Technical ***April 2022 Banger Meet Thread - Don't Be Fooled by 5***
Discussion in 'Traditional Hot Rods' started by Jiminy, Apr 1, 2022.
  1. hotrodA
    hotrodA
    Posted this on the main board but some of you may not always go there.
    A friend sent me this pic of a 32 banger powered roadster that he's thinking about buying out of CA.
    Brookville body, everything else is original Henry. It's PERFECT!
    Anybody recognize it, or better yet, is the owner? I'm very envious.
    Jet96 and Outback like this.
  2. hotrodA
    hotrodA
    Well, call off the search. It was on the ‘bay last week, offered by “flathead-Ed” in Murrieta.
  3. jim1932
    jim1932
    what are the metal parts for?
  4. jim1932
    jim1932
    I sacrificed a new one.......
    Old Dawg and winduptoy like this.
  5. raaf
    raaf
    Just pulled the trigger on the Serr Miller head. The wait begins!
    Jet96, Old Dawg, Dustyp489 and 2 others like this.
  6. Good choice
    J
    Old Dawg likes this.
  7. raaf
    raaf
    Thanks @johnneilson. I am still figuring out the rest of the puzzle. Cam...intake...carbs, everything else is up in the air. This will be atop a Burtz.
    Outback likes this.
  8. Be realistic about your usage
    The race car gets injection but the daily driver has only a single 94 carb
    The Burtz will be a good platform to start with
    J
    Old Dawg and Outback like this.
  9. raaf
    raaf
    Yes. I'm seeking solid, reliable (by A standards) drivable horsepower.
    Currently thinking dual downdraft + 81s but seeking opinions/advice where I can get it.
    Old Dawg and Dustyp489 like this.
  10. denis4x4
    denis4x4
    from Colorado
    I have Weber 32/36 carbs on my flathead banger and CRAGAR B engine. Easy to tune and no leaks
  11. raaf
    raaf
    Thanks @denis4x4 - that's just the kind of input I am looking for. I will add them to my list of considerations.
  12. rwrj
    rwrj
    from SW Ga
    I'm running two 1 3/4" SU carburetors with a police head, mild Brierley cam (C, I think? I'll have to check) and homemade exhasust. I'm happy with them. No idea about numbers, though.
    Outback likes this.
  13. raaf
    raaf
    Whoa. I haven't seen those before. Those are pretty! ...and apparently quite expensive. I'll look into them further.
    Thanks.
  14. 29 Speedster
    29 Speedster
    from Colorado
    I attached a flyer for an Early V-8 Ford, Model A & B Swap Meet in early June. In Brighten (NE Denver), Colorado. I thought is was for two days, but flyer has only one day.
    Call Chuck Smith ( info on flyer) to confirm.
    winduptoy and Outback like this.
  15. 29 Speedster
    29 Speedster
    from Colorado
    This is our Burtz/Miller Engine we ran in the 2022 Great Race.
    The Specifics are:
    Brierley M-13 Cam; Good Street, good low end torque
    Stipe Oil Pump with Remote Oil Filter (John Nielson’s Pump would work as well)
    FSI Electronic Ignition
    Single Stromberg 97 Carburetor (Used to meet Great Race Rules, for Street, I would recommend a Weber as Dennis 4X4 recommended)
    Ceramic Coated JE Pistons (the pistons recommended by Terry’s Build Instructions are fine)
    Bronze Timing Gear
    50935527-76AF-4037-9BBC-0837674283AB.jpeg 7A798997-68C0-43FF-898D-5BC4337D1CE6.jpeg EB4381DE-AB82-4763-B5F7-133FCE6C2BBB.jpeg
    51 mercules, Dustyp489 and G Baese like this.
  16. V4F
    V4F
    from middle ca.
    i also run a weber . no problems after 6 years
  17. rwrj
    rwrj
    from SW Ga
    There's a pair of h6's on the auction site right now for just over 200 bucks. I got my pair from the cl***ifieds here for around that. Cheaper than a couple of 81s would have been by a long shot. I like them. Had to make the manifold, but that's another story.
    Jet96, Old Dawg, winduptoy and 3 others like this.
  18. Kevin Pharis
    Kevin Pharis
    from Califunny
    Anyone heading to the Tulare swap meet next weekend...?
  19. callcoy
    callcoy
    Ford 2N 8N 9N Distributors
    Thinking ahead on my unconventional OHV conversion, it might be easier to to fashion a cam snout driven distributor as I can not mount a dizzy thru the head. I don't have a tractor dizzy here, does anyone know if they have centrifugal advance, if they do I can modify a Pertronics type unit to work. This tractor dizzy is compact and has side spark lead outlets like the crab flathead dizzys. I may have to figure out an external oil pump arrangement also if I go that way.
    Steve
  20. Joebrownvw
    Joebrownvw
    Took mine out for its first real blast up the road since the rebuild. What a huge difference a few hop ups make! 54A79732-2DD2-4B9C-A9A2-F1DE14687FEA.jpeg
  21. raaf
    raaf
    Thanks for all the info on recommended carbs.
    So here's an even better question...Are dual carbs necessary to get the most out of the Serr Miller head? Or can you get away with a single without sacrificing much?
    My use case is get in and drive!
  22. brjnelson
    brjnelson
    Here is a Ford 9N Dist adv weight and spring ***embly, I think you can do it.
    Pertronics has a kit for the 9N.
    Google is your friend
    I have a tractor side drive I sometimes think about fitting to the cam gear, I also have an A engine governor that bolts up to the cam gear.
  23. callcoy
    callcoy
    Great info I appreciate it , just thought it would look good out front and solve a problem. Will most likely look into using a V8 flathead oil pump instead of outside driving from the cam gear, but it is too soon to say. I have never seen a governor drive, if I had one of those I would really try to mount a pump tp it, if you hear of one that is available, I am in the market.
    Thanks Again
    Steve
    brjnelson likes this.
  24. Steve,
    be careful on the governor drives, they run at crank speed.
    Have done this cam drive a few times, it works extremely well.
  25. Outback
    Outback
    from NE Vic
    Old Dawg and BeaverMatt like this.
  26. Phil Damon
    Phil Damon
    from San Diego
    Vesco posted this picture on Facebook.
    Old Dawg, johnneilson, Jet96 and 3 others like this.
  27. Rumor is new billet 4 port Riley head and going after 220 record.
    Will be very interesting to watch, J
    ottoman, Jet96, Old Dawg and 4 others like this.
  28. 29 Speedster
    29 Speedster
    from Colorado
    We have a Single Stromberg 97’ with .045 Main Jets that runs fine on the street, more details regarding engine a few posts up.
    It had 80HP on ch***is Dyno, I think it was ~3600 RPM. We are also above 5,000 feet in Colorado.
    Jet96, 51 mercules and Outback like this.
  29. G Baese
    G Baese
    @ Collcoy,
    I have two different banger governor mounts...
    pm if interested.
    Outback likes this.
  30. stillrunners
    stillrunners
    from dallas
    Wishing and hoping all is well in your 4 world !
