Technical brake flaring
Discussion in 'The Hokey Ass Message Board' started by 1930artdeco, Apr 25, 2022.
  1. 1930artdeco
    1930artdeco
    from Lynden, Wa
    Hi All,
    OK, so I used a LISLE brake flaring tool to make the flares for my brake lines. However, several joints seem to leak a bit from around the pipe-not the threads. Is there a trick to making these not leak? I have noticed that if you look at the tube edge on sometimes there is an angle-or at least it appears there is one.
    Thanks,
    Mike
  2. B.A.KING
    B.A.KING
    Does it make double flare?
  3. saltflats
    saltflats
    from Missouri
    Cut it off and make it again, if you still have problems then maybe the tool is the problem.
    joel likes this.
  4. HOTRODPRIMER
    HOTRODPRIMER
    A perfect flair doesn't leak, I was taught to file the brake line before you do the double flair and do not over tighten to avoid any splits. HRP
  5. 1930artdeco
    1930artdeco
    from Lynden, Wa
    King-Yes it does the double flare
    Saltflats-Yep I will have to cut it and start all over:mad::(. As far as I can tell, the tool is working correctly. I am not sure of the junction block up front so I may just go with a Mustang MC so I can plumb straight to the front and rear lines.
    HRP-When you say file do you mean you take a fine file and scuff up the end that gets flared?
    Mike
    saltflats likes this.
  6. Pete Eastwood
    Pete Eastwood
    from california
    Prepping the end of the tube before flaring is the key to good flares.
    You have to undo all the distortion the tubing cutter creates.
    Deburr the inside, lightly file the sharp corner on the out side & file the end flat.
    A very small dab of white grease on the flaring mandrel helps too.
    rod1, chevyfordman, Paul and 21 others like this.
  7. nochop
    nochop
    from norcal
    I cut all mine with a dremel cut wheel, then chucked it in the flairing clamp to file 100% flat. No leaks and I did it on stainless tube. Don’t forget to ream the ID.
    1oldtimer, catdad49 and wandi harry like this.
  8. the oil soup
    the oil soup
    from Tucson,AZ
    After cutting the tubing you need to deburr the id and chamfer the end before clamping it into the tool correctly. 780DF748-E293-42B2-BE54-FF17685BAE61.jpeg
  9. 1930artdeco
    1930artdeco
    from Lynden, Wa
    Maybe that is what I am doing wrong, not getting it 100% flat before and after the flaring. The brakes hold pressure enough to get her on and off of a trailer for the move. Then I will replace some lines after I practice a bit more. Actually I am surprised I am doing as well as I am with no experience-just common sense (well sort of:D)
    Mike
  10. It's best to cut the tube with a saw or cutoff wheel... a tubing cutter work-hardens the end.
    Then put the tube in the flaring fixture with the cut end protruding through the flat side (non-flare-side) of the fixture. Use that as your filing guide to get it deburred and square.
    Slightly deburr the inside and outside of the tube.
    Follow the normal flaring instructions, taking care to NOT overtighten the tool!!! Don't totally collapse the flare into itself... leave it a bit 'under flared' and let the ***embly/tightening sequence complete the process. The idea is to make the tube conform to the fitting as it is tightened.
    Good luck!!!
  11. 1930artdeco
    1930artdeco
    from Lynden, Wa
    Thank you 28 that is good set of instructions. And thanks to everyone for giving me advice. It is such a good feeling to see her starting to come together and almost be ready for the road. Well, she is year off but from what I started with she is leaps and bounds closer to the road.
    Mike
    catdad49 and lothiandon1940 like this.
  12. jimmy six
    jimmy six
    Expensive but I bought an Eastwood flare tool. Other companies are now advertising it. After the first flare I knew I had bought a great tool. Every double flare or bubble end is perfect. I’ve used a Lisle for years and others too at work but the Eastwood is a godsend to me. I’ll be using it again tomorrow on a new fuel line.
  13. saltflats
    saltflats
    from Missouri
    One problem if you you are using a tubing from a roll, it need's to be straight on the end you flare.
  14. The tube has to be cut square, and you need to be deburr and chamfer inside and out slightly. A little lube while you are flaring helps (don't forget to clean that lube off before using the brake line).
    As mentioned above, a good flaring tool is very helpful. I also bought an Eastwood flaring tool a few years ago and couldn't be happier with a tool purchase.
  15. 1930artdeco
    1930artdeco
    from Lynden, Wa
    Salflats, I am using it from a roll so I straighten it out as best I can. Maybe I am not getting it straight enough, so that is probably another issue.
