Hot Rods Nature Abhors a Vacuum, Or, The Hemi A Roadster fills a void.
Discussion in 'The Hokey Ass Message Board' started by flynbrian48, Jul 18, 2020.
  1. flynbrian48
    flynbrian48
    2A47933F-865D-4B56-9B3F-102E719B1D5A.jpeg Well, I'm truly back to my Michigan self. Today I set about dropping the steering arms just a touch more (the tie rod still dragged on the radius rods). The right side went fine, the left seemed to be, until I foolishly pushed the tie rod in the steering arm to check. I knew it was still hot, but it was only for a couple seconds...
    Of course, being hot, the taper went up far enough just by hand, that by the time I pushed it in, swung the arm over to make sure the rod didn't hit the radius rod, the boss had cooled enough to REALLY lock it together. I ran to the tool box to grab a pickle fork and heavy hammer, but by the time I got it apart the little nylon bushing inside the (polished stainless tie rod end) was boiling and the ball was sloppy. Added bonus, evidently the fumes from whatever plastic that bushing was are respiratory irritants, because my nose is still burning and my eyes are watering.
    I needed to order some other stuff from Speedway anyway, so I have a new LH 11/16 rod end on the way. I decided to run the Dayton wires I had on the '34, and ordered 2 Excelsior 165R15's for the front, tubes, liners, and a set of wheel adaptors to get from 5 on 4 3/4" knock off hubs to the 5 on 4 1/2" bolt pattern on the hubs. The correct bolt pattern knock off hubs are available, but the 15" wheels won't clear the huge Buick drums, an extra inch turns the trick. These are wheels that'll go on it.
    Lets see what I wreck tomorrow...
    Stogy and RICH B like this.
  2. flynbrian48
    flynbrian48
    Uh, well yeah. Cheap 'gl*** '32 hood, cut the top in half and sectioned it to fit, cut down the sides, and hacked a teardrop shape hole to let the Hemi hang out. I'm gonna get an English Wheel from HF and learn how to make speed blisters to cover them heads... D5287E56-1B92-4091-9186-0E16DB157DCC.jpeg FF47D6EA-74A8-4203-A7C5-C460B8684B2D.jpeg 700F98E0-03DC-459E-B5A3-893CFFAC798F.jpeg 58C711B6-B7BB-42D1-AD56-72A35A83A05B.jpeg
  3. 1-SHOT
    1-SHOT
    from Denton
    Why did you leave the Automatic Transmission Cooler on the motor?
  4. Mr48chev
    That's looking good. If you haven't seen them before you might want to check this guys's series of metal working and shaping videos. I've been learning quit a bit off some of his stuff.
    jim32 and chryslerfan55 like this.
  5. flynbrian48
    flynbrian48
    3 reasons: 1. It's there. 2. The fan would have to trimmed to clear the trans cooler fittings in the radiator. I figure I'll need all the cooling I can get. 3. I kinda like it.
    Stogy and SS327 like this.
  6. flynbrian48
    flynbrian48
    69EEFC95-1C46-4C18-BBA2-7DDC08D9BC82.jpeg Today's project was twofold: Get transmission lines run to the original cooler on the engine, which I did, and get the brake pedal mounted to the MC bracket and get the plunger in. Success on both counts! The trans lines are hard to photograph, for the amount of time and effort it took it's not really very exciting to photograph, but I feel good being able to check that task off the list.
    The brake pedal was more photogenic, I have a new "Safety Clutch" pad left over from the wagon project, and since I used one as a brake pedal pad in it, thought this one would be appropriate for the roadster. Along with the T6 Texan starter pedal pressed (that's a pun, son) into service as the gas pedal, I don't have plain pedals. Well, maybe one of them is a plane pedal (that's another joke, son), but like 'em.
    In other news, a buddy of mine has a stack of FI Tech 4 bbl fuel injection units, new, complete but the boxes have been opened. He will sell me one CHEAP. I like the idea, it looks like a 4 bbl carb, and while I'll have to make an adaptor to fit the DeSoto 2 bbl intake, it'll save over an inch of height, and I can adapt the original oil bath air cleaner to it with a little cutting and t*******. I think I'm gonna pull the trigger on this and an an electronic ignition for the original dual point distributor. E8BE95A0-B3AB-47A1-88D7-DE2E381B811A.jpeg 69EEFC95-1C46-4C18-BBA2-7DDC08D9BC82.jpeg
    brEad, Stogy, chryslerfan55 and 4 others like this.
