Projects '53 Mild Custom - Dads Hot Rod
Discussion in 'The Hokey Ass Message Board' started by oliver westlund, Jan 29, 2019.
  1. loudbang
  2. JeffB2
    JeffB2
    from Phoenix,AZ
    See if you have any Hispanic owned upholstery shops in your area they may be able to do that type of innovation we have many here in Phoenix I saw a local shop that did one in a '54 Victoria maybe check out some lowrider shows in your area.
    oliver westlund likes this.
  3. oliver westlund
    oliver westlund
    Many thanks curt! @57ragtop
    These are just what this build needed! 20211201_123319.jpg 20211201_123334.jpg
    loudbang and JeffB2 like this.
  4. oliver westlund
    oliver westlund
    Had to figure out how to mount these, heres what i came up with... 20211202_102046.jpg 20211202_102026.jpg 20211202_102032.jpg
  5. oliver westlund
    oliver westlund
  6. oliver westlund
    oliver westlund
  7. oliver westlund
    oliver westlund
    Didnt need the 3 through the olds lense, wont be doing that on both sides. Just factory ford 3 screws and add two in the ford lense for the olds lense
  8. oliver westlund
    oliver westlund
  9. oliver westlund
    oliver westlund
  10. Ferdyeight
    Ferdyeight
    I dig the tail lights. On mine I used testors model glue to put 59 cad bullets over the centers. They've held on for over a year in all conditions. Just an idea if you want to secure the two lenses together permanently
  11. oliver westlund
    oliver westlund
    I didnt want them together permamently only because the factory ford tail light screws are inside the olds tail lights, but as it sits the ford tail lights screw in then you screw the olds lights to the ford lights and they feel snug and secure! I may still french the bezels in, theyre rusty anyway. Im giving the car to dad for christmas this year though so i need the floors done, carpet in, seat in before i do that, hopefully running and driving too but we shall see haha might be a blessing to have it incomplete, make a father son project out of finishing it
  12. greaser 35
    greaser 35
    from FRANCE
    I have the same taillight on my '54 Ford :cool:
  13. oliver westlund
    oliver westlund
    Did you install them kver the stock ones or by themselves?
  14. greaser 35
    greaser 35
    from FRANCE
    On the stock Ford directly !
  15. greaser 35
    greaser 35
    from FRANCE
  16. oliver westlund
    oliver westlund
    Very nice, beautiful car!
  17. oliver westlund
    oliver westlund
    Floor progress, bead roller and metal shears made this fun 20211212_163242.jpg
  18. oliver westlund
    oliver westlund
  19. oliver westlund
    oliver westlund
    Gave the car to dad for christmas, it wasn't quite as far along as I wanted but it was time. He seems to be pretty into it, we went to the local salvage yard grill hunting. Found a 52 willys aero and almost pulled the trigger but decided in the end to buy a repop 55 ford and go that route, dad likes that better and I have to agree! I think I am going to hit the brakes on metal work for now and see if i can get it running driving and stopping. Heres a pic of the basic look we are after, wont be changing the hood corners though Walt-christian-1953-ford.jpg
  20. stanlow69
    stanlow69
    I`d cut the floor out and start over. Do some sandblasting and use proper sized pieces of metal. Your dad is worth the extra effort.
  21. oliver westlund
    oliver westlund
    Well its solid and almost done now but i guess i could cut it all out and start over... been using s**** pieces to keep cost down
  22. stanlow69
    stanlow69
    Metal isn`t that expensive.
  23. oliver westlund
    oliver westlund
    Mail call! Harness and a cpl voltage reducers, going to finish the floors minus thr trans tunnel (for access to trans mount and shift linkage) then going to pull the engine and trans and strip old wires out/ paint engine bay and install new harness. Paint engine then ****on it back together, hoping i can pull it off within next cpl weeks. Goal is to prep and paint the body when the weather warms up and have dad cruising by the summer 20220119_154218.jpg
  24. greaser 35
    greaser 35
    from FRANCE
  25. oliver westlund
    oliver westlund
    okndnx and Squablow like this.
  26. oliver westlund
    oliver westlund
    Dad picked the ring n cap combo, he didnt dig the sombreros
  27. oliver westlund
    oliver westlund
    Little more floor progress, finished welds, seam sealer and zero rust paint, gonna get sound deadener over it when its done and carpet, its solid and will hold up well 20220426_170508.jpg
    Squablow likes this.
  28. JeffB2
    JeffB2
    from Phoenix,AZ
  29. Squablow
    Squablow
    I've used that same Peel 'n Seal stuff on the floors of several of my cars, it works great, seems to do a nice job of heat and sound insulation for about a quarter of the cost of any of the commercially available products and has held up really well for me.
    I don't think the stuff shown above is Peel 'n Seal, because it comes in rolls only about 6" wide so it lays out in long thin strips and would show a lot more seams, the stuff above looks like it's in big sheets.
  30. oliver westlund
    oliver westlund
