Projects Building My First Roadster in San Francisco
Discussion in 'Traditional Hot Rods' started by J.Ukrop, Sep 7, 2020.
Tags:
  1. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    That's all for tonight. Next up, we'll be talking front suspension, spindles and more. Stay tuned! IMG_2957.jpg
  2. ESGEE
    ESGEE
    from Sweden
    Just found the tread, Looking good this far
    Stogy, J.Ukrop and Six Ball like this.
  3. Tim
    Tim
    from KCMO
    Fantastic update-s!
    love the driving about town shots and everything else.
    what are the other pieces of your score from the sale? I can’t quite place them but they look neat!
    you’ll have a driving ch***is in no time at this rate :)
  4. Tribalmonkey
    Tribalmonkey
    Joey, I just read through several pages to get caught back up. Very cool start on your Traditional Hot Rod V2. Now I have quick change envy. So much fun!
  5. El Hueso
    El Hueso
    You don't have a washer/dryer at your home?
  6. trad27
    trad27
    Looking good, when I retired my harbor freight and finally bought a real welder I knew I had to have a tig. Can't beat the quality of welds and versatilety able to weld aluminum, sheet metal and everything in between but I have to admit i wish I had a mig sometimes. Everything is a process with tig, sometimes wish I could just plug in a pull a trigger for a quick tack or something little.
    Spoggie, J.Ukrop and Six Ball like this.
  7. Tim
    Tim
    from KCMO
    Id ***ume that if his apartment has laundry machines they are either several floors away from the garage or communal for the building and they probably aren’t mega stoked on him in plugging a machine and running a cord down the hall.
    J.Ukrop likes this.
  8. Jeff34
    Jeff34
    Or it's a gas dryer like mine.
    GREAT stuff, Joey! Keep on it! If it's nice, I'll be rollin' around town this weekend.
    J.Ukrop likes this.
  9. Joey, thanks for considering me as a friend. It means a lot to me. As for the Broadway Tunnel, IIRC it is about 1/4 mile long. Yes, we drag raced through the tunnel. The only worry was the stop light at the far end of the tunnel. Not the North Beach end.
    J.Ukrop, Outback, WalkerMD and 3 others like this.
  10. 41 GMC K-18
    41 GMC K-18
    @J.Ukrop
    Another cool place for awesome neon back drop photos, is out in front of the CASTRO theater!
    Keep the cool shots coming!
    J.Ukrop, Outback and Six Ball like this.
  11. Six Ball
    Six Ball
    from Nevada
    Friend? Hell I was going for Grandpa!:rolleyes: Thanks for thinking about me at all. SF at night was a special place for a lot of my life. All tunnels are cool in hot rods. :eek: The Caldecott Tunnel from Orinda into Oakland is sometimes a rabbit hole into a different climate valley heat to bay fog.
  12. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Thank you! We're having lots of fun, and we have some big things planned.
    Thanks Tim! I've been driving more than I've been posting, that's for sure. The car is running excellent.
    So, that's the big question. I believe they're Midget rear suspension components from the 1950s. Interestingly enough, they're cast steel that's been chromed. If you look closely, there's a name cast in there. I'll take a detail photo tomorrow. My first thought when I saw them? Headlight stands. I'm pretty sure I'm not going to run them, but they could be fun to mock up!
    Right now the goal is roller by summer, driving by fall. Not a day goes by that I'm not working on this thing!
    Thank you, Mark! I'm glad that I can follow your builds on Instagram too. No shortage of fun happening in either of our garages!
    Hahah I do. The problem is that our place turns 100 this year, and when you walk the lights sometimes flicker...
    In a perfect world I'll have a MIG and a TIG in my life. Maybe even a front yard too...
    You got that right!
    We missed you this weekend! We have an exciting day planned for this upcoming Saturday, though.
    You're for sure a friend. I even keep your business card in my desk! I told my friends about the Broadway Tunnel drag racing and they were shocked and excited. It gives me goosebumps knowing that I'm driving the same streets as the hot rodders of yesteryear. I have an article in the works that I think you'll appreciate.