  7. flynbrian48
    flynbrian48
    It was almost 50 here today, which was better than yesterdays mid 30's, windy and snow showers but it still ****ed. Inside the shop was warm and dry with the pellet stove roaring, and I got some stuff done. The gas tank is in, I made a simple riser out of some s**** 2x4 and 2x6 so it rests on the flange. A couple stainless steel straps for hold downs and carpet on the riser and , Bob's Yer Uncle, that's done.
    I ran fuel line, replaced the tie rod end I ruined the other day, and was excited to get some boxes from Speedway filled with shiny bits. A stainless front spreader bar, wheel adaptors to unite the Dayton knock off hubs to the Buick drums (and let the wheels fit) and a pair of 175/65 R15 tires to replace the much to wide 205/60R15's on the front wheels. I was eager to see it with the Dayton wires on, and wasn't disappointed. They look great on this car, they never looked right on the '34.
    I spoke with Rob Fournier about making an aluminum hood and side panels for it (as opposed to the gl*** '32 hood I cut up to fit), so I'll see what he has to say about cost before I make a decision. I think I've figured out how to make blisters in the 'gl*** hood sides, which would amount to a couple yards of mat and cloth and some resin, so it'll work either way. I sort of wince at having someone else do things for me, but it would be nice to have a neat, lightweight, beautifully made hood for it. It'd be cool polished. We shall see... 2C9B7362-4CF3-4759-8ADD-528B8CE5366E.jpeg C303E6C9-82FA-4346-B280-061D031477E8.jpeg 01A692CC-8306-4E2B-AE7A-7D65BD0057A2.jpeg
    brEad, Stogy, chryslerfan55 and 3 others like this.
  8. flynbrian48
    flynbrian48
    Oh, about the that hood... The thing is at least 5/16" thick, the sides are so rigid they won't lay against the slightly curved cowl. This bothered me, even just mocked up and held on with shipping tape, so I cut a couple reliefs in the back edge which lets it lay flat. Or lay curved. Some Dzus fasteners would hold it all together, so I think I'll try my hand a forming some blisters with pink foam and duct tape, which is how I made the rolled rear pan. Enough filler and Feather-Fill and it'd look fine... A5AC33C0-5F1B-4D80-A957-A2F627048CDC.jpeg
    brEad, Tman, Stogy and 3 others like this.
  9. Tim
    Tim
    from KCMO
    Looks infinitely better with the different wheels man
    Just Gary, Stogy and flynbrian48 like this.
  10. flynbrian48
    flynbrian48
    Yes it does, yes it does. The best part is that even with 1" thick adaptors they aren't any further further out from the hub flange. The offset isn't as much as the Salt Flats. They wouldn't have fit over the Buick drums otherwise.
    Tim and Stogy like this.
  11. 1-SHOT
    1-SHOT
    from Denton
    Never be ashamed to ask for help, watch as they do it and learn. When you make a mistake you also learn how not to do it.
  12. BamaMav
    BamaMav
    from Berry, AL
    As much as I liked the Salt Flats on the car, I gotta admit the wires do look good. Just glad I don't have to keep them clean!
  13. flynbrian48
    flynbrian48
    Back at it today (gone for a week to our nieces wedding in Indy)! I'm gonna start wiring, finish up and bleed the brakes, and hook the fuel lines up. A buddy contacted me who has a mini van 3rd row seat he's not going to use now, so that's available. I'm getting excited
  14. flynbrian48
    flynbrian48
    I didn't get it running or the brakes bled, but I DID get the mystery seat from a buddy and got it mounted. I used some hinges so it flips forward and I have a gate latch to secure it. It'll work with some finessing of the latch, so I'm happy. The upholstery of course is awful (it's from some mini-van), but it'll be easy to recover and make look appropriate. 6CEAAFD8-4171-450B-842F-E5CDC803B771.jpeg 8050AE66-B092-48FE-9038-C295151B725E.jpeg 1E7680F8-9BC8-491B-A7A5-9009538A97C5.jpeg EAD9CE95-78B7-4828-B126-C11DFDC0BE62.jpeg 4307FED4-43C1-4943-94C9-A2FAE283CBE6.jpeg
    Tim, Just Gary, brEad and 5 others like this.
  15. flynbrian48
    flynbrian48
    Ok, enough debating with myself. I'm going to glue the 'gl*** hood top together, paint it, get some leather straps, buckles and Miller springs and run just the hood top. Then, when I have some time, make an aluminum top and sides later. I've gotta get something done or it'll never get done.
