Technical Removing pilot bearing
Discussion in 'The Hokey Ass Message Board' started by johnfin, Apr 16, 2022.
  1. johnfin
    johnfin
    from Florida
    I am having a heck of a time removing the pilot bushing on a 350 chevy. I have a decent slide puller for the job but it wont come out. I heated it with a torch and even put slits in it with a micro saw to loosen the force but it wont budge. Any thoughts?
  2. oldiron 440
    oldiron 440
    I’ve seen them pushed out with a grease gun but I don’t remember how….
  3. BJR
    BJR
    Fill with grease and with a tight fitting dowel or steel rod that fits inside the bushing smack it with a BF hammer.
    dirt t, Deuces, Gasser 57 and 9 others like this.
  4. Davesblue50
    Davesblue50
    Have packed them with white bread as much as could go in. Put a bolt the size of the bearing ID in the hole and tap with a hammer. Keep packing with bread and it will force the bearing out.
    Rramjet1, Joe Travers, Deuces and 8 others like this.
  5. sunbeam
    sunbeam
    If it is br*** tap the hole for a bolt
  6. Los_Control
    Los_Control
    from TX
    I used the grease gun to pack it full of grease, then used clutch alignment tool or dowel etc and smack it with the hammer ... creates a hydraulic action and the grease pushes the bearing out.
  7. HOTRODPRIMER
    HOTRODPRIMER
    I tried it and it worked for me. HRP
    Joe Travers, hrm2k, nochop and 3 others like this.
  8. HOTRODPRIMER
    HOTRODPRIMER
    Bearing chisel , good to simply “blow up the bronze bushing into bits “
    pilot bearing puller , works great .
    blind hole bearing puller used with a slide hammer works really well
    pilot bearing puller for a slide hammer .
    Ive be also used the grease and punch method to force a bushing out .
    ive also mig welded on a bearing to “shrink it” and have it come out easier .
    a bronze bushing will melt with a torch without damaging any thing around it .
    Many many ways to skin a cat in this situation .
    verno30, Deuces, Gasser 57 and 3 others like this.
  10. samurai mike
    samurai mike
    small pieces of wet paper will do the same thing as grease without the mess
    flatout51, Deuces, Gasser 57 and 2 others like this.
  11. Mr48chev
    I've done it with grease and something that just slips in the hole in the bushing a few times but usually use a puller attached to a slide hammer.
    About 30 years ago when I didn't have access to a puller and was laying under the 48 in freezing weather I took my saber saw and cut a slot in the bushing to relieve the tension when I couldn't get it out with grease. I was too damned cold to have any patience that time though.
    Heating the bushing hurt and hinder progress rather than help as that will expand the bushing out and put more pressure against the crank. Hitting it with a blast from a Co2 fire extinguisher or packing it with dry ice would probably be more effective as far as heat/cold goes.
    Deuces, 41 GMC K-18 and '28phonebooth like this.
  12. johnfin
    johnfin
    from Florida
    So I got the bushing out with brute force but.....when I installed the clutch I remembered that I was suppose to ( or at least I think I should) put thread locker on the bolts to
    the flywheel to the crank. I torqued them to 80ft lbs. I know the newer cars use thread locker on the bolts and you can see traces of it on the bolts but I didnt see anything on
    these 40 year old bolts. Engine only has 180hp I think so I am not sure its necessary. What to you guys think?
  13. rusty valley
    rusty valley
    Flywheels have been around a lot longer than thread locker, you'll be fine. Hope you had the crank flange and flywheel spotless clean to mate perfectly
    blowby, Bob Lowry and Desoto291Hemi like this.
  14. 350 Chevy with no Loc***e on the flywheel bolts,,,,,,,,,what were you thinking !
    Lol,,,,,you’ll be fine,,,,,don’t give it another thought,,,,,if everything is clean and tight,,,,,you did your duty .
    Tommy
    olscrounger likes this.
  15. Bob Lowry
    Bob Lowry
    Desoto and Rusty valley are right. I have been building engines since 1960 and didn't use
    thread locker on any of my builds until 2000. You'll be good.
  16. hepme
    hepme
    this works. i've done it, to help i put a little wd40 around the edges and let it soak for a little while before i whacked it.
    nochop likes this.
  17. nochop
    nochop
    from norcal
    Grease, dowel, tap
    dana barlow and rusty valley like this.
  18. blowby
    blowby
    from Nicasio Ca
    I wonder who it was that came up with the idea of packing his pilot bearing with bread. Peanut ****er might help too. But no jelly, too sticky.
  19. choptop40
    choptop40
    That bearing was toast.....ha ha ...first time ive seen it removed with bread...
    clem likes this.
  20. ClayMart
    ClayMart
    That video does a great job of showing this process. But now it's got me wondering if I should be wearing latex gloves when I'm eating a sammidge.
    o_O :rolleyes:
  21. johnfin
    johnfin
    from Florida
    So my clutch kit came with a package of grease. Since the pilot bearing is impregnated bronze I am sure its not for that. Where else would you use grease around a clutch? I read somewhere a guy was talking about packing the throwout bearing. I think mine is sealed not that I want grease flying would the friction plate.
  22. simplestone
    simplestone
    If you have tried the grease & bread method and you don't want to buy the pilot bearing removal tool, you can rent the tool for free (their rental - pay and return for money back within 60 days) from your local Autozone. That's what I did when I had to remove the br*** bearing from my chevy 235.
  23. mrspeedyt
    mrspeedyt
    You still need the grease in the new pilot bearing. Just don't pack it full of grease.
  24. johnfin
    johnfin
    from Florida
    I read that you are never suppose to but anything on a sintered bronze bearing, it could gum it up as it has impregnated oil in the bronze.
    427 sleeper likes this.
  25. I have tried the grease thing and it has never worked for me. But as @sunbeam says here ^^^^^ taping and screwing a bolt in does work. I use a bottom tap so that the bolt can go past the bottom of the busing and push against the crank.
    Tim likes this.
  26. Corn Fed
    Corn Fed
  27. I had heard of the bread idea before but never used it .
    I think the bread deal is the best overall idea,,,,,,it works,,,,,and is super easy to clean up .
    Very good thinking whoever came up with that .
    Tommy
    Joe Travers and VANDENPLAS like this.
  28. Doublepumper
    Doublepumper
    from OR-WA, USA
    I always smear some on the bearing support and a dab on the fork contact areas.
    Removing pilot bearings? Gummies. Works perfect, not messy and much tastier than grease or bread:D
  29. 03GMCSonoma
    03GMCSonoma
    You should use a BMF hammer. :)
    VANDENPLAS and BJR like this.
  30. 1971BB427
    1971BB427
    from Oregon
    Did you guys quit reading the posts? He already has the bushing out.
    I'd not do much more than wipe a little grease on the input shaft of the trans before sliding the trans into the bellhousing. But even that isn't necessary with a sintered bronze bushing.
