.
  4. 41Helen
    41Helen
    Perfect! Thank you for this detail!
    Rickybop, chryslerfan55 and Moedog07 like this.
  5. loveoftiki
    loveoftiki
    from Livonia,Mi
    Head up….most epoxy primer sands like dog ****….
    41Helen likes this.
  6. Poverty cap
    Poverty cap
    Clean the paint gun really good, check that the fluid needle is open all the way when the trigger is pulled all the way open. Reducing the primer as some have said is probably required, the temperature of the primer could be a issue, it may need warming up some..
    chryslerfan55 and 41Helen like this.
  7. KenC
    KenC
    with a 1.4 tip, a reducer is needed with most epoxies , actually any primer. Reduce 5% or so and test spray. Up to 10% is allowed in some, but check your data sheet. I wouldn't wait, just wet sand, that will keep the epoxy from clogging the paper. And, I see no need for more epoxy, just sand flat and add high build.
  8. 1st, check to see if the vent cap on the cup is plugged. 2nd, make sure the bottom of the handle adjustment is open to full flow. I shoot epoxy all of the time and don't need to thin or reduce it. I have a regulator on the gun that is set at 38 psi on a purple gun. If you don't find anything up to this point, take the gun apart and clean it completely. Because your 1st attempt was smooth, I think you have a gun problem. However, I have not used that brand of epoxy.
  9. guthriesmith
    guthriesmith
    I’m in the “too small of a fluid tip” crowd. I had the same results recently trying to spray filler primer through my gun I paint with. I knew better, but tried it anyway and was reminded that it doesn’t work well. :rolleyes: Pretty sure my paint gun is a 1.4 and my primer as 1.8 as mentioned by others above. Most primers are too thick to atomize correctly through a 1.4 fluid tip. ***uming the first primer you sprayed was thinner, thus the difference.
  10. 41Helen
    41Helen
    Thank you all for the advice! I have gone ahead and hit it with 220 grit and cleaned the panels. I bought some U-Tech High Build Primer and bought a new gun with a 2.0 tip. I have double checked the TDS to confirm no reducer and I have the right tip. I have set up a few test panels to make sure I am dialed in. I am just going to spray the high build and go from there! I appreciate all the feedback!!!
  11. 41Helen
    41Helen
    I think you are correct. In my haste I may have read the TDS wrong. With a 1.4 tip, I needed 1 part reducer.. Completely my fault. Chalk it up to a learning lesson.
  12. 41Helen
    41Helen
    It wasn't a gun problem. 100% operator error, I checked the TDS again. With a 1.4 tip, I was supposed to use 1 part reducer... Learning lesson...
  13. 41Helen
    41Helen
    This! 100% this... I misread the TDS, with a 1.4 tip I was supposed to use 1 part reducer. Attention to detail fail.
  14. 41Helen
    41Helen
    haha yes it did.
  15. NoelC
    NoelC
    Well you have a choice to make, slow, medium or fast. I'm going to suggest slow or medium.
  16. theHIGHLANDER
    theHIGHLANDER
    Don't hang up on the 7 day thing. Once dry, recoating is fine. While their CYA (cover your ***) rating of 7 days is listed any possible scenario is included. Cold day, hot day, service parameters, blah blah blah. Generally 36 hours is a recoat window WITHOUT sanding in most epoxy primers but I never go more than 12 to 15. Even then I grey pad a bit.
    Sometimes you need more than the data sheets. Dig deep into online info sites. Tech data, MSDS, testing sheets, a real clear understanding can be had doing that, but not always needed for the casual enthusiast finisher. Good luck, don't panic, have fun.
    Rickybop, chryslerfan55 and 41Helen like this.
  17. 41Helen
    41Helen
    Thank you for this. I needed to read this.
    I went ahead and hit it all with 220 grit anyone to be safe. Tonight I am going to spray my high build, after many test panels haha.