    The s****s of aluminum are to hold it together while I 'gl*** up the backside to stick it all together, then I'll flip it over, take them off, and 'gl*** up the topside. It's like glueing a model car together. 46ADC625-D568-4CDE-B7CE-BB396758A8D5.jpeg 4EB71514-42D1-4AE1-87C3-1E3DDE66F227.jpeg 118C61E8-D590-46EB-B804-3F88180E0C76.jpeg
    AHotRod, brEad, Tim and 6 others like this.
  16. flynbrian48
    flynbrian48
    AHotRod, Tim, AndersF and 1 other person like this.
  17. flynbrian48
    flynbrian48
    Now I'm all sticky... 3D188104-771B-4CDF-9C84-9D7F1122761A.jpeg 3ED9867A-0353-4C41-83DF-6A2273B636F7.jpeg
    AHotRod, brEad, osage orange and 4 others like this.
  18. Johnboy34
    Johnboy34
    from Seattle,Wa
    Na, but you'll be really itchy after grinding and sanding BOTH sides for paint! ;) It'll look great though! :cool:
    flynbrian48 likes this.
  19. 1-SHOT
    1-SHOT
    from Denton
    I never seen perforated mat before
  20. flynbrian48
    flynbrian48
    Neither have I. The panels are extremely thick and heavy. Side panels are the same perforated mat, and are at least 5/16" thick. It's not my first choice of materials, I want to build an aluminum hood for it, but I can use these in the interim.
    AndersF likes this.
  21. Johnboy34
    Johnboy34
    from Seattle,Wa
  22. 1-SHOT
    1-SHOT
    from Denton
    We use to have Woven Rover it looked like a blanket woven out of 3/8 cord like yow would use in a chopper gun. I have used a lot of both.
  23. flynbrian48
    flynbrian48
    Just Gary likes this.
  24. flynbrian48
    flynbrian48
    It's not pretty, yet, but the '32 hood top is now a '29 with '32 grill shell hood top. I stood back and took a look, the first that hit me was that it's time to clean the shop up. The second realization I had was that I should have noticed yesterday when I couldn't find my impact driver, buffer, wool bonnets and polishing compound when I wanted to polish the little camper. 0DC26A03-B40D-42CA-908F-E0BCBBEE8E85.jpeg DFA94DEF-74DB-43CA-A0D6-7C2A997AB3CD.jpeg
    Tim, AHotRod, Just Gary and 5 others like this.
  25. Looks great!
  26. 1-SHOT
    1-SHOT
    from Denton
    They tried rubbing nylon stockings on your arms to remover the fibergl*** dust. That stuff gets EVERYWHERE
  27. flynbrian48
    flynbrian48
    F228CFC0-8845-43E3-BF06-2D40DACA22B7.jpeg 708EBED0-4D2E-490B-9B48-7CB02081323C.jpeg The DeSoto wagon came with a new, never installed Rhode Island Wiring harness. There's some stuff I won't need or use, but I should be able to weed it out enough to use. I thought it'd look appropriate, and while some of it is wrapped in plastic from RI, it's all linen wrapped wire, in the right colors, and most of the wrapped harness won't be visible anyway.
    I haven't gotten much done, what with summer fun and travel, and working on the other cars. The Diamond T got a new transmission after 10 years of towing and abuse, and I've been picking away at the finishing details of the DeSoto.
    Tim, rjgideon, AndersF and 2 others like this.
  28. flynbrian48
    flynbrian48
    This is the first chance I've had to work on the roadster since we got back the middle of April! I sorted through and weeded out the original, reproduction (I think it's Rhode Island Wire) harness that came with the '52 DeSoto, and started wiring the roadster. It's going good, although I discovered I don't have an original headlight switch. Went to NAPA, they didn't have any, neither did O'Rielley's or Auto-Zone. So, I ordered a generic one from Summit. I can pull wires to the front and rear, all linen wrapped, for headlights, park/turn, taillights, (what happened, why is the font italics now?) and wire the switch in the dash when I get it. I'll use the original wiper switch for the heater, it's two speed, so it's progress.
    I'm using the NOS voltage regulator as a junction block only, I have a one wire alternator.
    AC15DAF9-8ABA-4281-A9D3-7BCB2F7DE00D.jpeg CC4A9194-14EC-4668-AF71-12F63D945381.jpeg F5117119-9CF6-4230-A33D-072E4804080E.jpeg
    GordonC, rjgideon, Tim and 2 others like this.
  29. The second letter (...I...) on the top tool bar activates and de-activates the italics.
  30. 41rodderz
    41rodderz
    from Oregon
    You go man go. Digging all the work. First two times I worked with fibergl*** my arms itched . After that nothing for the next few decades. May be blessed or may be odd cir***stances. I love fibergl*** work.
