Technical What did you do with your car today? * NEW*
Discussion in 'The Hokey Ass Message Board' started by j hansen, May 3, 2020.
  1. lake_harley
    lake_harley
    Curious how many past and present Roaring 30's members and cars were there? I don't get around the St. Louis area but years ago the Roaring 30's were quite the prestigious club....maybe still are.
    Lynn
    mad mikey likes this.
  2. lake_harley
    lake_harley
    Good thing you didn't mention what kind of oil you bought or this thread would drift at the speed of light! :eek:
    Lynn
  3. lake_harley
    lake_harley
    Worked on and modified parts and pieces for the Powerglide that I plan to use in my under-construction FED. Getting close to ***embly time. The modifications I did will either make it a better transmission for it's purpose, or.....I ruined some parts of a perfectly good core PG. :oops: I'm following the "directions" in a very complete Powerglide book, so I hope my reading comprehension and picture-following skills are on track.
    Lynn
  4. wheeltramp brian
    wheeltramp brian
    I swapped in the correct ohm coil just now and it fires right off no problem. It used to crank for like 5 to 10 seconds sometimes and I always wondered why. My old coil read 3 1/2 ohms post to post and my new one is 1.5 which is supposed to be the correct for the V8. Whoops
    bchctybob and TA DAD like this.
  5. Blues4U
    Blues4U
    from So Cal
    Aired up the tires. While on the creeper greasing the driveline the other day I noticed the plumber's tape I used as a temporary battery hold down several years ago had failed and there was nothing holding down the battery at this point. So today I fabricated a simple battery hold down with a piece of flat bar stock and a couple of threaded j-hooks from the local Auto-Zone. Tried to paint it all up, but I didn't allow enough time between application of the primer and the paint, which caused the paint to crinkle. I didn't have time to redo it, so I'll have to sand it all down and repaint it later. For now it's installed for the cruise tomorrow. Now I'm off to the House of Blues for a gig, whoot! :cool:
  6. Sky Six
    Sky Six
    from Arizona
    Replaced the worn 15" air cleaner and rocker boxes (oops, valve covers) that were slightly rusted and replaced them with new, plus filters and breathers.
    mad mikey and TA DAD like this.
  7. 65type1
    65type1
  8. tombstone
    tombstone
    from sk.canada
    E4F59A5B-34DC-4EE5-800A-0444B16B9BA1.jpeg 9CA46B91-9351-4C14-8FEC-C70A73E2E3E0.jpeg 64F52EB2-2227-4D16-95EE-A86984524CA5.jpeg Got the speedster lettered.....
  9. Rehpotsirhcj
    Rehpotsirhcj
    I want video of that monster making a p*** Mike. :)
    bchctybob, mad mikey and twenty8 like this.
  10. twenty8
    twenty8
    Time very well spent...........:cool::cool::cool:
  11. bobss396
    bobss396
    Unboxed my rack and pinion kit the other day. Sorted through the parts and read the instructions.
    Ordered a PS pump, brackets and other goodies from Cl***ic Industries to the tune of $315... with free shipping. Opted for a new pump. I still need a belt and an adapter for the pressure-side of the pump to the 6AN lines... hope they fit. Also need to knock the pump pressure down from 1200 PSI to around 900.
  12. mad mikey
    mad mikey
    It has been one year ago since the accident. At this time last year I was almost done with the repairs and improvements . Thanks for reminding me of one of the worst day in my life.:rolleyes:
  13. dirt car
    dirt car
    from nebraska
    Thought I would try my hand at lettering when my project gets to that point but this guy really does a vehicle justice ......
  14. Greg Rogers
    Greg Rogers
  15. Black_Sheep
    Black_Sheep
    Pulled apart the top of the steering column and figured out why the turn signals would not cancel in one direction. It was a simple fix for an issue that’s bugged me since the truck has been drivable…
    mad mikey and Blues4U like this.
  16. TA DAD
    TA DAD
    from NC
    Got the Stude off the ground to look things over after putting a few miles on it. All is well, no leaks and nothing loose. I had all the rockers off the motor after a little run time and had 2 or 3 touching the retainers. Clearanced those and ****oned it up. So after driving it some and spinning the motor up a few times I thought I would take another look at them. There were 3 that had a slight witness mark so I touched those up and changed the oil and filter will I was at it. The good news is the valve adjustment was still spot on ( no cam wear ) and the rockers are running dead center (maybe a little to the inside of the valve tip ) I like to see them about 10 thous. to the inside myself. So my white lithium grease and a mix of 20 year old Kendall GT 50 and a couple qts of VR1 60 on my used flat tappet cam with the used lifters that were tossed in a box has made it through 20 gallons of Cam2 so far !