    For sure! Back when I lived on Corbett in Twin Peaks, you could see the neon glow from a mile away. I'll snap a picture next time I'm there with the roadster.
    Hahahah I'm always thinking about your adventures as I cruise around the area. Oh man, Caldecott Tunnel is a fun one for sure. I remember ripping through it on my motorcycle one night after a party in Martinez. Seeing that it was sunny when I left San Francisco, I only brought sungl***es. Well, when nighttime fell, I realized I would have to ride home sans eyewear. Not ideal! Especially on bias ply tires with no front fender on a half-century old bike. At least I got a good shower from the puddles at the mouth of the tunnel.
  13. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Ever since day one, this project has been about learning. In the past two weeks, David has helped me demystify so much of the hot rod building process.
    It all started with the bare frame on the floor.
    Then we laid everything in place.
    And then we pushed out the old bushings on this spring perch using a modified KR Wilson tool. IMG_2960.jpg
    Out with the old.
    After I sandblasted the perches, David gifted me a set of bronze bushings machined by his friend Jerry. They're perfect. He then showed me the correct way to dis***emble a spring using clamps and all-thread.
    This is exciting stuff!
    I blasted the old U-bolts and related hardware.
    And then we ate lunch.
  14. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Since the original crank clamp won't work with the Deuce radiator and grille shell, David welded a block to the bottom to make up the difference. IMG_2978.jpg
    We were both dead-set on using original U-bolts, which took a little bit of convincing to work with the So-Cal front crossmember. But it's all together now, and I'm really happy with how it looks.
    Last Saturday, we were confident that we could get the front end together. Unfortunately, I discovered that my '35-'36 Ford spindles will not work with the four-inch dropped '32 axle and the '37-'41 kingpins. Luckily @Hitchhiker is the man and set me up with a set of round-back spindles that will be getting here later this week. It's hard to say for sure, but I think they came from the same old hot rod as my perch pins. We'll see.
  15. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Right before I left the shop, David showed me how to remove rivets with a torch. He perfected this technique while working at Vern Tardel's infamous Prune Orchard, and it's incredible to see how easily he can make the metal do exactly what he wants. "Cutting, bending, cleaning—the torch can do it all," David told me as 90-year-old rivets popped from the Model A crossmember.
    IMG_2974.jpg That afternoon, he gave me a homework ***ignment: have the crossmember trimmed to the exact width (39 9/16ths) and cleaned up by the time I came back. IMG_3091.jpg
    So I did exactly that. I'm sure the neighbors enjoyed it.
  16. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Last Saturday, we jumped right in. We started by setting the narrowed crossmember into the frame and removing bushings. Next, David taught me how to correctly remove a torque tube from an early Ford banjo.
    It was fun to finally tear into this thing. I was surprised that nothing was seized or even stripped. We'll be shortening the torque tube once we get the quickchange in place. IMG_3099.jpg
    Some of the work even required a very small wrench.
    Salvageable hardware.
    On Saturday afternoon, gray Petaluma skies transformed into a clear blue day. We took a customer's 1945 Ford GPW for a test drive during lunch. David had just revived it from a long slumber, and it ran perfectly on our trip to town. I had never been in this early of a Jeep (type vehicle), but I had a blast riding shotgun. With its flathead four, three-speed transmission and solid axles, it's amazing how similar it feels to my roadster.
    Other visitors included our pal Sonny and his HD Servi-Car and one of David's customers in their 1967 Crown bus.
    The bus is an absolute behemoth, and the inside is a total time-warp with its streamlined features throughout.
    Once the visitors had come and gone, I used a pair of homemade C-clamps to help dis***emble the rear spring. Three leafs were removed, and we slid everything into position. IMG_3111.JPG
    All the rear end components are on loan from my friend Aaron. My quickchange leaves Texas in the morning, and I'm already counting down the days until I can unbox it! IMG_3112.jpg
    We're now up to speed on the fabrication and ***embly. I have a few small updates that I'll throw in when it's time, but more on that later.
  17. Tim
    Tim
    from KCMO
    Well dang!
