Technical Unbend tubing?
Discussion in 'The Hokey Ass Message Board' started by Dave G in Gansevoort, Apr 17, 2022.
  1. Dave G in Gansevoort
    from Upstate NY
    So say that you're making some tube bends, matching side to side. And you bump the pointer and don't notice. Now you have 2 tubes but 1 bend (the last one of course...) is just a degree or so, maybe 2, overbent. And don't want to start over, wasting 1 section of tubing.
    What do you do to get it a tiny bit less bent? Suggestions, please, and don't worry about hurting my feelings, I've already called myself a couple of bad names over it!
  2. Marty Strode
    Marty Strode
    Dave, I over bend tube all of the time. I have a couple 900 lb Welders that I can stick one end under, and slip an early Ford solid drive shaft into the other end, and pull. Depending on the tube size and thickness, you can normally take a little of the bend out.
    rod1, ottoman, dana barlow and 6 others like this.
  3. Paul
    Paul
    Editor
    Brake lines, roll bar/cage, frame, exhaust, round or rectangular?
  4. egads
    egads
    Tubing for what ?
    Flathead Dave, Cosmo49 and VANDENPLAS like this.
  5. Dave G in Gansevoort
    from Upstate NY
    So basically just muscle a little bit out. Okay I can do that! Yeah I've got heavy stuff in my shop. And there's always a tree out back with 2 big trunks (a bifurcated tree, yup $10 word...), that I could stick it between and tug.
    FYI Paul, it's 1.5 od .095 dom about 4 feet worth with 3 bends to shape it to the curvature of the body. Once I get the fit I'm shooting for, I'll be posting pictures to the Whatever project. Just have to mind the back...
    egads, Tim, VANDENPLAS and 1 other person like this.
  6. Used to do this all the time when bending larger conduit...
    It's funny, you do have to 'overbend' a bit to allow 'spring back' but things like ambient temps and slight material differences from piece to piece could cause variations in how much spring back you'd get. If it's not too much, say under 3 degrees, whacking the bend against a wood surface that's sturdily backed will generally remove the extra. Use wood so that it doesn't 'flatten' or scar the tubing. More than that gets a bit trickier, then you go looking for something heavy or a tree. But the 'whack' method gives better control for small changes. Try not to whack the same place each time, spread them out on the bend if possible.
    ottoman, LWEL9226, '51 Norm and 3 others like this.
  7. Paul
    Paul
    Editor
    Yeah, and of course mind the pressure points on the rebend, don't want to leave the over bend and create a new bend on the straight sections..
    indyjps and Tim like this.
  8. You probably will never get it straight again but like Marty here I have tweaked them a little bit when I have gone too far.
  9. Dave G in Gansevoort
    from Upstate NY
    I remember using the whack it on a telephone pole method for a quick and dirty way to straighten bent tie rods to get the race car back on track by feature time, but that was a get it good enough to be able to set the toe quickly. Never thought to use it today for this proble... opportunity to save the tubing.
    I'm going to try Marty's suggestion first tomorrow, when the back is willing.
  10. iagsxr
    iagsxr
    Used to have a welding bench that was perfect for hooking overbent tubing under to straighten.
    You want to get what I would call the anchor point as close to the bend as possible so the bend relaxes rather than bowing a straight section.
    Throw a block or s**** of plywood on the floor where the bend is going to be if you're going to hook it under a bench or something. It's pretty easy to leave a divot in .095".
    egads likes this.
  11. mohr hp
    mohr hp
    from Georgia
    My welding table has a 2x4 steel channel horizontal crossbrace that can hold a multi bend bar. I let only the offending bend and it's tail stick out, and I slip a cheater bar over or inside all the way to the bend. I'm only 165 Lbs., but by bouncing a few times, I have taken out up to 2 degrees more than once.
  12. KevKo
    KevKo
    from Motown
    Just curious, would heating an area on the outside of the bend shrink it?
    Ned Ludd and Tman like this.
  13. cfmvw
    cfmvw
    Had to tweak some conduit when I was doing an electrical project in the garage. The tractor sure came in handy for that! Used the bucket and some wood to hold one end down, then drilled a hole in a length of 2x4 to slip over it for leverage.
  14. I have done that as well as the bendy method Marty mentioned. Those old ford driveshafts are tough!
  15. Marty Strode
    Marty Strode
    They are long, for leverage as well.
    Tman likes this.
  16. If you have nothing better to do, watch this. Pretty impressive.
  17. These are my kinda folks. I enjoy these videos. Reminds me of all the stuff we had to fix growing up.
    seb fontana and AVater like this.
  18. I’ve used heat.
    I’ve whacked em on the floor.
    Whatever it takes.
  19. hipojoe
    hipojoe
    Next time you feel your life is difficult and are feeling conditions at work ****s, reflect how others get things done, No dial indicators, welding hood, mics, calipers, or some work boots/ shoes... Oh how those dingle balls hurt that role down the tongue of your shoes.
    brEad and seb fontana like this.
  20. AVater
    AVater
    Love those safety shoes they wear and the ingenuity in their work.
    Thanks for sharing!
    juan motime and Flathead Dave like this.
  21. Dave G in Gansevoort
    from Upstate NY
    Thanks guys. Yes it is just a wee bit of adjusticating to do. I'm going to use a heavy object (me) on one end, and like many mentioned, wedge the other end under something heavier. And I've got a lot of **** heavier than me in the shop
  22. gimpyshotrods
    gimpyshotrods
    I stick one end under the Haas and correct as needed.
  23. indyjps
    indyjps
    Thank You. The gears are turning in my head, have a 5'x 10' steel table, I can weld a few tubes across the center support for leverage bar using the table. :D
  24. Dave G in Gansevoort
    from Upstate NY
    You know, when I strted this thread, I thought I had only overbent the one end. Ready for the next installment of "As the Tubing Bends"?
    Yeah, Dumas me, when I put it in the bender working out from the center bend, my mind got wrapped around b*** ackwards. So both outer bends were actually wrong from the point of view of my layout. But it fit better that way!
    So I made a 2nd one to match, carefully bending it, checking the springback each time, and it worked!
    So I also needed two tubes 14 inches long for another part of the fabrication, which I was able to cut off the ends ot the 1 I thought was correct (it was, BUT the other... see above). So only 12-13 inches of tubing was wasted due to the bends in it. I'll use them to mock up something else, maybe...
    So no debending...
    Lemonaide from the lemon.But now I can save slight overbends if need be.
  25. DDDenny
    No, he's not referring to Gene either!
  26. abonecollector
    abonecollector
    I've found that a 5 degree or less bend on round tube up to 3" diameter will not look too terrible if you try to bend it back. i have made a few goofs on our tubing bender at work. Anything more, & the pipe looks ( & will be ) distorted
  27. G-son
    G-son
    from Sweden
    Heat shrinking can probably be used to do that. Although you may want to research what heat does to that type of tubing forst, I'm sure some won't be affected while some will be.
    mgtstumpy and rdscotty like this.
  28. 210superair
    210superair
    from Michigan
    Your avatar is my kids favorite book, lol.
    Paul likes this.
  29. mohr hp
    mohr hp
    from Georgia
  30. Marty Strode
    Marty Strode
