Hot Rods Rare Chevrolet 327 Intake manifold?
Discussion in 'The Hokey Ass Message Board' started by EZ Cool, May 1, 2022.
  1. EZ Cool
    EZ Cool
    Alliance Vendor
    from Slaton TX
    I have a cast iron intake manifold casting number 3872782 date code E116. It also has a large H cast just below the firing number. It does not come up on any if the casting number lists I have found. It looks identical to another 1966 intake with casting number 3872783 which shows to be for a 275HP 327. Can anyone shed some light on this?
  2. Taboo56Chevy
    Taboo56Chevy
    Picture of the intake casting number? The H is for calling out its a Holley base over a Rochester/Carter base.
    Deuces likes this.
  3. indyjps
    indyjps
  4. EZ Cool
    EZ Cool
    Alliance Vendor
    from Slaton TX
    Here are some pics of the manifold in question. image_67158785.JPG image_67152641.JPG image_67185409.JPG
    Deuces likes this.
  5. 427 sleeper
    427 sleeper
    Last 3 number's look like 783 to me.
    indyjps, low down A and Fordors like this.
  6. EZ Cool
    EZ Cool
    Alliance Vendor
    from Slaton TX
    On closer examination I believe your right. What is the significance of the H under the firing order?
  7. Bob Lowry
    Bob Lowry
    Number 3872783 shows that it is for a 283"/327" , 1966-67, with a mounting pattern
    for a Holley.
    ottoman and Deuces like this.
  8. SS327
    SS327
    Holley carb.
    Deuces likes this.
  9. bjinx
    bjinx
    Looked on two Camero sites both listed it as
    '66-'67 A B X/327 w/o AIR
    Holley Service Replacement
    I believe Service Replacement means you could buy it at dealer parts counter if you wanted a square bore intake
    Deuces likes this.
  10. Sporty45
    Sporty45
    What's a Camero? :p
  11. EZ Cool
    EZ Cool
    Alliance Vendor
    from Slaton TX
    I also have a Carter AVS tag 4028SA which shows to be for a 66 275HP 327. I fits both manifolds and I’m ***uming it came from the factory on the manifold without the H.
  12. Its an over rated piece of estiércol. :D :D
    Evidently speeel chek doesen't wurk on computer.
    Budget36 likes this.
  13. It's the Chevrolet 'monkey see, monkey do' version of the modified Falcon that F*%d marketed. Just another wasted use of manufacturing resources! YOMV....... but you'd be wrong!
  14. indyjps
    indyjps
