Hot Rods Anyone have any experience with Diamond back bias look radials?
Discussion in 'The Hokey Ass Message Board' started by Pa G., Jun 27, 2019.
  1. 08racer
    08racer
    from Gilbert AZ
    550/16 front
    750/16 rear
  2. GeezersP15
    GeezersP15
    from N.E. PA
    I'm about to "pull the trigger" on a set of these for my 48 Plymouth. The car has a set of DB radials on it now, that have been on it for nearly 11 years now. They still look like brand new, but due to their age, I'm replacing them. No, they're not cheap, but should last much longer than I ever will. Gonna have the wheels pinstriped per original while I'm at it too!
    Elcohaulic, AHotRod and Tim like this.
  3. European Custom
    European Custom
  4. okiedokie
    okiedokie
    from Ok
    "tires were inflated to specs " Does Diamond provide specs for the tires on different vehicles or just for the size of tire?
  5. Have a set on my 33, 5:50x16 and 7:50x16 Auburn deluxe, great ride compared to the cokers I had on my last rod. well worth the wait to get them. no tubes and the ride is soft not the hard rubber feel of the cokers. I had the sidewalls smoothed out and they look great.
  6. Discostew
    Discostew
    I just purchased a set of Auburn deluxe tires and had them fitted.
    I noticed a couple of mine had bubbling at the bead where the the rim is.
    What would cause this?
  7. brianf31
    brianf31
    I ordered a set of 10.00-15 for my Falcon g***er build. The shoulder is nice and square. AD1.jpg
    Toms Dogs, Deutscher, WC145 and 7 others like this.
  8. pprather
    pprather
  9. mrspeedyt
    mrspeedyt
    Dang! I think I'm going to stick with the black cheap tires and maybe get some porta walls...
  10. brianf31
    brianf31
    Yes, they are radials. They make a matching front runner if you want skinnies.
    https://dbtires.com/
  11. Bandit Billy
    Bandit Billy
    Auburns on my PU. Mmmmm, pie crust
    Toms Dogs, WC145, MRW1994 and 3 others like this.
  12. Russco
    Russco
    from Central IL
    Those are the Diamond back radials or the Auburn Deluxe radials?
  13. Russco
    Russco
    from Central IL
    I ordered a set of the Auburn Deluxe wide Whites about 10 days ago. They told me they would ship in about 2 weeks? We’ll see. They weren’t really any more expensive than the Coker’s I have see, but everyone swears they are far better. I plan on doing a review when I get them. I bought them to try on the Bourbon Run this year which is about 1200 mile round trip. Last year I had one of my front bias plies cup really bad while in Kentucky and luckily had a buddy down there that happens to have a spare set of 560/15’s he loaned me.
    brianf31 likes this.
  14. raaf
    raaf
    What's the deal if you want to run these on Kelseys? Do you need a tube?
    EDIT: Did some research and it sounds like I'm going to have to run "Radial Tubes" and use some grommets for the valve stems. If anyone has experience with this use case I'd be interested to know more.
  15. brianf31
    brianf31
    They are the Auburn Deluxe radials that Diamondback sells. I received mine in less than 2 weeks from the time I ordered.
    jetnow1 and Russco like this.
  16. Russco
    Russco
    from Central IL
    Update. I received the Auburn Deluxe tires in about 2 1/2 weeks from ordering. They came well packed (wrapped) I unwrapped them and let them sit a few days before I had them mounted. I measured the cross section on the Coker cl***ics before I had the new 8.20x15’s mounted hoping the new ones would be just a little narrower to help with an occasional rub I have on the rear inner wheel house. The Coker’s were 9.750 cross section width when mounted on 15x7 Wheels the new Auburns are 9.250 so I was happy about that. Cosmetically they look great The only think I don’t particularly like is the outside edge of the white wall sticks out about .125 but it’s not very noticeable. Now for the drive review. I put them on my car and took off. They immediately felt better than my Bias plies. While going through the neighborhood. Then out to the highway and within about 2miles 2of the wheel weights flung off as soon As I got up to about 55 mph so I can’t say for sure how much better they are yet because I’m so freaking pissed it messed up my front fender. So, more to come later after I get them re balanced and I guess I’ll be getting a fender re painted as well. I’m fuming mad right now! 9343F703-8722-4C7E-9499-ABED712F8162.jpeg 6E9A090E-5F04-4A64-8B29-CA8B56D1F1C0.jpeg 76431F4B-765D-4AD7-972F-3AB1B4211B5F.jpeg F65B406E-4C30-48B7-8EE8-23B975727F76.jpeg E7F2D264-EC99-4A2F-9A5C-2FE79FCAB246.jpeg
  17. Rand Man
    Rand Man
    Yea, that’s a h***le on that nice car.
  18. brianf31
    brianf31
    Ouch!
    Here are mine installed.
    WC145 and Splitbudaba like this.
  19. 4speed411
    4speed411
    33Doll and brianf31 like this.
  20. guthriesmith
    guthriesmith
    Wow...I would be hot too... Sorry that happened man. I love your 40 and that even makes me sick that it happened. :(
  21. Russco
    Russco
    from Central IL
    Finally had them balanced (a second time) and was able to drive it last night. It’s rides MUCH better. The shaking/vibration that shuttered the entire car before at certain speeds, is now gone. They look pretty good as well. So far, I am pretty pleased overall (except for the damage on my fender, but I’ll have that repaired. We leave next weekend on our Bourbon Run trip. It’s about 1200 miles with some spirited Kentucky backroads in the mix. I’ve always just ran the Coker bias plies because that’s all I knew of that looked “right”. Now I’m happy to say those of us that hop in them and drive them on long road trips have another option. Here’s a few pics of them on the car.
    A4643D05-6781-44E2-842D-21D14541394D.jpeg 16248B72-0C2E-4036-AAF2-426B23F244A1.jpeg B94D8C31-0EF0-4952-B1F2-175FCAD9A273.jpeg
    A Boner, rod1, Toms Dogs and 10 others like this.
  22. brianf31
    brianf31
    Looking good! I'm glad to hear they ride well. It will be a while before I can prove 'em out.
  23. WC145
    WC145
    from Maine
    Boy, I like those. If I knew they existed I might have ordered a set instead of the Firestone cheater slicks for my '30.
  24. brianf31
    brianf31
    They ride very good. I have around 1000 miles on them and no complaints so far. I wish I would have bought them for the front as well but I got some Towel City front runners there.
  25. putz
    putz
    from wisc.
    Great tire and look ...... had on 39 pu , 40 pu ,40 Fords just ordered a set ....
  26. 33Doll
    33Doll
    I just ordered some to match my Firestone 560’s
    Are you still digging them?
    That Falcon is Bad$$$
  27. 1935ply
    1935ply
    from peyton,co
    I have about 3000 miles on diamond back 8.20 - 15's and 5.50 - 15's and they are so much better than the coker tires. The 7.50 - 16 and 5.00 - 16 cokers never would balance and at high speed it always felt like the wheels were loose. The diamond back radials are smooth and handle well. The sidewalls aren't as tall as the firestones but the driving improvement is worth it. I usually never get replacement insurance on tires but did with these, one rear tire got damaged all I had to do was send them a picture and they sent a new tire to me.
    427 sleeper likes this.
  28. brianf31
    brianf31
    Yes as long as you ain't expecting lots of traction when you dump the clutch. I have about 2000 miles on them now and they still ride good. They did well pulling a trailer in the mountains during Sick Smokies drag and drive.
    54delray and 427 sleeper like this.
