Hot Rods 57 FORD Build #2... Glutton for Punishment.
Discussion in 'The Hokey Ass Message Board' started by Jeff Norwell, Oct 20, 2021.
  1. I will never understand why people always want to part out 4 doors, even the one I have, the original owner said many people wanted to part it out, its one of the reasons he sold it to me instead of others who offered, because I wanted to put it back on the road and not just part it.
  2. Squablow
    Squablow
    That's what I was wondering too. If that car were in Wisconsin people would be all ga-ga for it since it's not a bag of rot.
    In the end it seems like all of the parts were used and the rest got built into something, so no real harm done, but would have been a terrible shame if it did get scrapped.
  3. Its kinda weird to think, these cars were supposed to last maybe 5 years, at most, and here they are, 65 years later.
    Jeff Norwell likes this.
  4. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Cmon… you all can surmise until the cows come home…
    I saw that car, inspected it and took what I needed.
    floors were completely gone… interior was destroyed, the 272 was Seized… the Ford-o-matic was not only toasted… they were a horrible transmission… the front end was deteriorated beyond fixing as the front crossmember was Swiss cheese.
    It was J U N K .
    Be happy it made a second life as a race car… and 7 people saved their cars.
    GordonC, Landmule, enloe and 19 others like this.
  5. lothiandon1940
    lothiandon1940
    ..........Well said, Jeff.
    enloe, Stogy, SilverJimmy and 3 others like this.
  6. bobss396
    bobss396
    Not all cars can be saved. Great that parts went into other projects and the car lives on the track, looking real sharp.
    Stogy, Thor1, guthriesmith and 2 others like this.
  7. lippy
    lippy
    from Ks
    I gotta give em credit. There are a lot of diehard gearheads here that would cross the amazon in a Hippo paddelboat to save a rotted out hood off an opel kadett.:D
    Stogy, Thor1, dalesnyder and 5 others like this.
  8. Roothawg
    Roothawg
    Progress is good.
    Stogy and Jeff Norwell like this.
  9. Where did your used parts come from? Ultimately the real answer in fact is $$$$ when you get right down to it. Afterall that's what drives everything. Let's get back to building something.
  10. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Anyhow...... moving forward.....
    My final parts arrived...... finally. my Robbmc starter arrived,. I needed this as the solenoid can rotate 360 degrees... fit like a charm,
    also received my fuel canister and mount.... mocked it up... and I will continue with the 3/8's line...
    Plan to go and get my driveshaft cut and spun up with an accurate measurement of 57-5/8's...
    and starting to assembly the throttle linkage.
    Keep pushing forward....
    GordonC, alfin32, Deuces and 16 others like this.
  11. that is a beautiful motor, not a speck of oil or rust on the outside of it.
    Deuces, Stogy and Jeff Norwell like this.
  12. The shine on those valve covers looks fantastic! Did that come from spray bombs? If so, what's your secret?
  13. Jeff Norwell
    Jeff Norwell
    MODERATOR
    No. painted by a friend in his shop
    The same guy working on my other 57
    enloe, Stogy, Thor1 and 3 others like this.
  14. Damn, I thought you might have tripped upon the holy grail of spray bomb product, technic and prep. None the less, they look great!
  15. PoTaToTrUcK
    PoTaToTrUcK
    In Canada it is quite common to use the Lint-Free roller.
    T/F
    Algoma56, lippy, Roothawg and 3 others like this.
  16. 57 Fargo
    57 Fargo
    I'm impressed with how clean Jeff's hands are! My hands get dirtier driving my junk! Hahahah!!
    Stogy, hrm2k and Jeff Norwell like this.
  17. atch
    atch
    He's an artist man. Can't be smudgin' up the drawings.
    Blues4U, Stogy, Thor1 and 5 others like this.
    Stogy, Thor1, 57 Fargo and 2 others like this.
  19. Notice both Ford's are in front of the Chevy.
    Blues4U, Joe Travers, Stogy and 3 others like this.
  20. bobss396
    bobss396
    Is that a Holley fuel canister? I have a couple of them myself. They take the same element as the old Ford fuel pumps. I forget the number right now.
    Stogy, Thor1 and Jeff Norwell like this.
  21. What's the reasoning behind using a hydraulic clutch in this application? Reason I ask is I am assuming the factory stick cars had rods and a Z-bar (or something similar).
    When I changed a slightly off-topic car from auto to stick, I bought a used factory pedal assembly and modified a Z-bar I had laying around from another application. Worked great.
    Were most 57 Fords auto with factory stick pedals being extremely hard to find? Is it for exhaust/engine clearance? It shouldn't be for steering box clearance if factory parts are used. All this talk of brackets and bracing makes me wonder why the factory stuff (or what I assume factory stuff to be) couldn't be used or modified to work just fine leaving me wondering why the bother to switch to hydraulic.
  22. Jeff Norwell
    Jeff Norwell
    MODERATOR
    The only real reason for using the Hydraulic throw out bearing was... it was free.
    On the other 57 Build, I used a complete stock Z-bar set up with slight mods to use with the 428 and 4 speed. No,.. they are not rare..... I just did not have them at the time I needed them for this build.
    I have used Hydraulic throw out bearings on other builds and have no issues with them.(some people detest them)
    I don't,.... they just need to be set up properly.
    In short,. I used what I had at hand.
    As time has past... and now I have collected all factory stuff.... If I get in a fix.. I have it to fall back on.
    Squablow, enloe, Deuces and 6 others like this.
  23. Jeff Norwell
    Jeff Norwell
    MODERATOR
    @bobss396 .... The fuel canister and bracket is from a 1960 Ford unit..... and was used on 390/406/427 cars....
    I did not know Holley made one.. interesting.
    Thor1, lippy and lothiandon1940 like this.
  24. lippy
    lippy
    from Ks
    Jeff Norwell and impala4speed like this.
  25. As the Chevy is lapping them...couldn't help myself...:p
  26. Note, Always keep the old tech should the new tech fail :D
    Stogy, Jeff Norwell and impala4speed like this.
  27. I am pretty sure the holley fuel canisters have 1/4 male fitting attached to the canister to slide 1/4 inch rubber hose over .
    Picked up a proper tri power / dual four chrome canister with a new filter at ancaster a few weeks ago , I'll break your heart Jeff 20.00
    Thor1, Stogy and Jeff Norwell like this.
  28. The chrome one with the hose barbs attached is a holley ,just cant read the sticker anymore . 20220415_150457.jpg
    Deuces, Joe Travers, Thor1 and 2 others like this.
  29. With fuel at 7.00 a us gallon this week , not sure when I will get the tri power back on my truck , I was never successful at keeping my foot out of it when it was on the truck !!! 20220415_150956.jpg 20181008_112613.jpg
    enloe, Deuces, Joe Travers and 5 others like this.
  30. bobss396
    bobss396
    I have 2 of them, I'll have to dig one out and shoot a picture of it. They are red with a Holley label on at least one of them. I used them on my stock cars and they take a 3/8" line. I haven't seen one new one for sale in decades.
