Technical Hole in piston, big
Discussion in 'The Hokey Ass Message Board' started by birdman1, Apr 26, 2022.
  1. birdman1
    birdman1
    i bought 4 flathead ford motors the other day. want to build one for 1930 dirt track racer. Everything looks good except this piston. i has a 1953 Ford Mainline I bought from my uncle in 1962. The same hole. It was caused by the left bank thermostat sticking closed. At least that was the consensus then. I have not looked at the thermostat yet. I think I will just repa
    lace the shot piston, Hone all the cylinders and put some new rings on it and run it. Pais $100 for all 4 motors. Now I need a Model T frame and some Model A axles. IMG_20220426_151345277.jpg
  2. 51504bat
    51504bat
    Only see one "Ford part number" crack to the right of the piston with the hole. Any other obvious cracks?
  3. Marty Strode
    Marty Strode
    Ah, you don't have a hole, this is a hole ! I had it bored .060 and put back together, runs great. IMG_0327.JPG
  4. Truckedup
    Truckedup
    That hole in the piston crown is text book pre ignition...
    dana barlow and Deuces like this.
  5. SEAAIRE354
    SEAAIRE354
    I’m sure it’s an optical illusion but the open valve to the right doesn’t look concentric to the seat. Probably the camera angle. And that cylinder has some nice scratches. Maybe stuck or broken rings.
  6. Flatheadjohn47
    Flatheadjohn47
    from Lewes, DE
    Why would u want a model a axle??? For the rear, I presume. Even the later model v8 axle was relatively weak 70-80 years ago,now after that many years of rust and everyday useage, is even weaker. If you absolutely want a banjo rear end, one key to look for is the tightness of the drum on the hub. These rear ends came with a square piece of keystock that for any kind of “performance” driving the square stock must be a tight fit in the drum and the matching axle. Make sure you “box” the T frame thoroughly as they are easy to “twist like a pretzel”. Just my opinion, but you are dealing with relatively “weak” parts and yes I am aware of the flatheads relatively low power output but even a stocker can wreak havoc on the pieces you want to build a car with. D18E6E0B-6C2F-48B9-BD10-032C61524A8C.jpeg
    dana barlow, Deuces and Desoto291Hemi like this.
  7. birdman1
    birdman1
    I'm not sure what to do about the crack in the block at the bolt hole next to the cylinder. Is it junk?
  8. Steve Ray
    Steve Ray
    This video shows the builder installing inserts on those bolt holes with similar cracks. They had to do five of them.
    Deuces and dana barlow like this.
  9. Flatheadjohn47
    Flatheadjohn47
    from Lewes, DE
    A crack from a stud or bolt hole is not much to worry about. Most worst cracks occur along the pan rail or from a valve seat to the bore. Some people will put a sleeve in the bore where the cracked valve seat to bore occur; some people work thru the crack by pinning. A lot of people try to sell a block or engine saying that it is a runner. A block can still be cracked and yet run, so I rarely give more than $100-$150 . Having bought,sold,traded over 50 engines over a 60 year “love affair”, I have pretty much seen it all. Flatheads Forever!! A20BF814-9221-42B5-9DB0-9639CEDB2C9D.jpeg 54A443B4-4212-4BDD-B764-BEF3542DCB99.jpeg
    winr, 51504bat and Algoma56 like this.
  10. Mr48chev
    Well that piston may have been hot in the process but I'm thinking that it had a bad case of indigestion from the bolt or screw it ate. Lets see a photo of the head showing the combustion chamber from that Cylinder. Hot piston_LI.jpg
    olscrounger and Blues4U like this.
  11. alchemy
    alchemy
    That nick isn't from FOD, it's the direction arrow.
    The little crack between the stud hole and the water port doesn't need any repair. Goop the stud up good and the thing will live for many more years. Just don't run any taps down stud hole threads as you will make them too loose and you will have weeping studs forever.
    SS327, Desoto291Hemi and harpo1313 like this.
  12. birdman1
    birdman1
    Pictures of the head. The heads were off when I got the motor, so no way to find what it was. IMG_20220428_135553558.jpg
  13. Beanscoot
    Beanscoot
    I'm more curious about the "KAR ***E ALLOY" bolt screwed into the block.
    Never heard of that make of bolt or should I say cap screw.
  14. "weeping studs forever" sounds like a line from "Broke Back Mountain". Just sayin'....
    Wanderlust, Fortunateson and i7083 like this.
  15. Mr48chev
    You might want to take a close look at the matching imprint in the head plus the three imprints put there by the FOD when it pounded it's way through the piston. ROFLMFAO.jpg fod head_LI.jpg
  16. Budget36
    Budget36
    Sits in the corner and raises hand and asks…
    “what is FOD”?
    Beanscoot, SS327 and Fortunateson like this.
  17. Fortunateson
    Fortunateson
    Yeah, what is FOD? Force of detonation?
  18. Torana68
    Torana68
    from Australia
    foreign object debri , it started as a aircraft thing
    Budget36 likes this.
  19. BJR
    BJR
    And should end there.:eek:
    rbrewer, indyjps, blowby and 2 others like this.
  20. alchemy
    alchemy
    You might want to take a look at the piston to the right and notice the exact same mark in the exact same place.
    SS327, blowby, egads and 2 others like this.
  21. Truckedup
    Truckedup
    Us guys who mess with bikes know pri ignition damage. A piece of something got red hot causing very advanced ignition and in just several engine cycles the piston dome over heats and collapses. The suspected loose object may have caused the pre ignition but it did not in my opinion, directly cause the piston dome hole damage.
    this photo is what pre ignition does in a second with no loose junk in the cylinder. 22204608012_92e525ee37_c.jpg
  22. Fortunateson
    Fortunateson
    Thank you.
  23. blowby
    blowby
    from Nicasio Ca
    Yep.
    In this case it means Forward Orientation Direction :)
    Mine has them too.
    Steve Ray and egads like this.