    Thanks,
    Mike
  16. tubman
    tubman
    It's a learned skill.
  17. 41rodderz
    41rodderz
    from Oregon
    Agree. Deburr and patience.
    35 Sedan likes this.
  18. Harv
    Harv
    from Sydney
    The more I think about it, the more I like this advice. I normally tighten the flaring tool as much as I can. The idea of letting the fitting "bed in" the last bit of the flare makes better sense.
    FWIW, I use a US-made MasterCool tool. Love it. This jigger is great for internal and external deburring:
    https://www.ebay.com.au/itm/252441659029?hash=item3ac6b20695:g:GBYAAOSwgY9XckIa&frcectupt=true
    Cheers,
    Harv
    egads, catdad49 and Just Gary like this.
  19. dalesnyder
    dalesnyder
    Another free tip. If your using the twin bar flare tool, keep the bars even (height wise) when you tighten them. If not the head oof the flare may be bent over a bit.
    Algoma56, bobss396, catdad49 and 2 others like this.
  20. Happydaze
    Happydaze
    Rolling the roughly straightened tube between 2 pieces of ply, 1/2" minimum (and about 3' x 1' for maneagability) will straighten it out. Long lengths might be a challenge and require some imagination!
    The threads themselves don't not seal a tube nut, they provide the clamping force that makes the seal. Pipe thread is of course a different matter.
    I guess I've been lucky with brake pipes, including stainless, all these years! Cant say the same for 3/8" stainless fuel line. Had to get creative!!
    Chris
    Algoma56 and catdad49 like this.
  21. WZ JUNK
    WZ JUNK
    from Neosho, MO
    As a backup or emergency situation these have been a life saver. 3/16" copper flare gasket. B00YTF8ZTK
    I have found that many of the new fittings I bought recently are one time use only. The metal is so soft that it forms a groove or distortion and it will not reseal when reinstalled. I do not remember having this problem in the past.
    joel and bobss396 like this.
  22. Russco
    Russco
    from Central IL
    If nobody has mentioned it either NiCopp line is much easier to work with too.
  23. Jmountainjr
    Jmountainjr
    All that I will add is be aware of the tubing you are buying. I have a number of flare tools from the old double clamp bar to the newer Eastwood like tool that use a split clamp block. The newer tool works like a charm as long as the tubing OD is on spec. I have found tubing from several sources that 3/16" tube is undersized. It's in the 0.184" to 0.185" range and not 0.187". The clamp blocks on the newer tool doesn't clamp the undersized tubing enough to prevent it being pushed out of position when forming the flare. The old double bar tool still works ok. So I now take calipers with me when shopping for tubing or by online from the one or two places that sells spec tubing.
  24. bobss396
    bobss396
    I borrow a Mastercool kit when I do lines. I now cut them with a fine hacksaw blade, I made up soft wood blocks to hold the line in my bench vise. I file the cut end square, deburr it inside and out. I do the initial flare, look it over and clean up anything I don't like before doing the final flare.
    chevyfordman and Algoma56 like this.
  25. bobss396
    bobss396
    Thanks, these are on my Amazon wish list. I have one pesky flare at my master that seeps no matter what I do, it may even be the mating surface in the offshore master.
  26. And very important to have the mating surfaces surgically clean - get into the female part with a flashlight and make sure no **** is on there. If there already was something on there, and it has been squished into the br*** surface, sometimes only a new replacement fitting will fix the weep.
  27. The quote above should be viewed as an absolute requirement :)
    After working with this stuff, I will NEVER go back to steel line. It is so much easier to flare and bend too.
    Blue One and seb fontana like this.
  28. phat rat
    phat rat
    I also use a Mastercool. But I don't buy rolls of tubing I buy 6' sections and go from there
  29. MMM1693
    MMM1693
    X2 on everything Jimmy six said
    Blue One likes this.
  30. TRENDZ
    TRENDZ
    FFA437AF-47E7-4854-9C76-E3D11259F2AA.jpeg As recommended, no tubing cutter. Work hardening makes steel or ss more likely to crack while flaring.
    A nice square cut with a good deburing inside and out is also essential to minimize the likelihood of cracking while flaring.
    With 3/16” tubing I use a drill bit by hand to debur the inside, and a hand file for the outside. All other sizes of tubing I use a Ridgid brand tube deburring tool.
    I also strongly recommend the Eastwood flaring tool. It makes the job much nicer to do, and the results are terrific with stell or ss.
    I personally don’t like using the nicop, but I’m admittedly a little strange.
