Hot Rods Headlights with Built-In Directional Lights
Discussion in 'The Hokey Ass Message Board' started by 19Fordy, Apr 27, 2022.
  1. 19Fordy
    19Fordy
    I am considering installing these lights in my 40 Ford.
    Has any HAMBER used these lights? Feedback or suggestions appreciated. I would also like to use LED tailights.
    Also, what directional switch that mounts on the steering column should I buy?
    https://www.ebay.com/itm/Street-Hot-...YAAOSwtpBeWDiC
  2. 19Fordy
    19Fordy
    OOPS! Didn't mean to break any HAMB rules. Thanks for the reply.
    Jeff Norwell and jimmy six like this.
  3. I used something similar on a vw bug
    didn’t look as street rodish as these
  4. goldmountain
    goldmountain
    I think they look like you have a broken lens on your headlight which let in water that pooled on the lower edge. But that's just my opinion.
    clem likes this.
  5. sunbeam
    sunbeam
    I like them so many turn signals look add on.
    hotrodharry2 and 41rodderz like this.
  6. Automotive Stud
    Automotive Stud
    Why not just put a dual filament socket in the parking light and use that as the turn signal?
  7. Mr. Sinister
    Mr. Sinister
    from Elkton, MD
    You could probably find something similar with a halo that flashes instead of the seperate turn signal bit that would look a lot more period.
  8. krylon32
    krylon32
    from Nebraska
    I have a amber dual filament bulbs and sockets in the parking lights of my 40 standard and they work fine.
  9. 4ty
    4ty
    No offense, but your car is too nice looking to put those on. My 40 is still 6V and one of the reasons I used fog lights on the front for signals.
    Paul in CT
    Elcohaulic and rusty valley like this.
  10. Mr48chev
    Add me to the while functional I am just not a fan of the look club. It's usually not all that hard to change the socket in the park light to a double element socket. Then your turn lights look proper.
    The other option to me depending on the build theme of the car is a pair of lights on the bumper that look like fog lights but are turn signals.
    This turn signal is on the fender of the 51 1-1/2 ton I have.
    I keep thinking that they would look pretty nice all done up right and sitting on the splash apron where a pair of fog lights would normally go.
  11. One issue with the turns in the headlights is the turns are a lot less visible when the headlights are on. There's a reason the OEMs don't do this...
  12. Petejoe
    Petejoe
    from Zoar, Ohio
    My similar 37 lights have a socket for turn signal bulbs that double as parking lights.
    These sockets are positioned below the headlight sockets about 1-2” from the edge of the reflector.
    Work well and are visible at night.
    Still look original too
  13. 41rodderz
    41rodderz
    from Oregon
    I have been debating these or halo’s as well. On “Effie” my 1948 Ford F1 I am thinking of making a full tube grill and eliminating the factory signals.
  14. You know what they are, but that may not be true for other drivers. You may be underestimating the confusion factor... :eek:
    kevinrevin likes this.
  15. jaracer
    jaracer
    My buddy's 34 which uses an old pair of fog lights for turn signals.
    hfh, cfmvw, 54reno and 1 other person like this.
  16. Jeff Norwell
    Jeff Norwell
    MODERATOR
    You didn't break any rules.. they are just kinda streetroddy-ish....
  17. Before the street rod crowd got them by 2 or 3 decades (maybe 4) you could get a turn signal kit from JC Whittney that placed an amber bulb inside your existing non-seal beam light. They are not as modern as many think. very very old idea.
    I have never used them although I did one have a very old motorcycle light with the same basic setup being used as a "park" light. It worked OK.
    OK let me back up and regroup. We are talking about a little bulb inside your non-seal beam headlight correct?
  18. X38
    X38
  19. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I am on my second Anglia build. I do not like the headlights mounted on the tops of the fenders, nor do I like free standing turn signals on this particular body.
    So I plan to recess the headlights like we did on my son's Anglia and use the headlights with integral turn signals to keep the front end cleaner.
    cfmvw, 41rodderz and LOST ANGEL like this.
  20. pirate
    pirate
    from Alabama
    I have these on a car I built. There are amber LED’s in the bottom of the halogen headlights and a little more discreet then the lense being amber. I like them because it’s a cleaner look without having to find a place to hang an extra turn signal light. Don’t remember where I bought them but pretty easy to find. Maybe not for everyone your mileage may vary. 563C24DD-C160-44F3-94D6-5A3F9090480F.jpeg
  21. 41rodderz
    41rodderz
    from Oregon
    The idea of using fog lamps as turn signals maybe a good idea but nowadays you need something that large in the rear to get people’s attention.:)
    hotrodharry2 and chevyfordman like this.
  22. 41rodderz
    41rodderz
    from Oregon
    If memory recall didn’t 40’s Dodge truck have cowl lights? I have some hiding as well as Ford cowl lights I could use . 19Fordy that could work for you too. Even on both side panels near the grill ?
  23. 41rodderz
    41rodderz
    from Oregon
  24. chevyfordman
    chevyfordman
    I have built in orange turn signal bulbs inside my 32 Ford headlights and it really messes up the light beam. So I want to replace the headlights one of these days. I would use the 40 parking light but you do have to replace the socket and run a wire from both lights back to the turn signal device.
  25. i7083
    i7083
    So that's what happened!
  26. Blake 27
    Blake 27
    I used those as well.
  27. Petejoe
    Petejoe
    from Zoar, Ohio
    74C1EC3F-4235-491E-A970-427BB753A4E7.jpeg C31B3B26-A1C9-4B43-82F8-5ECE4BB6FAAA.jpeg 16986D34-1A1E-4415-858F-99C14D6BF954.jpeg
    took some pictures. The headlights are causing some glare in the picture but this gives some idea of the view.
    Shown are headlights on. Parking lights on. And headlights and turn signal on.
    41rodderz likes this.
  28. notaford1
    notaford1
    from webster ny
    I used these turn signal not as obvious 6EBB8C05-59DD-4F4C-B7F8-101F10680844.jpeg
  29. jimmy six
    jimmy six
    My 1939 Indian Sport Scour is that way. Front park light.
  30. Dan Hay
    Dan Hay
    Hard pass, use the parking lights as signals. Also, probably 90% of the people that need to know you are turning are behind you.
