Technical GPS speedometer
Discussion in 'Traditional Hot Rods' started by Jim Hewitt, May 2, 2022.
  1. Jim Hewitt
    Jim Hewitt
    Does anyone out there have knowledge or opinions on the GPS speedometers? I thinking of putting one in my 27 T Bucket but would like pros and cons from you guys. What do you think?
  2. Dave Gray
    Dave Gray
    I used one in my 56 Corvette land speed racer. I compared it to the time slips
    And found it to be very accurate.
  3. krylon32
    krylon32
    from Nebraska
    I have done a 32 5 window with a GPS speedo and was really satisfied with it. We mounted the pickup module on the front side of the mirror. Sometimes it took a few 100 yards once I backed out of the garage for it to pick up the signal but once it locked on it was very accurate. My gauges were Autometer.
  4. lothiandon1940
    lothiandon1940
    There have been numerous threads about them. A quick search will find them.
    rockable and Jim Hewitt like this.
  5. 911 steve
    911 steve
    from nebraska
    I had a dakota digital speedo with gps sensor from speedway. very simple hookup, accurate. only drawback was it took a few blocks of driving to acquire a satellite
  6. squirrel
    You miss out on all the fun of messing with the gears in the back of the transmission, routing the cable so it won't wiggle or get melted, getting the calibration right, etc.
    How boring.
  7. mrspeedyt
    mrspeedyt
    I have a free GPS speedometer app on my phone. It seems to be very accurate.
    vintage56, verno30, Jibs and 6 others like this.
  8. I have had one in my Buick for 11 years. Great. Can even do a timed 1/4 mile.
    Ben
    40ragtopdown likes this.
  9. ClutchDumpinDan
    ClutchDumpinDan
    I’ve used a couple of them from SpeedHut. They’re my go to now. So much easier to install and no worries if you like to swap rear gears/tires on occasion.
  10. Dave Mc
    Dave Mc
    Put one in my 29 Like it a lot, Sensor is magnetic, mounted it on lip of w/shield frame.Speedhut Gauges and speedo
  11. lothiandon1940
    lothiandon1940
    .Everyone tells me they eat up battery life. Is that true? I've been a little reluctant to try the app because of that.
    iagsxr likes this.
  12. squirrel
    Some guys install a "cigarette lighter socket" to charge the phone as they drive.
    I think with modern phones the GPS power consumption isn't too bad, although having the display on all the time will use some power. If you're just driving around town, you won't notice. If you're on a long trip, you'll plug the phone in to charge, anyways. So it's not an issue.
    Cosmo49 and Squablow like this.
  13. Jim Hewitt
    Jim Hewitt
    mad mikey and Dave Mc like this.
  14. mitch 36
    mitch 36
    I mostly also use the phone app, the stock speedo in my 36 is about 12 mph off so instead of changing gears in the th350, I just either guess-timate or use the app. Mitch
  15. iagsxr
    iagsxr
    I used to use my phone all the time in my OT tow rig truck because the speedometer was off due to tire size. We race a lot at a track that's 3:15 from my shop. It would all but kill the battery by the time we got there.
    That was with a Galaxy S5. I think my S20 has way better battery life, but I had the speedo recalibrated so don't really use it that way anymore.
  16. Mr48chev
    I use my phone app with my 77 Chevy flatbed that eats speedometer cables as fast as you can put them in and on my old phone it did put a drain on the battery but as Jim said, plug it in and life is good. The truck only leaves the yard when it has a job to do and after going trough a couple of cables it is just easier to use the phone app.
    The app works great to calibrate a mechanical speedometer with. Check the speed at 60. calculate the difference and which way. figure the percentage and then pop the speedometer drive and driven gears out or check color on the drive gear and figure out how you have to change the gears to change that percentage.
    Algoma56 and lothiandon1940 like this.
  17. squirrel
    I've used the phone for speed/distance on a couple road trips, when the speedo/odo died and I needed to keep track of gas fillups (non working gas gauge too). It works. It's just not as convenient as having a proper old fashioned speedometer that works.
  18. Mr48chev
    I remember driving to Texas and then back to Bonneville in my 51 Merc in 1988 with no speedometer and no gas gauge, Dad was along but wouldn't drive because the gauges didn't work. He couldn't figure out how I knew pretty well how much gas the car would take at stops and when to stop but I was watching mile markers and figuring out gas mileage at every stop. No cell phone apps in those days. What a bonus that would have been on that trip.
  19. dana barlow
    dana barlow
    from Miami Fla.
    Simple , no cost and less clutter=
    If you run an engine rpm tach?,You can just put some small marks for each 10 MPH*, around on outer tach face in high gear.:D
    That way the rpm tach,is also a speed-O*. You can check your real speed now days from your GPS speed on you phone,old school was to have a buddy drive beside you,holding at each 10 MPH mark you make.:cool:
  20. wicarnut
    wicarnut
    I put a VDO GPS speedometer in my 32 Ford years ago, easy install, worked perfect, accurate, was happy with product. Looked it up at YOGI'S, $369 +$229 for sensor sending unit, a little pricey, do not remember what I paid back then, 15 years ? ago. I believe all cell phones have an app for speedo/maps.
    lothiandon1940 likes this.
  21. theHIGHLANDER
    theHIGHLANDER
    I'd never put a speedo on. Trust me, y'all be grateful for that. :cool:
    BJR, Baumi, Ned Ludd and 3 others like this.
  22. hrm2k
    hrm2k
    I found a set of gauges from a company called Vee Three. Primarily boat gauges. The GPS speedo does a really good job. All the other gauges come with senders. It was an easy install
  23. Mechman_22
    Mechman_22
    from Nc
  24. hepme
    hepme
    same here, i use the app on my phone and just mark my speedo to certain intervals like 30, 50, 70, etc. Found its def. more accurate compared to a "fixed" speedo calibration.
    firstinsteele likes this.
  25. Mechman_22 likes this.
  26. 26hotrod
    26hotrod
    from landis n c
    Like Dana Barlow I marked my tach & use it for a speedo. I mounted the tach next to the interior rear view mirrow at top of the windshield, easy to see..........
  27. deucemac
    deucemac
    When I installed my Cl***ic Instruments GPS unit, the instructions said to hook the power wire to a battery feed. I did that and if the car sat for a couple of weeks, the battery would be low. I switched the power wire to a switched sourse and that stopped that. However, the speedometer won't register if I pull right out of the garage,, for about a minute or so. So, I fire up the engine, wait a minute and everything is fine.
  28. fastcar1953
    fastcar1953
    Run off what the tach says. Works for me. Wife even checked with her phone, now she watches the tach.
    Truckedup and Joe Travers like this.
  29. flynbrian48
    flynbrian48
    Just use your phone. It's the easy way out. Unless you still have a flip phone...;)
  30. PhilA
    PhilA
    I tried that, is there a number I can dial to get my current speed?
    49ratfink, Baumi, Texas57 and 14 others like this.
