Technical Sbf engine mounts help ???
Discussion in 'The Hokey Ass Message Board' started by 38nailhead, Apr 17, 2022.
  1. 38nailhead
    38nailhead
    from England
    Hi everyone .
    I’m after a bit of help please .
    I have a ch***is Engernering transmission kit and engine mount kit to fit a 351w and c4 transmission, the transmission kit went in ok and the transmission mount is sitting in place , but I’m having a few problems with the engine mounting brackets.
    I have followed the instructions for the dimensions ( picture included ) but have had to adjust them by 1 and half inches forward, the brackets are sitting 7/16 of the inner frame edge . If I was to bolt them through to hold them in place would this be sufficient and strong enough ? Their is 1 and a 1/4 “ sitting on the frame . The brackets are both a equal distance both sides sitting on the frame and also equal from the back of the bracket to the frame edge
    This is my first time doing this and have spent all day finding out as much as I can so any help would be very appreciated.
    I have also included 2 pictures of the sump to show it clears the front cross member , I can fit my fingers between the gap .
    27CE529E-A14A-4ECB-9B98-A8D990E02ED2.jpeg D7EE33A4-883B-460C-B672-3654228F45ED.jpeg FE19C1AE-A99E-45AA-927C-7F2BC5F10F38.jpeg
  2. oldiron 440
    oldiron 440
    First thing I see is it looks like the motor/transmission aren’t squared with the frame, the output shaft of the transmission and the center line of the crankshaft need to be the same distance from the frame rails and square to the cross members.
    Next you don’t show witch oil pan you have but is it possible that you have mounted the transmission to far forward?
  3. 38nailhead
    38nailhead
    from England
    the oil pan is a rear sbf pan so it clears the front crossmember . The transmission mount I bolted in to the original holes as the ch***is Engernering instructions directed me to . The c4 transmission mount is sitting in the lower plate but the nuts havnt been tightened.
  4. oldiron 440
    oldiron 440
    It’s probably an optical thing but the front crossmember looks pushed back in the center. And like I said before the engine transmission must be offset the same amount front and back.
    Once you have the combination located where it should be you can make adjustments on height and try and clear the cross member.
    38nailhead likes this.
  5. 38nailhead
    38nailhead
    from England
    this is the front crossmember from above , the right hand side is where the engine sits .
  6. oldiron 440
    oldiron 440
    You can raise the front of the engine enough to clear the crossmember to a point but floor and firewall location come into into play. You only need to clear the cross member by 1/2 to 3/4 of and inch.
  7. titus
    titus
    Thanks for getting back to me on those window regulators........
  8. sunbeam
    sunbeam
    A notch or BFH to pan time
  9. gimpyshotrods
    gimpyshotrods
    If it were me, I would slot the transmission mount bolt holes by one hole diameter, and slide everything back.
  10. Charlietruck62
    Charlietruck62
    check your transmission mount. My fuzzy memory says that some c-4 mounts weren't centered fore and aft.
  11. Charlietruck62
    Charlietruck62
    I should add I mean to turn it around and mount it the other way
