Technical Dropped tie rod end question
Discussion in 'Traditional Hot Rods' started by el_coyotte, May 30, 2021.
  1. el_coyotte
    el_coyotte
    Unfortunately I need the spacers to gain clearance from spring. I thought if they were pressed into the arm and welded together it would be a safe solution. After lowering the drag link is 5,5 in over the ground. I think is a sufficient distance.
    Instead maybye I can try to bend the steering rod a little like I did with the cross steer drag link.
  2. seb fontana
    seb fontana
    from ct
    Sorry I didn't mean to imply change but hard to see in different angles of pics. Is there a short way of coping a pic, marking stuff and posting it back?
  3. seb fontana
    seb fontana
    from ct