    My new blend is some 40, 50 and 60 weight ZR1 ( they used to make some off road ZR1 but I am out of that ) Any oil is better than no oil ! IMG_0351.JPG IMG_0350.JPG IMG_0354.JPG IMG_0349.JPG IMG_0355.JPG IMG_0356.JPG Got it back on the ground my Bride came out and said "take me for a spin" so we went for a little ride. Plus all the plugs looked great ! I got a 750 Holley on it. It is/was new a few years ago. It was run on the dyno taken off had the bowls pulled off and dried out, set on a shelf with a rag over it until it was p***ed along to me. I bolted it on without touching it and it runs super. Pretty amazing really that the pumps hadn't turned hard. You know the old saying "**** it ! run it !
  17. topher5150
    topher5150
    Random thought...how often should I prime the oil pump? I have an engine that was sitting around a few years when I got it. I've had it for two years now and have primed the pump about once a year.
    Should I keep priming it?
  18. vtwhead
    vtwhead
    Topher, I always like to prime and turn the engine over manually to a different position.
    mad mikey and topher5150 like this.
  19. hd1084
    hd1084
    Added a new set of ceramic coated lake headers to the hot rod today.
    David Gersic, MO_JUNK, 40two and 9 others like this.
  20. Atwater Mike
    Atwater Mike
    Took my black suede F100 out and warmed 'er up... got some thumbs up from 2 guys in an Apache 31 step,
    O.K., Bowties...
  21. Blues4U
    Blues4U
    from So Cal
    Good to hear that you got the ol' F100 out Mike
  22. Blues4U
    Blues4U
    from So Cal
  23. milwscruffy
    milwscruffy
    IMG_0137.JPG IMG_0138.JPG Made the drivers side motor mount, lots to clear and make as much room as possible for the exhaust. I may add some holes to it in the future. It's made from 5 pieces of 3/16" flat stock and no it's not a solid chunk. Thus why I may add holes to it. Edit: both sides now done, time to move rearward to the transmission ans frame x-members. IMG_0140.JPG
  24. nochop
    nochop
    from norcal
    Mocked up my alternator, not sure if I like it. 8050F8C6-6201-4476-A7B5-5EC985BF4609.jpeg 56C4C177-A050-4BE1-8F20-3A10EBFB790E.jpeg F90C9EE7-C087-4A06-94ED-31508254CB66.jpeg
  25. Saturn V
    Saturn V
    from Killen AL
    Welded up the drag link for the Olds. Had a friend help me with it. Can't seem to hold steady as I use to with a tig!! IMG_20220426_200342587.jpg IMG_20220426_200336109.jpg
    LAROKE, blowby, bobss396 and 4 others like this.
  26. RICH B
    RICH B
    Haven't been doing much other than therapy on shoulder. ****s to be so limited right now. Did get a few parts painted along with shaping the dash knobs. Going to try to move some stuff around so I can get a buffer out and polish them. Knob project may work out yet; least it is something new to try.
  27. bobss396
    bobss396
    I think I have almost everything here or on order for my rack & pinion steering swap. Cl***ic Industries order should arrive late in the week or early next week. Local speed shop had a 6AN to NPT adapter, pressure reducer is coming via eBay. From there if the kit hoses work out, all I need is a belt and PS fluid.
  28. ironandsteele
    ironandsteele
    Finally getting the wiring straightened out on this one so it can go back on the road:
    ironandsteele.com​
  29. jimmy six
    jimmy six
    About 3 years ago I changed my valve springs and retainers in the car because some touched. I found some bee-hive style springs and retainers in the Compe***ion Products Catalog that would work with the pressure and lift. Never gave them a thought before that.
  30. jimmy six
    jimmy six
    You might try a 55-up V8 Chevrolet generator adjustable arm. They curve at the end only where the slot is and are flat. You’ll need to cut it shorter and drill a new mount hole. I’ve used them on a lot of close mounted alternators
    pvfjr and olscrounger like this.
