Hot Rods Spalding Bros Repro, for "Too Tall" Ganahl.
Discussion in 'The Hokey Ass Message Board' started by Marty Strode, Jul 13, 2015.
  1. Gofannon
    Gofannon
    Hartman ran the torsion bars transversely in his car. If Spalding's was the first to run torsion bars, Hartman's would have to be the second.
    Just as an aside (I don't want to drag this thread off topic), I've thought about running one of those '41-'46 Chevy truck rears in my roadster. Narrower than '50's truck rears, 3/4 ton had open drive 4.56 gears, and I have a hunch a mini locker for an early 12 bolt would drop in allowing for 30 spline axles. Maybe it was the "3/4 ton rear" used in '57 Chevy Black Widows? Similar width housing to a 55-57 rear.
  2. AmishMike
    AmishMike
    Wow, mention of ‘57 black widow must be an old timer. Never knew they ran different rear. Wonder how many of those left the factory & not created by “restorers” years later.
  3. jimmy six
    jimmy six
    6 lug front and rear…
    Tman likes this.
  4. Marty Strode
    Marty Strode
    Another shipment of photos from Pat. Also, make sure and tune in to his Blog Tomorrow. Pat 35.jpg Pat 36.jpg Pat 37.jpg Pat 38.jpg Pat 39.jpg Pat 40.jpg
  5. Marty Strode
    Marty Strode
    I just noticed Pat has a picture of my old buddy, Rosie Rousell in his # 96 on the wall !
    Outback, Just Gary, Tim and 2 others like this.
  6. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Maybe I'm missing something, but as I look down on the plug wire arrangement it seems the #5 and #6 plug wires may be crossed, unless they do another crossover near the spark plugs, no?
    chryslerfan55 and Gofannon like this.
  7. Gofannon
    Gofannon
    Complicated plug lead order. Rotor looks like this, one set of points does 3 cylinders. It depends on which coil is firing and which leg of the rotor is being used, and what lead it lines up with. It makes my head explode.
  8. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I get that its a twin coil arrangement.
    I am looking down at the wires coming from the distributor cap and where they seem to be headed on their way to the spark plugs.
    If you ***ume the standard inline six arrangement firing order of 1-5-3-6-2-4 and ***ume the rotor moves in a counter-clockwise direction and ***ume the wire's position routed over the valve cover matches the order of the spark plugs 1-2-3-4-5-6 I end up with 1-6-3-5-2-4. Any other way I try to figure it , it does not compute. I realize that's a lot of "***umes" so somebody school me.
    or expect backfires
  9. Marty Strode
    Marty Strode
    Jiminy likes this.
  10. pgan
    pgan
    Mr. Flyer, I was thinking it was Gofannon who wrote the above reply--where things do rotate in the opposite direction (and yes, my head exploded a couple times trying to figure this wiring). But on all of my engines (Chev, GMC, Cad) the distributor rotates clockwise. And do not ***ume the wires attach to the plugs in the order they cross the valve cover.
    I had a photo showing the wires attaching to the plugs with Rajah terminals, but I dumped it because it didn't show much. But several wires cross under the manifold. And I just switched two in the separator clips to get them farther away from the exhaust manifold. The big problem was I could find no diagram on how to wire this Spalding distributor, nor anyone around here who really knew anything about it. So I just picked a no. 1, and then arranged the plug wires in the 1-5-3-6-2-4 order that has been etched in my brain since high school, going by which set of points was opening, which coil those points were wired to, which rotor tip that corresponded to, and where that tip was pointing. But I am notorious for getting my wires crossed. We'll see.
    PG
  11. saltracer219
    saltracer219
    This setup looks very similar a W&H Ducoil distributer, there is a post somewhere here on the HAMB that lays out the firing orders for those units. You might also see if you can get a reply fron GMC Bubba on this.
  12. Gofannon
    Gofannon
    Pat and Marty, the car is looking great! Much needed inspiration for me to get mine done. From what I worked out, clockwise around the cap it goes 14**36**52**. I'll have to double check that when I get to firing up for the first time. I can barely read my own notes! The coil lead needs to be in the right hole for which set of points it's connected to, and the points need to be in phase. I think a buddy of mine has a Distributorgraph, otherwise I'll fab some sort of pointer device to phase the points.
  13. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Thanks for setting the record straight. I know you know your six bangers. I made one too many ***umptions I guess.
    I'm liking how it looks going together.
    Outback and chryslerfan55 like this.
  14. Dave G in Gansevoort
    from Upstate NY
    2 1/2 months! Any news? Pictures? Trivia? Pat's favorite burrito? Anything?
  15. Marty Strode
    Marty Strode
    Bill is going to haul the car to his South City Rod and Custom shop, and finish it. Pat was down to spraying the paint on the body and turtle deck, and some final ***y. Bill will do a great job on the completion. I am going to send him a thumb drive of all of the construction pictures, to aid in his work.
  16. jimmy six
    jimmy six
    After meeting Bill I’m sure this recreation is in good capable hands. The love and respect he had for his father will show in his completion.
  17. Marty Strode
    Marty Strode
    JD, absolutely, he is special, just like his Dad !
  18. Dave G in Gansevoort
    from Upstate NY
    It will be a fantastic tribute to Pat. It would be fitting if the car ends up being displayed in the Petersen Museum in his honor.
  19. jimmy six
    jimmy six
    That’s what might happen but I’m sure Pat would have trailered it to every dirt track in California and take hot laps at intermissions. True racers and fans would go crazy to see the true roots of the early roadsters that flooded the dirt track here for sure…
    Lowlife, tractorguy, 54delray and 6 others like this.
  20. Dave G in Gansevoort
    from Upstate NY
    And don't forget the original went to the lakes. Maybe Bill will air it out a few times as well.
    tractorguy and Uncle Ronn like this.
  21. jimmy six
    jimmy six
    Not legal to race but no reason not go in for a photo shoot in the middle of the week..
  22. Marty Strode
    Marty Strode
    Bill picked up the Spalding over the weekend, set the body on for the trip up to his Hayward, Ca shop. He is very busy readying a couple cars for the GNRS, and then he will be getting the paint work on the body, deck and hood finished and do the final ***embly, later this Winter/Spring. It will be nice to see and hear it run. Spalding 200.jpeg Spalding 201.jpeg
  23. bskustoms
    bskustoms
    from Aloha, Or.
    As always Marty, great work!
    Uncle Ronn and chryslerfan55 like this.
  24. Tim
    Tim
    from KCMO
    Man that’s a beautiful car
    Uncle Ronn likes this.
  25. Fordors
    Fordors
    Simply a work of art. I can't wait to see it in paint.
    Uncle Ronn and TerrytheK like this.
  26. John Starr
    John Starr
    I was sad to see it go, but happy to know where it’s headed.
    Outback, Just Gary, Boatmark and 18 others like this.
  27. twenty8
    twenty8
    That must have been a hard day for you and Bill.
    I sincerely hope the story of this build doesn't stop here, and that both you and Bill will keep us informed.
    Lots of people on this journey with you both.
  28. Stan Back
    Stan Back
    I hope it doesn't end up at the Peterson. They might sell it off like they did to other cars to make the building even more ugly.
  29. Marty Strode
    Marty Strode
    Thanks John for the photo, a lot of good cars rolled out of that driveway, and some rubber was burned as well.
    Just Gary, Uncle Ronn, KKrod and 6 others like this.
  30. Marty Strode
    Marty Strode
    I am certain Bill will take photos, and send them to me, and I will post them here, just like I did for Pat. Thanks to all of you for tagging along, it has been a journey.
