Projects S.E.G.A. Olds build
Discussion in 'Traditional Hot Rods' started by Saturn V, Oct 11, 2021.
  1. Saturn V
    Saturn V
    from Killen AL
    Here's a couple of better pics of the main caps. They was on my work bench this morning when I got to work. As soon as I can, I'll get a block set up in the mill! IMG_20220426_184129364.jpg IMG_20220426_184201289.jpg
    catdad49, winr, seb fontana and 9 others like this.
  2. Saturn V
    Saturn V
    from Killen AL
    I have work going on at 2 different shops today! A friend of mine's kid made me some nice solid body bushings today! IMG_20220430_144149.jpg
    winr, catdad49, bchctybob and 4 others like this.
  3. Saturn V
    Saturn V
    from Killen AL
    IMG_20220430_143247781_HDR.jpg I'm working on a filler bushing to put the racing column in the factory column's position. The kid is faster than me!!
    catdad49, bchctybob, bobss396 and 4 others like this.
  4. What degree did you set your caster? I set mine at the 6-7⁰ mark, it'll set straight when it's up on jack stands, but when I pulled the drag link of it falls over. Don't know if I'm good or not o_O
    bchctybob likes this.
  5. Saturn V
    Saturn V
    from Killen AL
    I originally set mine at 10,, but after talking with Quain. I cut mine back to 6... My last bracket car was a a-arm car. Set it at 10..car ran like it was on a string! After studying and asking about a straight axle set up. I decided to cut it back a bit.. I'll know more once it hits the track.
    To be honest,,, I'm not sure what I'm doing! This is my 1st g***er!! Thing probably will hurt me!!!!
  6. I hear ya loud and clear lol, I read on here somewhere to shoot for the 6-7⁰ mark. With the wheels cut, you can see it. I guess I was afraid it was still too much. I've only driven mine down the driveway a couple of times, I guess we'll see what happens on the highway. I used the speedway kit, and I'm thinking I'm gonna have to pull a leaf, it's pretty stiff. Love your build brother
    Just Gary and 427 sleeper like this.
  7. Saturn V
    Saturn V
    from Killen AL
    Thank you! I pulled 3 leafs outta mine,,, thinking I will have to put one back in...but mine is a track only car! This being my 1 st straight axle build,,,, I may have to cut it all back out and do it again!!!!
    Lloyd's paint & glass likes this.
  8. Saturn V
    Saturn V
    from Killen AL
    Finished the filler bushing this evening. Now I have to figure out how to safely mount the column.. IMG_20220502_193450417.jpg
  9. 6sally6
    6sally6
    Use one of those good-look'in 4 bolt mains you had machined!!!!
    Should hold that column in place just fine!
    (I'm sure you can just 'whip-out' somethin on the lathe...no prob)
    6sally6
    seb fontana and Saturn V like this.
  10. seb fontana
    seb fontana
    from ct
    I had my Shoebox caster as little as 2° but car is relatively low and not that fast [102].
    Saturn V likes this.
  11. Saturn V
    Saturn V
    from Killen AL
    I'm hoping this nightmare will make at least 118 in the 1/8th!
    Just Gary likes this.
  12. seb fontana
    seb fontana
    from ct
    It would have taken me another 1/4 m !
  13. Saturn V
    Saturn V
    from Killen AL
    winr, catdad49, bchctybob and 5 others like this.
  14. ***uming you'll get a weight break, compared to same size SBC or SBF ?
  15. Saturn V
    Saturn V
    from Killen AL
    Yes, I'm getting a break, but getting weight added for the intake.
  16. Good...How about a break for the wheelbase, ala the Gapp and Roush "taxi" ? ;)
    OahuEli likes this.
  17. Saturn V
    Saturn V
    from Killen AL
    That would be nice!! But I'm not sure I'll be able to get down to minimal weight!
  18. Saturn V
    Saturn V
    from Killen AL
    Lower column mount made, a few holes drilled. I think it's gonna work! IMG_20220512_194649776.jpg IMG_20220512_194619857.jpg
  19. Saturn V
    Saturn V
    from Killen AL
    IMG_20220514_123113303.jpg Got the solid body bushings installed today..
    catdad49, bchctybob, brEad and 5 others like this.
  20. Saturn V
    Saturn V
    from Killen AL
    Back to the engine today! Studs came in for the mains. Placed the caps in place so y'all can get a idea of what needs to be machined. IMG_20220516_192538889.jpg IMG_20220516_192144330.jpg IMG_20220516_192544851.jpg
  21. Saturn V
    Saturn V
    from Killen AL
    I got another piece of the puzzle today. Looks like this weekend we'll be putting the mock up block and trans back in the car.
    The clutch and brake pedals will be next on the list to make! IMG_20220517_173730543.jpg
  22. Saturn V
    Saturn V
    from Killen AL
    Some guys are body guys, some fabricators,,this is where I shine!!! I love being a machinist!! IMG_20220518_173945939.jpg IMG_20220518_181104386.jpg IMG_20220518_184244813.jpg IMG_20220518_184754410.jpg IMG_20220518_185655790.jpg
    catdad49, AHotRod, winr and 13 others like this.
  23. wheeltramp brian
    wheeltramp brian
    Nice work on that block
  24. Saturn V
    Saturn V
    from Killen AL
    Thank you!! Hopefully it will be going to work with me in a couple of weeks for the line bore and hone.
    Then it's back to the money making process. I have depleted my hobby account!!
  25. bchctybob
    bchctybob
    I would never dare to call myself a machinist but I really enjoyed making stuff on my mill and lathe over the years. I did all kinds of stuff looking for a reason to use the machines. Very satisfying for a tinkerer.
  26. Saturn V
    Saturn V
    from Killen AL
    A mill and a lathe are the best friends a hot-rodder can have!!
  27. Saturn V
    Saturn V
    from Killen AL
    Didn't get as much done today as I wanted to. We got the mock up engine and transmission in place,, trying to figure out the steering shaft routing. IMG_20220521_123949985.jpg IMG_20220521_123959154.jpg
    winr, catdad49, Brian Penrod and 5 others like this.
  28. Saturn V
    Saturn V
    from Killen AL
    The steering shafts are cut to length. Shaft support welded into place. Now I need to clean the fab bench off!! The joints will be Tig welded. IMG_20220528_123133733.jpg IMG_20220528_123145148.jpg
  29. Saturn V
    Saturn V
    from Killen AL
    Back to the engine today. One crank option for those on a budget is a old 425/early 400 crank. The diesel and big block Olds share the same main journal size and spacing.
    One of the things you have to do is turn down the counter weights to clear the inside of the block. IMG_20220530_090544079.jpg IMG_20220530_092834313_HDR.jpg
    winr, catdad49, OahuEli and 8 others like this.
  30. AHotRod
    AHotRod
    How many of these cranks do you have?
    Do you have enough parts to build 3 engines to test and swap?
    SEGA is hard on engines