    J.Ukrop and Stogy like this.
  18. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    Keep going Kid.
    Great journey you are on.
  19. Outback
    Outback
    from NE Vic, Oz
    Awesome work mate! You are certainly kicking goals!
  20. kevinrevin
    kevinrevin
    from East Texas
    Looks great, Joey. Are you putting a coupe body on this ch***is with the flathead?
    Two cars are better than one. A banger roadster for the sunny days, and a flathead coupe for the cold or rainy ones
  21. Jeff34
    Jeff34
    Great stuff, Joey! Keep it goin'
    J.Ukrop likes this.
  22. Atwater Mike
    Atwater Mike
    Wow, Joey! Your Deuce frame looks like a twin to mine, (but going under my '27 T Touring body)
    Nice work on the front end, the 'U' bolts and clamp turned out very 'sanitary'.
    Strictly by habit, I incorporated a dead perch on the p***enger side of mine. Old ones die hard...
    41 GMC K-18 and J.Ukrop like this.
  23. Atwater Mike
    Atwater Mike
    The caps you're using: HRM coined them "Baldies", that's what we always called 'em. Used to be in stock at San Jose American Auto, Urzi's, and Grand Auto... 2 bucks each. First saw (and bought) them in '55, Norm Grabowski had 'em on the 'Lightnin' Bug', with 15" black steelies and wide whites. We followed suit.
    Seeing the movie "Hot Rod Gang", John Ashly was driving Scritchfield's '32 roadster, 'chariot racin' with the bespectacled character in the Tony LaMasa roadster, beating the baldy caps to death!
    My buds Rams (channeled 'A' Coupe) and Wimpy ('32 highboy 5 window) and humble self (channeled '31 Cabriolet) got onto the wheel-to-wheel 'chariot thump' on El Camino Real, between Santa Clara and San Jose...
    Second gear, 35-45 MPH sounded like full throttle to the shocked citizens lining the street... and the clashing of hubcaps added to the carnage!
    Rams discovered a lot that sold new & used small 'house' or 'camp trailers', and all of them had BALDY CAPS!
    Took all of 30 minutes one dark night for him and Fat Tommy to empty the trailer lot of the whole stock of Baldies!
    Never counted 'em all, but there were stacks of the bulbous caps in his ba*****t.
    They stacked 'all crooked', like bowls on the shelves of a greasy s****... We had baldies all day...
    This was about 32 miles south of S.F., Santa Clara... "There used to be a town..."
  24. Big mike 1968
    Big mike 1968
    Frame and suspension are really coming together, looks great.
    J.Ukrop and 41 GMC K-18 like this.
  25. Outback
    Outback
    from NE Vic, Oz
    @J.Ukrop just out of interest what are the wide 5 drums on your friends diff? (Sprint car I'm guessing?)
    J.Ukrop likes this.
  26. Six Ball
    Six Ball
    from Nevada
    Lots of great progress! We are all benefiting from your education.
    The craziest Caldecott Tunnel story I ever heard was form my mother in law. In the '30s she and her high school friends would drive through the wrong way! Only two tunnels back in those days.
    Outback, J.Ukrop and Beanscoot like this.
  27. Go Joey go!! Looking good. Making some excellent progress. Love the updates so please keep them coming.
    Brian B
    Six Ball, Outback and J.Ukrop like this.
  28. Hitchhiker
    Hitchhiker
    We're the perch pins orange too? I've forgotten.... Definitely the same car if so. They all came from the same horde. Wallingford area of Seattle, not sure where he got them, but he had been going to local swaps since the 50's. I even have the split wishbones, that i am using in my 29 AV8 i am about to start building.. I had some orange headlights too that I sold years ago.
  29. Budget36
    Budget36
    To be honest Mike, you should still be pining for your parole;)
    J.Ukrop likes this.
  30. Budget36
    Budget36
    Was it the Caldecott a fuel tanker was in a wreck, big explosion…I think in the late 70’s or early 80’s I was a kid but recall something like that on the news.
    Dang, now I gotta Google it.
